After having accessed the action holding the list of ControlObjects thought the GetAction method, the single ControlObjects can be retreived using the global method
BaseControlObject GetControlObject( BaseAction action, string ControlObjectID )
Most Control Object types have the following generic properties:
Text (String)
This property adapts to all objects (execute string)
IntControl.Text = "5"ImageControl.Text = "IMAGE*FolderA/SubfolderB/ImageName"
ID (String)
Returns ObjectID
Description
Returns the object description
Each Control Object type has specific properties:
Control Container
Properties:
Visibility
Position
posX (double)
posY (double)
posZ(double)
Rotation
rotX (double)
rotY (double)
rotZ (double)
Scaling
scaX (double)
scaY (double)
scaZ (double)
This type doesn’t have the Text property.
Control Image
Properties:
Path (string)
Position
posX (double)
posY (double)
Scaling
scaX (double)
scaY (double)
Control Material
Properties:
Path (string)
Control Omo
Properties:
Value (integer)
Control Text
Properties:
Value (string)
Control List
Example:
sub OnInit()    'declare variables    dim objAction, table, cell    dim output1, output2, output3    'get table obj action    objAction = arc.GetAction("object")    table = arc.GetControlObject (objAction, "controlObj_ID")    Console.WriteLine("Table name: " & table.Text)    'set values in single cells inside the table    table(0,0).value = false    table(0,1).value = 5    table(2,5).x = 12    table(3,6).value = "IMAGE*/Default/GER"    'assign values to a variable and show in debug console    output1 = table(0,0).Text    output2 = table(0,1).Text    output3 = table(0,2).Text    Console.WriteLine("cell - " & output1 & " | " & output2 & " | " & output3)end subProperties:
Accessor
table[int row, int col]: returns a cell
nbcolumns (integer): number of columns
nbrows (integer): numbers of rows
Single Cells Properties
Cell  | Type  | Additional Information  | Example  |
BaseCell  | Text (string)  | Sets or gets value as string. Common to every cell type.  |
BoolCell  | Value (boolean)  |
DoubleCell  | Value (double)  | table(0,5).x= 12.8  | |
DupletCell  | X (double)  | table(0,5).text = "0.55 0.2"  | |
GeomCell  | Value (string)  | table(0,5).value = "GEOM*/folder/geometry"  | |
ImageCell  | Value (string)  | table(0,5).value = "IMAGE*/folder/image"  | |
IntCell  | Value (integer)  | ||
MaterialCell  | Value (string)  | table(0,5).value = "MATERIAL*/folder/material"  | |
TextCell  | Value (string)  | ||
TripletCell  | X (double)   | table(0,5).text = "0.55 0.23 1.23"  |
Control Integer
Properties:
Value (integer)
Control Double
Properties:
Value (double)
Control Boolean
Properties:
Value (boolean)
