Communication with Tracking Hub
Tracking Hub provides a command interface similar to that offered by Viz Engine. The default port is 20000.
Command Syntax
<token> <location>[*<property>]* <command> [<parameter>]*
 Where:
  • <token>: The token tells the receiver how to interpret the message, if an answer is expected etc.
  • <location>: Reference to an object or a collection of objects.
  • <property>: Reference property or properties or member objects contained in the root object or collection.
  • <command>: The command to be executed on the property or object.
  • <parameter>: Command parameter or parameters.
Tokens
> 0
Client receives and answers carrying the same token.
-1
Client receives no answer.
-2
(only for message from Tracking Hub) Reserved for notifications.
-3
(only for message from Tracking Hub) Status message.
Answer
You always get a string as an answer. It starts with a status code followed by the actual content (for example, XML) or an error message.
(0|1) [string|xml|message]
0
Failure
Followed by an optional error message.
1
Success
Followed by an optional status message or an answer in a prearranged format.
Long Pattern for Answer Handling
if (answer != null) {
    // Handle error answer
    if (CommandMessage.IsFailure(answer)) {
        if (CommandMessage.IsErrorMessage(answer)) {
            Log.Error("{0} returned an error: {1}", command, CommandMessage.ExtractMessage(answer));
            return;
    // Handle success answer
    if (CommandMessage.IsSuccess(answer)) {
        // HANDLE VALID ANSWER HERE
        return;
    Log.Error("{0} returned an invalid answer", command);
} else {
    // No answer at all
    Log.Error("{0} returned no answer", command);
This pattern is implemented in: CommandMessage.IsSuccess(string answer, string command)
Short Pattern for Answer Handling
    // REPORT ERROR HERE
    return; // then bail out
Failure Messages
Note: Any command message may fail and return an error. It is because of the command interface having changed with a new version of Tracking Hub.
The most common generic error messages are:
Unknown Location
0 Unknown location: <location>
Returned if the top level location of the command message is unknown.
Unknown Property
0 Unknown property: <location>[*<property>]*
Returned if command message starts with a known location, but contains an unknown property in the following property path.
Unknown Command
0 Unknown command: <location>[*<property>]* <command>
Returned if command message starts with a known location and valid property path, but ends on an unknown command.
Commands
MAIN
Tracking Hub matching, available ports, IPs, etc. (MAIN*):
MAIN*COMPORTS GET = <portname>[,<portname>]*
MAIN*PARAMETERLIST GET = <parametername>[,<parametername>]*
MAIN*PROTOCOLS GET = <protocolname>[,<protocolname>]*
MAIN*LOCAL_IPS GET = <ip>[,<ip>]*
MAIN*VIZ_IP SET <ip> or <adaptername>
GET = <adaptername>
MAIN*TRACKING_IP SET <ip> or <adaptername>
GET = <adaptername>
MAIN*CONFIGURATIONS GET = [<name>[,<name>]*]?
//MAIN START not used
//MAIN STOP  not used
//MAIN*RUNNING GET = <bool> not used
MAIN*WRITE_LOG_FILE SET <bool>
GET = <bool>
MAIN*FORWARD_LOG SET <bool>
GET = <bool>
MAIN*LICENSE SET <key>
GET = <name>,<number of cameras>,<days left> (name is either Cameras or Dongle, -1 means unlimited cameras/days)
MAIN*DEBUGLEVEL SET <int>   (range is  1 ... 10, 1 only emergency, 10 all)
GET = <int>
MAIN*DEBUGLEVEL++
MAIN*DEBUGLEVEL--
MAIN*TH_VERSION GET = <version>
Tracking Hub version as major.minor.patch, for example 1.99.0.
MAIN*ROLE SET <int>
GET = <int>
Backup role of this Tracking Hub: 0 none, 1 Master, 2 Slave. Setting it applies the backup rule immediately — see Backup Configuration.
MAIN*NDI_SOURCES GET = <name>[,<name>]*
NDI sources currently visible to Tracking Hub.
MAIN*TCPROTOCOLS GET = <protocolname>[,<protocolname>]*
Available timecode protocols, as MAIN*PROTOCOLS does for tracking protocols.
MAIN*LIC_TYPE SET <int>
GET = <int>
License system, matching the LIC_Type setting in the user interface.
