System Requirements
This section detail the system requirements.
Syncronization
The Tracking Hub needs some sort of synchronization method on the machine it is installed. This can be:
a running Viz Engine installation, or
an installed Plura synchronization card.
If sync sources is not found, the Tracking Hub can still be used in “free running” mode. Free running is not intended and should not be used for production. It can, however, be used to experiment with tracking on a laptop. For use in production either Viz Engine or Plura synchronization is needed.
Minimum Hardware Configuration
Minimum 4 GB Ram
Dual-Core Intel or AMD CPU
Min 10 gigabyte free disk space
Recommended Hardware and Software Configuration
8 GB Ram
Quad-Core Intel or AMD CPU
Windows 7 Pro 64 Bit
Supported Hardware and Software
Windows 7 32-Bit and 64-Bit
Viz Engine 3.7.2 (either 32-Bit or 64-Bit) or later
Plura PCL-PCI and PCL-PCIe (L, LV, 3G) timecode reader cards (Driver 5.16)
Studio Manager requires .NET framework 4.5.1 or higher.
