MCP Server Integration
Viz Arc includes an MCP (Model Context Protocol) server that enables integration with AI assistants and development tools. MCP is an open standard (now under the Linux Foundation) that provides a universal way to connect AI tools to external data and capabilities.
Compatible MCP Clients
The Viz Arc MCP server works with any MCP-compatible client, including:
Client
Type
Notes
Claude Desktop
Desktop App
Anthropic's desktop application
ChatGPT Desktop
Desktop App
OpenAI's desktop application (MCP support added March 2025)
Cursor
IDE
AI-powered code editor with MCP support
VS Code + Copilot
IDE
GitHub Copilot agent mode supports MCP
Windsurf
IDE
Built-in MCP Plugin Store
Cline
VS Code Extension
Autonomous coding agent with MCP integration
Continue
IDE Extension
Open-source extension for VS Code and JetBrains
OpenAI Codex
CLI/IDE
Supports MCP servers in CLI and IDE extension
Architecture Overview
MCP Client VizArc.McpServer.exe Viz Arc
(Any compatible) <----> (Lightweight server) <----> (Main application)
stdio REST API
Benefits
  • Work with multiple AI tools, not locked to one provider.
  • Use your existing AI subscriptions.
  • Access Viz Arc documentation and templates from your preferred tool.
  • Create and modify templates through natural conversation.
  • Work alongside the main Viz Arc application.
Setup Instructions
Step 1: Locate the MCP Server
Find VizArc.McpServer.exe in your Viz Arc installation:
C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe
Step 2: Configure Your MCP Client
Configuration varies by client. Below are examples for popular MCP clients.
Claude Desktop
  1. Open configuration file: %APPDATA%\Claude\claude_desktop_config.json.
  2. Add the configuration:
    "mcpServers": {
    "vizarc": {
    "command": "C:\\Program Files\\Vizrt\\Viz Arc\\MCP\\VizArc.McpServer.exe",
    "args": []
  3. Restart Claude Desktop completely (check system tray).
ChatGPT Desktop
  1. Open ChatGPT Desktop settings.
  2. Navigate to MCP Servers section.
  3. Add new server with command: C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe.
  4. Restart ChatGPT Desktop.
Cursor
  1. Open Cursor Settings (CTRL + ,).
  2. Navigate to MCP section.
  3. Add server configuration:
    "vizarc": {
    "args": []
  4. Restart Cursor.
VS Code with GitHub Copilot
  1. Open VS Code Settings (CTRL + ,).
  2. Search for MCP.
  3. Edit settings.json and add:
    "github.copilot.chat.mcpServers": {
    "vizarc": {
    "args": []
  4. Reload VS Code.
Windsurf
  1. Open Windsurf's MCP Plugin Store.
  2. Search for VizArc or add custom server.
  3. Set command path: C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe.
OpenAI Codex CLI
codex --mcp-server "C:\Program Files\Vizrt\Viz Arc\MCP\VizArc.McpServer.exe"
Important: Use double backslashes (\\) in JSON paths for Windows.
Step 3: Verify Connection
After configuring your MCP client:
  1. Start a new conversation.
  2. Ask: "What Viz Arc tools do you have access to?".
The AI should respond with information about available Viz Arc tools.
Example Prompts
For documentation queries (Viz Arc not required)
  • "Show me the available parameter types in Viz Arc"
  • "How do callbacks work in Viz Arc templates?"
  • "What is the difference between SetControlObject and UpdateTemplate?"
For live template work (Viz Arc must be running)
  • "What template do I have open in Viz Arc?"
  • "Add a text input parameter called 'headline' to my current template"
  • "Show me the control objects available in my template"
  • "Link the 'score' parameter to the 'ScoreText' control object"
Available AI Tools
Static Tools (Always Available)
These tools work without Viz Arc running:
Tool
Description
get_documentation
Access Viz Arc API documentation.
get_parameters_reference
Get parameter types and properties reference.
get_sample_templates
Show example template implementations.
list_parameter_types
List all available UI parameter types.
query_documentation
Search documentation for specific topics.
Dynamic Tools (Require Viz Arc Running)
These tools require Viz Arc to be running and a valid AI license:
Tool
Description
get_current_project
Get information about the loaded project.
list_templates
List all templates in the current project.
get_template
Get details of a specific template.
validate_template_code
Validate JavaScript or VBScript code.
create_template
Create a new template and open it in Template Designer.
get_current_editing_template
Get the template currently open in Template Designer.
modify_current_template
Apply changes to the currently open template.
get_control_objects
Get available control objects for linking.
link_parameter_to_control_object
Create UI linkage between parameter and control object.
unlink_parameter
Remove linkage from a parameter.
get_parameter_linkages
View all current parameter linkages.
Modifying Parameters
When using modify_current_template, you can update various parameter properties:
Property
Description
x, y
Parameter position
width, height
Parameter dimensions
label
Display label
parameterColor / backgroundColor
Background color
Supported Color Formats
  • Hex: #FF5500 or #AARRGGBB
  • RGB function: RGB(255, 85, 0)
  • Comma-separated: 255, 85, 0
  • JSON object: {"R": 255, "G": 85, "B": 0}
Troubleshooting
AI Prompt Panel Not Visible
Cause: AI license not valid or not available.
Solution:
  1. Verify AI license status in System > Configuration > Info.
  2. Contact your Vizrt representative if license is missing.
MCP Server Not Connecting
Check 1: Configuration file syntax
  • Ensure claude_desktop_config.json has valid JSON syntax.
  • Verify double backslashes in Windows paths.
Check 2: Executable path
  • Confirm VizArc.McpServer.exe exists at the specified path.
  • Test by running the executable directly in a terminal.
Check 3: Restart Claude Desktop
  • Fully quit Claude Desktop (check system tray icon).
  • Relaunch the application.
"AI License Required" Error
Cause: Valid AI license not detected.
Solution:
  1. Ensure Viz Arc is running.
  2. Verify AI license in System > Configuration > Info.
  3. Contact your Vizrt representative for license issues.
Documentation Not Loading
Check that the documentation folder exists: %ProgramData%\Vizrt\VizArc\Resources\MCP\AI_Documentation\.
If missing, reinstall Viz Arc or contact support.
Dynamic Tools Not Working
Cause: Viz Arc application not running.
Solution:
  1. Start Viz Arc.
  2. Load a template in template editor.
  3. Try the tool again.
Note: Static tools (documentation, parameter types) work without Viz Arc running. Dynamic tools require Viz Arc to be running with a loaded template.