MAIN*LIC_LOC SET <int>
GET = <int>
Where a license is acquired, matching LIC_LOC in the user interface: 0 local, 1 network, 2 local + network.
MAIN*LIC_CAM SET <int>
GET = <int>
Number of licensed cameras.
MAIN*3RDPLICENSE GET = <string>
Third party license information. Read only.
MAIN*PARAMETERSERVICEPORT SET <port>
GET = <port>
Port of the parameter service.
MAIN*WEBSOCKETPORT SET <port>
GET = <port>
Port of the websocket interface. Setting it reopens the websocket.
MAIN*RINGBUFFERSIZE SET <int>
GET = <int>
MAIN*AI_PATH SET <path>
Path used by the AI components. Sending the command without a value clears the path. There is no GET.
MAIN*CSINTERPOL SET <int>
GET = <int>
Center shift interpolation, the same setting stored as CentershiftInterpolation in BaseConfig.xml.
MAIN*USEWINSOCK2 SET <int>
GET = <int>
Stored as Usewinsock2 in BaseConfig.xml.
MAIN*BACKUP_IP SET <ip>
GET = <ip>
Address of the backup Tracking Hub. Setting an empty or too short value clears the address and deactivates the backup partner.
MAIN*SYNCHRONIZE SET
Runs the synchronization from the Master to the Slave — see Backup Configuration for what is transferred.
MAIN*POST_AUTOLOAD SET <0|1>
GET = <0|1>
With 1, the current post session is stored as the session to load on the next start.
MAIN*TIMING SET <value>
Toggles the send timing insertion. The value is required but not evaluated.
MAIN*CANBUSTEST SET <value>
Toggles the CAN bus test. The value is required but not evaluated.
CONFIG
Store configuration on the Tracking Hub machine:
CONFIG EXISTS = 0|1
CONFIG SAVE
CONFIG LOAD
CONFIG SET = <name>
CONFIG GET = <name>
CONFIG RESET
CONFIG*BASE SAVE
CONFIG*BASE DISMISS
CONFIG SAVE_AS <name>
Saves the current configuration under a new name and makes it the active one. This writes the whole set: the studio configuration file, the router configuration, the cyc and the video wall. The name may contain spaces. Without a name the answer is “No filename given!”.
CONFIG SEND = <xml>
Returns the current configuration as XML without writing anything to disk.
STUDIO
Base studio configuration (STUDIO*):
STUDIO GET = <xml>
STUDIO*MODE SET FREE|AV|VIZ
GET = SET
STUDIO*FREQUENCY SET 50|60|59.94
GET = SET
STUDIO*SHAPE SET LSHAPE_LEFT|LSHAPE_RIGHT|USHAPE|WALL|HOLE
GET = SET
STUDIO*CYC SET <xml>
GET = SET
STUDIO*TIMING GET = <bool>
STUDIO*SENDDELAY GET = <int> [in ms]
SET   <int> [in ms]
STUDIO*BUSYLOOP  GET = <int> [type]
SET   <int> [type]
STUDIO*CYC DISTRIBUTE
Pushes the current cyc to all connected Viz Engines. Add this to the existing STUDIO*CYC entry.
STUDIO*VW SET <xml>
GET = <xml>
DISTRIBUTE
The video wall, handled exactly like the cyc: SET replaces it, GET returns it, DISTRIBUTE pushes the current one to all connected Viz Engines. Sending SET with a value shorter than three characters deletes the video wall.
STUDIO*BASECFG GET = <xml>
Returns BaseConfig.xml from the configuration folder. The matching SET exists but is handled on the large-file path rather than as a normal command.
