Version 2.1 | Published July 20, 2021 ©
Persistence Configuration
It is possible to have the configuration and recordings persist through service restart or crash. This feature is controlled by the following configuration:
With persistence configuration enabled:
During startup, if a backup file does not already exist, one is created containing the parameters of the current configuration.
A new back up file is created every time there is a change in the runtime configuration.
The changes in the runtime configuration can come from commands or NMOS requests.
If there is a crash or the service is stopped, next time the service is started, the back up file is used instead of the usual configuration file.
The back up file is located in %ProgramData%\vizrt\ServiceHost\.
The back up file name contains a timestamp which indicates when it was created (e.g. VizrtCRTest_20200909152851194.xml).
Since the back up file is used as configuration it is not possible to change some of the configuration via GUI anymore.
To disable persistence you can still use the GUI. The GUI can still be used to configure the connector and output.
Note: For IP workflow this feature can replace the auto-recovery option found in Viz Engine.
