General
This page details configuration steps for OIDC providers.
The OpenID Connect Protocol (OIDC) is used to authenticate users. It can, in theory, be configured to integrate with any OIDC compliant identity provider.
The following providers have been tested and are supported:
  • Microsoft Entra ID (formerly Azure Active Directory)
  • Vizrt SSO (Keycloak)
Microsoft Entra ID
The Entra ID application configuration consists of two parts: an App Registration for the technical details of the application, and an Enterprise Application that defines user and group access and their role assignments, as well as other aspects of how the app integrates with your tenant.
Detailed Instructions
Complete instructions to set up the Entra ID App Registrations.
Introduction
This guide walks you through the steps to create and configure two App Registrations in your Microsoft Entra ID (Azure AD) tenant: "Vizrt Back-Ends" and "Vizrt MSE". These configurations allow your applications to use Entra ID for authentication and authorization.
When creating the registrations manually, both appId (Application Client ID) and id (Object ID) are auto-generated by Azure AD.
Step 1: Create the "Vizrt Back-Ends" App Registration
  1. Navigate to Azure Portal: Go to the Azure Portal and log in.
    1. Select your tenant that should be configured on the top right (user details) under Switch directory.
  2. Access Entra ID: Search for and select Azure Active Directory.
  3. Go to App Registrations: In the left-hand menu, under Manage, select App registrations.
  4. Create New Registration: Click on + New registration.
    • Name: Vizrt Back-Ends
    • Supported account types: Select Accounts in this organizational directory only (Single tenant).
    • Leave the Redirect URI (optional) section blank for now.
    • Click Register.
The registration name is free-form. This guide uses "Vizrt Back-Ends" as the example throughout; use whatever fits your naming convention.
If an application needs a client secret, create it in the same registration under Certificates & secrets > Client secrets > New client secret. Give it a description and an expiry that matches your rotation policy, then copy the value immediately — Entra shows it only once. Sign-in breaks when a secret lapses, so track the expiry date.
Step 2: Define App Roles for "Vizrt Back-Ends"
  1. In the "Vizrt Back-Ends" App Registration, navigate to App roles under Manage.
  2. Click on + Create app role. Create the following roles. Ensure the settings match exactly.
    1. For each role, click Apply after entering the details.
    Some role values of VAM-Messaging require the {APPCLIENTID} to be set to the application (client) ID as prefix. This can be retrieved from the app registration status page.
Role Display Name
Allowed member types
Value
Description
VAM-Storage Read/Write
User, Application
readwrite
VAM-SERVICE
User, Application
vam
VAM-SERVICE
VAM-SERVICE Admin
User
vam-admin
VAM-SERVICE Admin
VAM-Messaging Write All
User, Application
{APPCLIENTID}.write:*/*/*
VAM-Messaging Read All
User, Application
{APPCLIENTID}.read:*/*/*
VAM-Messaging Configure All Vhosts
User, Application
{APPCLIENTID}.configure:*/*
RabbitMQ Configure All Vhosts
pilot-admin
User, Application
pilot-admin
Has administrator access to Viz Pilot Settings and all apps
graphic-designer
User, Application
graphic-designer
Can use Template Builder
pilot-editor
User, Application
pilot-editor
Can use Pilot Edge
pilot-journalist
User, Application
pilot-journalist
Can use Pilot Edge
pilot-mse
Application
pilot-mse
Used by the Media Sequencer Engine (MSE) to connect to Viz Pilot
VAM-Storage Admin UI
User
consoleAdmin
MinIO Admin UI
The VAM-Messaging roles authorize service-to-service messaging. The storage and message-broker administration consoles are not part of this configuration, so no browser sign-in is set up for them.
  1. Go to API permissions: In the left-hand menu, under Manage, select API permissions.
  2. Add Microsoft Graph Permissions:
    • Click + Add a permission.
    • Select Microsoft Graph.
    • Choose Delegated permissions.
    • Search for and select the following permissions: email, offline_access, openid, profile, and User.Read.
    • Click Add permissions.
  3. Add Vizrt Back-Ends Permissions:
    • Select the My APIs tab.
    • Find and click on Vizrt Back-Ends.
    • Choose Application permissions.