TEMPLATES
Templates stored on the Tracking Hub machine (TEMPLATES*):
TEMPLATES*COUNT GET = <amount of templates>
TEMPLATES LIST = <name1, name2, . . .>
TEMPLATES*<name> GET = <xml>
TEMPLATES*<name> SET <xml>
TEMPLATES*<name> DELETE
TEMPLATES*<name> LOAD = <xml>
TEMPLATES*<name> USE <name>
TEMPLATES*<name> SAVE <ts_name1 ts_name2 . . . rig_name1 rig_name2 . . . 1 2>
TRACKING SYSTEMS
Tracking Systems set up on the Tracking Hub machine (TRACKING_SYSTEMS*)
TRACKING_SYSTEMS*COUNT GET = <number of tracking systems>
TRACKING_SYSTEMS CREATE <name>
TRACKING_SYSTEMS DELETE <name>
TRACKING_SYSTEMS XMLFILES GET = <string>
TRACKING_SYSTEMS*<idx/name> GET = <xml>
TRACKING_SYSTEMS*<idx/name> CONNECT
TRACKING_SYSTEMS*<idx/name> DISCONNECT
TRACKING_SYSTEMS*<idx/name>*INDEX GET = <index>
TRACKING_SYSTEMS*<idx/name>*NAME SET <name>
GET = <name>
TRACKING_SYSTEMS*<idx/name>*SLOTINDEX SET <slotindex>
GET = <slotindex>
TRACKING_SYSTEMS*<idx/name>*PROTOCOL SET <protocolname>
TRACKING_SYSTEMS*<idx/name>*NETUSE SET <netuse>
GET = <netuse>
TRACKING_SYSTEMS*<idx/name>*COMPORT SET <name>
GET = <name>
TRACKING_SYSTEMS*<idx/name>*BAUDRATE SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*PARITY SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*STOPBITS SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*DATASIZE SET <baud>
GET = <baud>
TRACKING_SYSTEMS*<idx/name>*HOST SET <ip>
GET = <ip>
TRACKING_SYSTEMS*<idx/name>*PORT SET <port>
GET = <port>
TRACKING_SYSTEMS*<idx/name>*XMLFILE SET <string>
GET = <string>
TRACKING_SYSTEMS*<idx/name>*STATUS GET = DISCONNECTED|NOT_RECEIVING|BAD_TIMING|GOOD_TIMING
//only in running mode
TRACKING_SYSTEMS*<idx/name>*PARAMETERS GET = <parametername>[,<parametername>]*
TRACKING_SYSTEMS*<idx/name>*SENDRAWDATA SET <bool>
TRACKING_SYSTEMS*<idx/name>*RAWDATA_OFFSET <parametername> ACT
TRACKING_SYSTEMS*<idx/name>*RAWDATA_OFFSET <parametername> SET <int>
// not in use any longer
//TRACKING_SYSTEMS*<idx/name>*SENDDELAY GET = <ms>
//                                      SET <ms>
//this command switches hexdumplogging
TRACKING_SYSTEMS*<idx/name>*HEXLOG SET <bool>
GET = <bool>
TRACKING_SYSTEMS*<idx/name>*TICKCOUNT SET <parametername, value>[,<parametername, value>]
GET = <parametername, value>[,<parametername, value>]
TRACKING_SYSTEMS*<idx/name>*RCVTIMECORR SET <bool>
GET = <bool>
TRACKING_SYSTEMS*<idx/name>*NDI_COMPRESSED SET <0|1>
GET = <0|1>
Receive Compressed. Only the metadata of the NDI stream is read, which keeps GPU and CPU load down. On by default.
TRACKING_SYSTEMS*<idx/name>*NDI_AVSYNC SET <0|1>
GET = <0|1>
Use AVsync. The NDI library tries to harmonize the timing of incoming and outgoing frames. Off by default and not recommended.
TRACKING_SYSTEMS*<idx/name>*NDI_TIMING SET <0|1|2>
GET = <0|1|2>
What the tracker paces its work on: 0 VIZ, 1 NDI, 2 NDI av. The default is 2.
TRACKING_SYSTEMS*<idx/name>*LONGITUDE SET <string>
GET = <string>
TRACKING_SYSTEMS*<idx/name>*LATITUDE SET <string>
GET = <string>
TRACKING_SYSTEMS*<idx/name>*ALTITUDE SET <string>
GET = <string>
Longitude, latitude and altitude define the GPS zero point of the studio. They are used by the HD Skycam protocol, which converts them to UTM coordinates as the origin of its tracking data. Other protocols ignore them.
