Template Builder User Guide
Version 2.0 | Published July 26, 2021 ©
Editing Template Layout
Editing a template's layout makes it easy to create fill-in forms for journalist. With drag & drop functionality, creating new fill-in forms is quick and easy.
Adding tabs enables you to quickly create fill-in forms based on selected fields or start with an empty space where you can add your chosen field types.
The All tab gives you access to the classic form that contains all of the template's field types.
Resize, move, edit, add and delete fields quickly.
Follow the steps below to get started.
Accessing Layout Editing
Open or create a new template and add a scene.
Click Fill-in form:
The default view is then displayed:
Creating a Template
Selecting Fields and Creating a New Tab
To create a new form for journalists to work with, select fields and click the Create New Tab button:
Enter a new for your new tab and click OK:
In the example in above, Selected is marked as the fields have already been selected. Click OK. All of the previously selected fields are now shown:
Creating a Second Tab
You can use the layout editor to drag and drop, resize and reposition elements in the form. This can be a quick way of doing things if you're only using a few fields.
Click the Create Tab button (or ALT +T).
Enter a name for the tab. Select None and click OK:
Adding, Moving, and Resizing Fields
Use drag and drop to add fields:
You can then use your cursor to resize and move the elements around:
You can also create a new tab and click Select All:
This tab then contains all the fields, and is quite similar to the default view:
Deleting Tabs
When you're happy with your design, you can Delete the tabs that you don't want to use, right-click on the tab:
Hiding and Showing Tabs
You can then decide what should be visible to the journalist. All with a line through the eye icon indicates that a tab is hidden:
Make a tab visible by clicking the breadcrumbs beside New Template at the top of the screen:
Deselect Hide generated view and click Close:
Voilà:
Creating a Drop-down Menu
Give the journalist more options to choose from. Click Data entry at the bottom left of the screen. Select Choose from list:
Enter a Name in the menu:
Double-click the Value field:
Edit the Value box:
Right click in the menu and select Insert row below, to create more rows in the same way:
Changing the Image
Click the circle icon to open a menu to search for a different image:
Select an image and click OK:
Image Constraints
Specify standards for image quality and size using either or both of the following:
Minimum size of the image (pixels): number of pixels, irrespective of aspect ratio.
Aspect ratio: minimum width and height.
Note: A warning is shown if the image becomes smaller than the minimum permitted.
Saving a Template
Click the Disk icon (or shortcut CTRL + S) to save:
Enter a template name and click Save:
