Template Builder User Guide
Version 1.0 | Published August 10, 2017 ©
The Fill In Form
The window placed in the middle in the Template Builder is the auto generated fill in form for the graphics. It displays editable fields that are given the appropriate control plugins by the designer in Viz Artist where the user can add content to the graphic. What type of content that are allowed in the fields are controlled in the Template Builder Window. Fields can be restricted to contain e.g. only text with a certain amount of characters, numbers within a specific range, media placeholders for media assets, or it can be a set of choices in a drop-down list.
As long as the fields in the Fill In Form are exposed controls made by the designer the added content will be shown in the Preview Window .
At the top of the Fill In Form there are three options Edit all, Show all and Refresh HTML panels.
Edit all is an option to edit all fields in the Fill In Form. This is to provide a way to edit default values of fields that are set to read-only.
Selecting Show all displays all fields in the Fill In Form, even if the fields are set in hidden mode.
Selecting Refresh HTML panels will reload the HTML panel(s) in the Fill In Form.