LATTICES
Lattices set up on the Tracking Hub machine (LATTICES*):
LATTICES*COUNT GET = <zero-based index>
LATTICES CREATE <name>
LATTICES DELETE <name>
LATTICES LENSFILES GET = <string>
LATTICES LENSFILES RELOAD
LATTICES*<idx/name> CREATE PARENT|CHILD <childname>
LATTICES*<idx/name> GET = <xml>
LATTICES*<idx/name>*INDEX GET = <index>
LATTICES*<idx/name>*NAME SET <string>
GET = <string>
LATTICES*<idx/name>*FILTER_ZOOM SET <bool>
GET = <bool>
LATTICES*<idx/name>*TYPE SET SIMPLE_CAM|OBJECT|LATTICE
GET = SIMPLE_CAM|OBJECT|LATTICE
LATTICES*<idx/name>*SLOTINDEX SET <slotindex>
GET = <slotindex>
LATTICES*<idx/name>*<parameter>*NAME SET <string>
GET = <string>
                               *OFFSET SET <float>
GET = <float>
                               *INVERT SET <bool>
                                     GET <bool>
                               *DELAY SET <float>
                                      GET <float>
LATTICES*<idx/name>*TRACKINGDELAY SET <frames(float)>
LATTICES*<idx/name>*VISUAL_XML SET <xml>
                               GET = <xml>
LATTICES*<idx/name>*CALIBRATION SET <bool>
                                GET = <bool>
LATTICES*<idx/name>*CALIBRATIONDONE GET = <bool>
LATTICES*<idx/name>*CALIBRATION_RANGE GET = <zoom_min> <zoom_max> <zoom> <focus_min> <focus_max> <focus>
LATTICES*<idx/name>*LENSRANGE SET <lensrange_min> <lensrange_max>
                              GET = <lensrange_min> <lensrange_max>
LATTICES*<idx/name>*SCALEVAUES SET <ScXNear, ScXWide, ScYNear, ScYWide>
                               GET = <ScXNear, ScXWide, ScYNear, ScYWide>
LATTICES*<idx/name>* LENSFILE SET <string>
                              GET = <string>
LATTICES*<idx/name>* LENSFILE_LENSEXT SET <string>
                                      GET = <string>
LATTICES*<idx/name>*LENSVALUES SET <0|1> = <stream_id>
Returns the id of the lens value stream for this rig, which a client can use to receive lens values over the websocket interface. The argument is required but is currently not evaluated — see MAIN*WEBSOCKETPORT for the port the stream runs on.
SERVICES
Services set up on the Tracking Hub machine (SERVICES*):
SERVICES*COUNT GET = <zero-based index>
SERVICES*BY_INDEX*<idx> GET = <xml>
                        START
                        STOP
SERVICES*BY_INDEX*<idx>*SLOTINDEX GET = <slotindex>
                                  SET <slotindex>
SERVICES*BY_INDEX*<idx>*RUNNING GET = <bool>
SERVICES*BY_ID*<service_id> GET = <xml>
                            START
                            STOP
SERVICES*BY_ID*<service_id>*SLOTINDEX GET = <slotindex>
                                      SET <slotindex>
SERVICES*BY_ID*<service_id>*RUNNING GET = <bool>
SERVICES ADD PARAMETER ALL                         <ip> <port> = <service_id>
SERVICES ADD PARAMETER             <lattice_name>  <ip> <port> = <service_id>
SERVICES ADD TRACKING_TIMING       <ts_name>       <ip> <port> = <service_id>
SERVICES ADD COMMUNICATION_TIMING  <service_id>    <ip> <port> = <service_id>
SERVICES ADD CAMERA                <lattice_name>  <ip> <port> <cameranumber> = <service_id>
SERVICES ADD OBJECT                <lattice_name>  <ip> <port> = <service_id>
SERVICES ADD TIMECODE              <timcode>       <ip> <port> = <service_id>
SERVICES REPLACE <service_id> (TRACKING_TIMING|COMMUNICATION_TIMING) (<ts_name>|<service_id>)    <ip> <port>                = <service_id>
SERVICES REPLACE <service_id> (PARAMETER|OBJECT|TIMCODE)             (<lattice_name>|<timcode>)  <ip> <port>                = <service_id>
SERVICES REPLACE <service_id> CAMERA                                  <lattice_name>             <ip> <port> <cameranumber> = <service_id>
SERVICES REMOVE <service_id>
SERVICES REMOVE_ADDR <ip>
SERVICES REMOVE_ALL
SERVICES ADD STATE <objectname> <ip> <port> = <service_id>
SERVICES ADD TRFLOW <objectname> <ip> <port> = <service_id>
SERVICES ADD TRFLOWRAW <objectname> <ip> <port> = <service_id>
SERVICES ADD MULTIOBJECT <lattice_name> <ip> <port> <cameranumber> = <service_id>
SERVICES ADD MOCAP <lattice_name> <ip> <port> <cameranumber> = <service_id>
SERVICES ADD VIDEOWALL <lattice_name> <ip> <port> <cameranumber> = <service_id>
SERVICES ADD TCCAMERA <lattice_name> <ip> <port> <cameranumber> = <service_id>
SERVICES ADD NDI <lattice_name> <ip> <port> <cameranumber> = <service_id>
SERVICES ADD TARGET <lattice_name> <ip> <port> = <service_id>
SERVICES ADD TARGET <lattice_name> <ip> <port> <mapprefix> = <service_id>
The second form sets the shared memory map prefix.
