Channel Recorder Control Commands
The application Viz Send, included in Viz Artist installation, can be used to communicate with Channel Recorder. Connect the tool to the port specified in the configuration file. The following commands are implemented in the service:
ABOUT
Command |
Description |
ABOUT GET |
Prints license information of all libraries used in this software. |
MAIN
Some of the following commands must be called during initialization. To configure these commands, use the configuration web interface and the restart the service. Refer to Channel Recorder Configuration for more information.
Command |
Description |
MAIN VERSION |
Returns Channel Recorder version. |
GET VERSION |
Returns Channel Recorder version. Same as MAIN VERSION. |
MAIN HOSTNAME |
Returns system hostname. |
MAIN SVCNAME |
Returns Service Host version. |
MAIN BOARD LIST |
Lists all available boards. |
MAIN BOARD SELECT [serial number] |
Selects a board. The board is identified by the serial number. If the board with the given number is not found, the first board is selected. |
MAIN BOARD GET |
Returns the selected board. |
MAIN CONNECTOR SELECT |
Selects a connector. Connectors are labeled consecutively from A to P or numerically from 1 to 32. Numerical value is needed for addressing all inputs in a 2110 capable board. This command can also be used to restart the channel without using the web interface. |
MAIN CONNECTOR GET |
Returns the selected connector. |
MAIN LICENSES |
Returns the state of the licenses defined at configuration. An example output is: Example "Service Host Core" ENG_SVCHOST_CORE 1200004 300 7 1 VL_GRACE_LICENSED VL_SHARED 0 1540987200 0 0 license-server.vizrt.internal Each line is one license and each row separated by space is:
MAIN CRASH [type] |
Crashes the service. [type] can either be omitted or be one of:
OUTPUT
One output target can be initialized during startup. During execution more than one output can be enabled. For instance you can have VideoOut A and Coder enabled. Please refer to Channel Recorder Configuration to initialize an output during startup.
Command |
Description |
OUTPUT GET |
Lists the active targets. |
OUTPUT LIST |
Lists available targets. |
OUTPUT START [target] |
Starts an output handler for the specified [target]. Several output handlers can be started in parallel, but only one is allowed for each target. Valid targets are:
Example: OUTPUT START VideoOut A
Example: OUTPUT START Coder SHMCoder1 localhost 12345 |
OUTPUT STOP [target] |
Stops the output handler for the specified target. |
RECORD
Crash Recording / One-time Scheduling
These are specific commands used only for crash and one-time scheduling of recording. These command are available from version 1.0. For scheduling, it is recommended to use RECORD SET introduced from version 1.1.
Command |
Description |
RECORD CLIP [clip name] |
Sets the clip name and initializes the recorder. This command does not start recording (see RECORD START ). |
RECORD START [duration] [start time] [end mode] |
Starts or continues recording. The [duration], [start time], and [end mode] parameters are optional. However, the parameters are interdependent as follows:
The format for both is Timecode (see Data Types).
RECORD PAUSE |
Pauses recording. |
RECORD STOP [end time] |
Stops recording and flushes the recorder. A new clip needs to be set afterwards (see RECORD CLIP ). The end time is optional and specifies the timecode when the recording should end. |
Example: Crash recording:
RECORD CLIP Crash.mxf
RECORD START
RECORD STOP
One-time scheduling recording:
RECORD START 600 15:00:00:00
Loop Recording
These are specific commands used only for loop recording. It allows setup, start or stop loop recording. These are introduced from version 1.1.
Command |
Description |
RECORD LOOP [key=value] ... [key=value] [operation] |
Starts, stops or configures the settings for loop recording. Any number of properties can be applied in the form of key-value-pairs. If no property is supplied, and the entry does not yet exist, it is added with the default values. Available keys are:
[operation] can be START or STOP. When no [operation] is specified then only the settings are set for the specified key-value-pairs. It is possible to specify [key=value] [operation] at the same time but only when [operation] is START. Example: RECORD LOOP LENGTH=00:05:00:00 CHUNK=00:00:30:00 PREFIX=Loopy START |
Scheduled Recording
These are specific commands used only for scheduled recording. It allows setup, start or stop scheduled recording.
Command |
Description |
RECORD SET [name] [key=value] ... [key=value] |
Adds a new clip to the timeline, or changes a property of an entry defined by [name]. Any number of properties can be applied in the form of key-value-pairs. If no property is supplied, and the entry does not yet exist, it is added with the default values. Available keys are:
For more information regarding these settings possible values and default values check the section CONFIG SET below. |
RECORD REMOVE [name] ... [name] |
Removes the entry [name] . Multiple [name] arguments can be provided. |
RECORD GET [name] | [key] ... [name] | [key] |
Lists all entries or shows the properties of an entry. If no parameter is applied, a list of all scheduled clips is returned. Any number of [name] and [key] can be applied. The values of all keys are returned for all values. If no [key] is provided, all values of the applied keys are returned and vice versa. This means that if you call RECORD GET with clip names only, the command returns all properties of these clips. When called with properties only, it returns this property for all clips. A special [key] is TIMELINE , which returns all entries in the timeline. |
Common Record Commands
Some of these commands are only used for loop and crash recording, while others are used for all three modes.
