Version 1.5 | Published April 05, 2022 ©
Supported Protocols
Currently, Tracking Hub has native support for the following protocols:
FreeD (see Description of the FreeD protocol)
Shotoku
RTHead
NCam
Xpecto
XML Tracking: A special feature, a self-definable protocol for special solutions
Motion Analysis (it is possible to work with two MA instances)
mo-sys (with lens information)
Trackmen
Trackmen Mocap
Vicon
Libero
Spidercam
spidercamfd
Spidercam-frameb
Flair
Thoma
Stype A5
Stype HF
Camreginfo
Technodolly
Skycam
Gsgeopoint
Kuper
FreeDa0
Telemetrics
hd-Skycam
kromanov
Arraiy (only with VIZRT lensfile)
Sky X Cam
Cable Cam
Eagle Eye
GeoPro
Important: Tracking Hub is able to parse these protocols and send the translated data to Viz Engine. Being in this list does not mean the tracking system is certified!