The following properties are addressed as SERVICES*BY_ID*<service_id>*<property>.
*NAME SET <string>
GET = <string>
GET = <netuse>
*COMPORT SET <name>
GET = <name>
*BAUD SET <baud>
GET = <baud>
*PARITY SET <int>
GET = <int>
*STOPBITS SET <int>
GET = <int>
*DATASIZE SET <int>
GET = <int>
*UDPPORT SET <port>
GET = <port>
*TCPROTOCOL SET <protocolname>
Timecode protocol of the service.
*ADDITIONALDELAY SET <float>
GET = <float>
Delay added on top of the rig delay, in fields.
*LUTFILE SET <string>
GET = <string>
Look-up table used by the service.
*WALLGROUP SET <int>
GET = <int>
Video wall group the service belongs to.
*USECANBUS SET <0|1>
GET = <0|1>
*TOGGLECS SET <0|1>
GET = <0|1>
Center shift toggle.
*NDI_SOURCE SET <string>
NDI stream the service sends into.
GET = <0|1>
Receive Compressed, on by default.
GET = <0|1>
Use AVsync, off by default.
GET = <0|1|2>
What the service paces its output on: 0 VIZ, 1 NDI, 2 NDI av. The default is 2.
*NDIQS SET <int>
GET = <int>
NDI queue size, which shifts the delay of the whole NDI signal.
A service can carry several rig/camera pairs. These commands manage them, addressed as SERVICES*BY_ID*<service_id>.
ADD <slot> <lattice_name> <cameranumber>
Adds a rig/camera pair to the service.
DELETE <slot> <lattice_name> <cameranumber>
Removes a rig/camera pair.
CHANGEOBJ <slot> <lattice_name> <cameranumber>
Replaces the rig of a pair.
CHANGECAM <slot> <lattice_name> <cameranumber>
Replaces the camera number of a pair.
EXTSTART
EXTSTOP
Start and stop the service externally. Also available under SERVICES*BY_INDEX*<idx>.
ROUTERS
Configure routers controlled by Tracking Hub (ROUTERS*):
List Available Router Models
ROUTERS*MODEL_LIST GET = <model>[,<model>]*
Manage Routers
ROUTERS ADD <model> <name> = <index>
ROUTERS REMOVE <name> | <index>
ROUTERS*COUNT GET = <count>
Configure Individual Routers
ROUTERS*<idx/name> GET = <xml>
ROUTERS*<idx/name>*INDEX GET = <index>
ROUTERS*<idx/name>*NAME SET <string>
                        GET = <string>
ROUTERS*<idx/name>*MODEL SET <model>
                         GET = <model>
ROUTERS*<idx/name>*AB_MODE SET <mode>
                           GET = <mode>
ROUTERS*<idx/name>*NETUSE SET <netuse>
                          GET = <netuse>
ROUTERS*<idx/name>*COMPORT SET <name>
                           GET = <name>
ROUTERS*<idx/name>*BAUDRATE SET <baud>
                            GET = <baud>
ROUTERS*<idx/name>*PARITY SET <baud>
                          GET = <baud>
ROUTERS*<idx/name>*STOPBITS SET <baud>
                            GET = <baud>
ROUTERS*<idx/name>*DATASIZE SET <baud>
                            GET = <baud>
ROUTERS*<idx/name>*HOST SET <ip>
                        GET = <ip>
ROUTERS*<idx/name>*PORT SET <port>
                        GET = <port>
ROUTERS*<idx/name> CONNECT
ROUTERS*<idx/name> DISCONNECT
ROUTERS*<idx/name>*CONNECTED GET = <boolean>
ROUTERS*<idx/name>*INPUTS*<idx>*NAME SET <string>
                                     GET = <string>
ROUTERS*<idx/name>*OUTPUTS*<idx>*NAME SET <string>
                                      GET = <string>
ROUTERS*<idx/name>*CURRENT_PRESET SET <string>
                                  GET = <string>
Configure Presets of Individual Routers