    • Search for and select the following permissions (the display names are in parentheses for easier identification):
      • {APPCLIENTID}.configure:*/* (VAM-Messaging Configure All Vhosts)
      • {APPCLIENTID}.read:*/*/* (VAM-Messaging Read All)
      • {APPCLIENTID}.write:*/*/* (VAM-Messaging Write All)
      • readwrite (VAM-Storage Read/Write)
      • vam (VAM-SERVICE)
      • pilot-mse (pilot-mse)
  4. Grant Admin Consent: After adding all permissions, you will likely need to grant admin consent. Click the Grant admin consent button and then Yes. Ensure the status of all permissions changes to Granted.
API Permission
Permission Name
Type
Admin Consent Required
Microsoft Graph
email
Delegated
No
Microsoft Graph
offline_access
Delegated
No
Microsoft Graph
openid
Delegated
No
Microsoft Graph
profile
Delegated
No
Microsoft Graph
User.Read
Delegated
No
Vizrt Back-Ends
Application
Yes
Vizrt Back-Ends
Application
Yes
Vizrt Back-Ends
Application
Yes
Vizrt Back-Ends
Application
Yes
Vizrt Back-Ends
vam (VAM-SERVICE)
Application
Yes
Vizrt Back-Ends
Application
Yes
Step 3: Expose API for "Vizrt Back-Ends"
  1. In the "Vizrt Back-Ends" App Registration, navigate to Expose an API under Manage.
  2. Click Set next to Application ID URI.
  3. Accept the default api://{APPCLIENTID} and click Save.
Step 4: Configure Redirect URLs for "Vizrt Back-Ends"
  1. Open the newly created "Vizrt Back-Ends" App Registration.
  2. In the left-hand menu, under Manage, select Authentication.
  3. SPA Redirect URIs:
    • In the Single-page application (SPA) section, click Add a URI.
    • Add one URI per web application, replacing FQDN with the host name of your VAM installation:
      • https://FQDN:30443/config/
      • https://FQDN:30443/pilot/pcs-admin/
      • https://FQDN:30443/pilot/pilotedge/
      • https://FQDN:30443/pilot/template-builder/
      • https://FQDN:30443/pilot/data-server-config/
    • Click Save.
Entra matches a redirect URI exactly, including the trailing slash. Add one set of URIs for every host name users reach the installation by. Port 30443 is the gateway reached directly; omit the port when the installation sits behind a load balancer that terminates on 443.
Step 5: Create the "Vizrt MSE" App Registration
  1. Go to Azure Active Directory (Entra ID) then App registrations.
  2. Click + New registration.
    • Name: Vizrt MSE
    • Click Register.
Step 6: Request API Permissions for "Vizrt MSE"
  1. In the "Vizrt MSE" App Registration, navigate to API permissions under Manage.
  2. Click on + Add a permission.
  3. Select the My APIs tab.
  4. Find and click on Vizrt Back-Ends.
  5. Under Application permissions, select the following roles:
Role Display Name
Role ID
Type
<role-id>
Role
VAM-SERVICE
<role-id>
Role
pilot-mse
<role-id>
Role
pilot-admin
<role-id>
Role
graphic-designer
<role-id>
Role
pilot-editor
<role-id>
Role
pilot-journalist
<role-id>
Role
Role IDs are generated when a role is created, so they differ in every tenant and every app registration. Select the roles by display name in the portal; read the IDs from the App roles blade of "Vizrt Back-Ends", or from its Manifest, if you need them.
  1. Click Add permissions.
  2. Click the Grant admin consent button and then Yes. Ensure the status of all permissions changes to Granted.
Step 7: Assign Roles to Users/Groups for "Vizrt Back-Ends"
  1. Go to Azure Active Directory (Entra ID) then Enterprise applications.
  2. Find the Vizrt Back-Ends application.
  3. In the left-hand menu, under Manage, select Users and groups.
  4. Click on + Add user/group.
  5. Select the users or groups you want to grant access to.
  6. Under Select a role, choose the appropriate role or roles you defined in Step 2.
  7. Click Assign. Repeat this for all necessary user/group and role assignments.
Step 8: Enforce V2 JWT Tokens
  2. Open both the "Vizrt Back-Ends" and "Vizrt MSE" App Registrations.
  3. In the left-hand menu, under Manage, select Manifest.
  4. Find the "api" section in the JSON manifest.
  5. Ensure the "requestedAccessTokenVersion" property is set to 2. If it is not present, or is set to null or 1, change it to 2 and click Save.
Completing these steps configures your Entra ID App Registrations. Remember to configure your actual applications with their respective Application (client) IDs, any necessary client secrets, and the correct scope and audience information for authentication and authorization.