Command |
Description |
RECORD DURATION |
If no duration parameter is applied to the command, it returns the timecode relative to the start timecode. If a duration parameter is applied, the duration of an ongoing recording is changed. The duration parameter can be specified as either a number of frames or a timecode (see Data Types ). In the case of loop and schedule recording the value used to set using this command is ignored. |
RECORD RESOLUTION GET |
Returns the resolution the Channel Recorder is running at. |
RECORD STATE |
Returns the state the Record Channel service is in. By default state is idle. State is only invalid when the clip was configured incorrectly (e.g. container / codec combination is wrong). State flow: Idle -- Start() --> Recording -- Stop() --> Paused |
RECORD STARTTC [starttc] |
Defines which start timecode to use for the recording. If the command is not called before the recording starts, the current timecode is written to the clip. If no value is given, the command returns the current value. This is only used for loop and schedule recording. |
CONFIG
Command |
Description |
CONFIG GET |
Gets the current settings. |
CONFIG LIST [argument] |
Lists all available variables. The optional [argument] flag provides information specific to the applied argument. Known arguments are:
CONFIG SET [variable] [value] |
Sets the [variable] to [value] . To get all available variables, call CONFIG LIST . Refer also to variables and values for CONFIG SET below . |
CONFIG SET
Variable and values for CONFIG SET command. The CONFIG SET command is used to set the configuration globally, this means that all the recording mode uses these settings by default unless specified otherwise. Only schedule recording can specify different settings for each schedule by specifying them via RECORD SET command.
IPIN
Variable |
Value |
IPIN SDIIP ADDRESS [address] |
Destination IPv4 address. The default value is 239.0.10.10. |
IPIN SDIIP PORT [port] |
Destination port. The default value is 50002. |
IPIN SDIIP PACKETINTERVALTHRESHOLD [threshold] |
Indicates the threshold for generating the time interval between the IP packets alarm on the main IP stream. The range is from 6.4 nanoseconds to 419424.0 nanoseconds in intervals of 6.4 nanoseconds. The default value is 6.4. |
IPIN SDIIP JOINTYPE [type] |
Indicates the type of membership request made when IPv4 address is a multicast address. Valid values for [type] are:
The default value is None. |
IPIN IPGENERAL REDUNDANCY [bool] |
Enable redundancy flows. |
IPIN IPGENERAL JOINTYPE [type] |
IPIN IPVIDEO [ bool] |
Enables video flow if True. |
IPIN IPVIDEO ADDRESS [address] |
Sets destination IPv4 address. The default value is 239.0.10.10. |
IPIN IPVIDEO PORT [port] |
Sets destination port. The default value is 50002. |
IPIN IPVIDEO RTPPAYLOADID [id] |
Indicates the RTP (Real-time Transfer Protocol) Payload ID to capture. Used when RTP Payload ID is set to True. The default value is 96. |
IPIN IPVIDEO PACKETINTERVALTHRESHOLD [threshold] |
Indicates the threshold for generating the time interval between the IP packets alarm on the main IP stream. For video, the range is from 6.4 nanoseconds to 419424.0 nanoseconds in intervals of 6.4 nanoseconds. The default value is 6.4. |
IPIN IPVIDEO FILTERTYPE [type] |
Specifies the type of filtering applied to the source list when IGMPv3 is used. Valid values for [type] are:
The default value is 1. |
IPIN IPVIDEO IGMPV3 FILTERLIST [list] |
Lists IPv4 addresses to be included or excluded separated by a space character. |
IPIN IPVIDEO_S ADDRESS [address] |
Destination IPv4 address. The default value is 239.1.10.10. |
IPIN IPVIDEO_S PORT [port] |
IPIN IPVIDEO_S PACKETINTERVALTHRESHOLD [threshold] |
IPIN IPVIDEO_S IGMPV3 FILTERTYPE [type] |
IPIN IPVIDEO_S IGMPV3 FILTERLIST [list] |
IPIN IPAUDIO [bool] |
Enables audio flow if True. |
IPIN IPAUDIO ADDRESS [address] |
Destination IPv4 address. The default value is 239.0.10.12. |
IPIN IPAUDIO PORT [port] |
Destination port. The default value is 50004. |