ROUTERS*<idx/name>*PRESETS CREATE <name> = <index>
ROUTERS*<idx/name>*PRESETS DELETE <name>|<index>
ROUTERS*<idx/name>*PRESETS*COUNT GET = <count>
ROUTERS*<idx/name>*PRESETS*<idx/name> GET = <xml>
ROUTERS*<idx/name>*PRESETS*<idx/name>*NAME SET <string>
                                           GET = <string>
ROUTERS*<idx/name>*PRESETS*<idx/name> CONNECT <input-index> <output-index>
ROUTERS*<idx/name>*PRESETS*<idx/name> DISCONNECT <input-index> <output-index>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS ADD <ip> <port> <cameranumber> = <index>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS REMOVE <index>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS*COUNT GET = <int>
ROUTERS*<idx/name>*PRESETS*<idx/name>*CAMERAS*<idx> GET = <xml>
ROUTERS*<idx/name>*PRESETS*<idx/name>*GPIIO ADD <devicename> <port> <pin> <pressed>
                                            GET  = <devicename> <port> <pin> <pressed>
ROUTERS*<idx/name>*PRESETS*<idx/name>*GPIIO REMOVE
ROUTERS*<idx/name>*MANUAL_CONTROL GET = <xml>
ROUTERS*<idx/name>*MANUAL_CONTROL*ENABLED SET <boolean>
                                          GET = <boolean>
ROUTERS*<idx/name>*MANUAL_CONTROL CONNECT <input> <output>
ROUTERS*<idx/name>*MANUAL_CONTROL DISCONNECT <input> <output>
ROUTERS*<idx/name>*IMAGE_MODE SET <0|1|2|3>
GET = <0|1|2|3>
Image mode of the router: 0 off, 1 foreground, 2 background, 3 DVE. A value outside this range is read back as 0 when the configuration is loaded.
ROUTERS*<idx/name>*DEPLUGIN SET <int>
GET = <int>
Delays per Router
ROUTERS*<idx/name>*PRESET_DELAY SET <double>
                                GET = <double>
ROUTERS*<idx/name>*ENGINE_DELAY SET <double>
                                GET = <double>
GPIIO
GPIIO used on the Tracking Hub machine (gpiio).
GPIIO*COUNT GET = <count>
GPIIO*MONITOR START
GPIIO*MONITOR STOP
GPIIO*MONITOR GET = <boolean>
GPIIO*<idx/name> GET = <devicename> <count inputports> <count outputports>
GPIIO*<idx/name>*INDEX GET = <index>
GPIIO*<idx/<name>*NAME GET = <string>
Notifications (only sent from Tracking Hub) if gpi triggered when monitoring is on
GPIIO*MONITOR PRESSED  <devicename> <port> <pin>
GPIIO*MONITOR RELEASED <devicename> <port> <pin>
GPIIO NEW <devicename> <count inputports> <count outputports>
Registers a GPI IO device that has been found. Tracking Hub adds it to its device list and re-checks the router configuration for presets bound to that device.
GPIIO CHANGE <devicename> <port> <state>
Sets the input state of one port of a device.
GPIIO TEST START
GPIIO TEST STOP
Starts and stops the Sealevel 410 worker, for checking a connected device.
POST
Setup of the Tracking Hub post system.
Set the Timecode Sources for Live and Post
POST*LIVE_SOURCE SET  <string>
                 GET = <string>
POST*POST_SOURCE SET <string>
                 GET = <string>
POST*TIMECODE_SOURCES GET <string>[,<string>]*
POST*SIM_LIVE SET <int>
Sets the simulated live timecode. SimLive and SimPost allow tracking data to be recorded without a timecode reader card. For analysis only — never use them for production recording.
POST*SIM_POST SET <int>
Sets the simulated post timecode.
POST*SIM_POST_INCREMENT SET <float>
Sets the rate at which the simulated post timecode advances.
