Template Builder User Guide
Version 1.3 | Published July 26, 2021 ©
Setup and Configuration
Opening Template Builder
Template Builder opens as a web application in your default browser.
The URL to access Template Builder, if hosted on the Pilot Data Server, is: http://pds-hostname:8177/app/templatebuilder/TemplateBuilder.html
Using Mist
It's recommended to install Mist and let that serve out all the products, for example in order to simplify resource sharing with Viz Pilot Edge and Viz Story or to provide HTTPS support.
The URL to access Template Builder if served out by Mist is: http://hostname/templatebuilder/
Configuring Preview Server
Preview Server manages one or more Viz Engines, providing frames for thumbnails and snapshots in an ongoing preview process.
Preview Server must be configured in the Pilot Data Server:
Access the Pilot Data Server Web Interface: http://pds-hostname:8177
Click the Settings link
Select the preview_server_uri setting, and add the URL for the machine on which you installed the Preview Server (ie. http://previewserver-hostname:21098)
Click Save
Note: All applications with a connection to the database will now have access to Preview Server.
Specifying a Graphic Hub Endpoint
If you're using multiple Graphic Hubs, the one used to store your scenes must be configured in the Pilot Data Server:
Select the graphic_hub_url setting, and add the URL for the machine on which your scenes are stored (ie. http://gh-hostname:19398)
Click Save
Monitoring Graphic Hub Status
Since some users have multiple Graphic Hubs (GHs) for design, distribution, testing and production, green icons at the bottom of the interface show you which GH and which database you're currently connected to:
Note: GH REST status info is based on the graphic_hub_url parameter mentioned above - not Graphic Hub's search provider settings.