POST*DEBUG SET <int>
Sets the timecode debug level.
Session Commands
POST*SESSION CREATE <string>(create a new session)
             START (starts recording)
             STOP (stops recording)
             GET_LIST = <string>[,<string>]
             LOAD <string>
             DELETE <string>
             INFO_GET = <string>;[,<string>]*
POST*SESSION CLOSE
Closes the loaded session.
POST*SESSION STATUS_GET = <string>
State of the current session.
POST*SESSION GET_CAMERA_CHANNELS = <string>
Camera channels of the loaded session. These are the channels that can be assigned to a camera service — see Post System, Camera Channels.
Notifications
Loading saved session file progress as a percentage FILE_PROGRESS <float>. Loading of saved session file is complete FILE_FINISH.
Recording and Replay Commands
POST*PARAMETER_RECORDING GET <Parameter Name> = 1 (recording on) | 0 (recording off)
                         SET <Parameter Name> <0|1>
POST*PARAMETER_REPLAY GET <Parameter Name> = 1 (replay on) | 0 (replay off)
                      GET_DELAY <Parameter Name> = <float>
                      SET_DELAY <float>
TRACKING_SYSTEMS*<name>*RECORDING GET = 1 (recording on) | 0 (recording off)
                                  SET <0|1>
TRACKING_SYSTEMS*<name>*REPLAY GET = 1 (replay on) | 0 (replay off)
                               SET <0|1>
TRACKING_SYSTEMS*<index>*RECORDING GET = 1 (recording on) | 0 (recording off)
                                  SET <0|1>
TRACKING_SYSTEMS*<index>*REPLAY GET = 1 (replay on) | 0 (replay off)
                                SET <0|1>
TRACKING_SYSTEMS*<name>*REPLAY GET_DELAY = <float>
                               SET_DELAY <float>
TRACKING_SYSTEMS*<index>*REPLAY GET_DELAY = <float>
                                SET_DELAY <float>
SERVICES*RECORDING GET <service id> = 1 (recording on) | 0 (recording off)
                   SET <service id> <0|1>
SERVICES*REPLAY GET <service id> = 1 (replay on) | 0 (replay off)
SERVICES*REPLAY GET_DELAY <service id> = <float>
SERVICES*REPLAY SET_DELAY <service id> <delay>
LENSFILE
Lensfile, load, save and change on the Tracking Hub machine (LENSFILE*).
LENSFILE*LOGIN <pwd> = <xml_lensfile> ??? correct error handling ???
LENSFILE*NEW
LENSFILE*LOCK <service_id> = <LockID>
LENSFILE*UNLOCK <LockID >
LENSFILE*XML_GET <LockID > = <xml_lenfsile>
LENSFILE*SELECT <lensfilename> =  lenfile (binary) loaded for edit
LENSFILE*SAVE <LockID,>
LENSFILE*SAVEAS <LockID, name>
LENSFILE*GROUP SELECT <LockID  parameter>
LENSFILE*GROUP NEW <LockID  parameter>
LENSFILE*GROUP ADD < LockID , parameter >
LENSFILE*GROUP DELETE < LockID , parameter>
LENSFILE*GROUP PARAMETERMOVE <LockID , parameter groupID >
LENSFILE*GROUP PARAMETERMOVE <LockID , parameter >   //move into a new group
LENSFILE*PARAMETER<parameter>VALUEADD< LockID , zoom,focus >
LENSFILE*PARAMETER<parameter>VALUEDEL< LockID , zoom,focus >
LENSFILE*PARAMETER<parameter>VALUECHANGE< LockID , zoom,focus,newvalue>
LENSFILE*ACTIVE GET = all active services
LENSFILE*PROXY SEND<LockID,string>
LENSFILE*PROXY REQ < LockID string> = <answer>
LENSFILE*PARAMETER<parameter>GET_TRIANGULATION< LockID > = <string>
Triangulation data of the parameter in the locked lens file.
LENSFILE*PARAMETER<parameter>GET_SAMPLES< LockID > = <string>
Sample points of the parameter in the locked lens file.
LENSFILE*PARAMETER<parameter>SET_INTERPOLATION< LockID , interpolation >
Interpolation used for the parameter. Accepted values are linear, linearmix and precalc.
All three require the lens file to be locked. If the LockID is unknown, the answer is “Lensfile is not locked”.