IPIN IPAUDIO RTPPAYLOADID [id] |
Indicates the RTP (Real-time Transfer Protocol) Payload ID to capture. Used when RTP Payload ID is set to True. The default value is 97. |
IPIN IPAUDIO PACKETINTERVALTHRESHOLD [threshold] |
Indicates the threshold for generating the time interval between the IP packets alarm on the main IP stream. For audio, the range is from 102.4 nanoseconds to 6710681.6 nanoseconds in intervals of 102.4 nanoseconds. The default value is 102.4. |
IPIN IPAUDIO FILTERTYPE [type] |
IPIN IPAUDIO FILTERLIST [list] |
IPIN IPAUDIO USETRACKCOUNT [bool] |
Uses track count to specify the number of tracks for the incoming IP stream if True. The default value is False. |
IPIN IPAUDIO TRACKCOUNT [count] |
Specifies the number of tracks for the incoming IP stream. Valid values for [count] are:
The default value is 8. |
IPIN IPAUDIO PACKETDURATION [duration] |
Indicates the duration of the incoming audio packet. The packet size (in samples) can be computed using the sample rate (48000 samples/sec) and the packet duration. Valid values for [duration] are:
The default value is 3. |
IPIN IPAUDIO_S ADDRESS [address] |
Destination IPv4 address. The default value is 239.1.10.12. |
IPIN IPAUDIO_S PORT [port] |
IPIN IPAUDIO_S PACKETINTERVALTHRESHOLD [threshold] |
IPIN IPAUDIO_S IGMPV3 FILTERTYPE [type] |
IPIN IPAUDIO_S IGMPV3 FILTERLIST [list] |
IPIN IPANC [bool] |
Enables ANC flow if True . |
IPIN IPANC ADDRESS [address] |
Destination IPv4 address. The default value is 239.0.10.14. |
IPIN IPANC PORT [port] |
Destination port. The default value is 50006. |
IPIN IPANC RTPPAYLOADID [id] |
Indicates the RTP (Real-time Transfer Protocol) Payload ID to capture. Used when RTP Payload ID is set to true. The default value is 100. |
IPIN IPANC PACKETINTERVALTHRESHOLD [threshold] |
Indicates the threshold for generating the time interval between the IP packets alarm on the main IP stream. For ancillary data, the range is from 819.2 nanoseconds to 53685452.8 nanoseconds in intervals of 819.2 nanoseconds. The default value is 819.2. |
IPIN IPANC FILTERTYPE [type] |
IPIN IPANC FILTERLIST [list of ips] |
List of IPv4 addresses to be included or excluded separated by a space character. |
IPIN IPANC_S ADDRESS [address] |
Destination IPv4 address. The default value is 239.1.10.14. |
IPIN IPANC_S PORT [port] |
IPIN IPANC_S PACKETINTERVALTHRESHOLD [threshold] |
IPIN IPANC_S IGMPV3 FILTERTYPE [type] |
IPIN IPANC_S IGMPV3 FILTERLIST [list] |
SFP
[sfp] can be A or B and it refers to the SFP cage.
Note: These parameters are board-wide, meaning that any change done affects any other instances of any application that is using the board. The values for these parameters should be the same for every instance of Channel Recorder that is using the board.
Variable |
Value |
SFP [sfp] ADDRESS [ip] |
Sets IPv4 address. The default value is 10.0.0.3. |
SFP [sfp] GATEWAY [ip] |
Sets IPv4 gateway. The default value is 10.0.0.1. |
SFP [sfp] NETMASK [ip] |
Sets IPv4 netmask. The default value is 255.255.255.0. |
SFP [sfp] DHCP [bool] |
Enable DHCP protocol. |
SFP [sfp] TOSDSCP [number] |
Specifies a datagram's priority and request a route for low-delay, high-throughput, or highly-reliable service. The default value is 0. |
SFP [sfp] DELAYMECHANISM [mechanism] |
Specifies the type of network delay mechanism to use for the time server connection. Valid values for [mechanism] are:
The default value is End-to-End. |
SFP [sfp] IPMODE [mode] |
Specifies the type of internet protocol mode to use for the time server connection. Valid values for [mode] are:
The default value is Multicast. |
SFP [sfp] MASTERCLOCKDOMAINNUMBER [number] |
Specifies the master clock domain number. The default value is 127. |
SFP [sfp] ANNOUNCERECEIPTTIME [number] |
Specifies the announce receipt time. |
SFP [sfp] JOINTYPE [type] |
SFP [sfp] FILTERTYPE [type] |
SFP [sfp] FILTERLIST [list of ips] |
2059
Variable |
Value |
2059 BESTMASTERSELECTION |
Specifies the BMCA (Best Master Cock Algorithm) used to select the genlock over IP signal. |
PROCESS
Variable |
Value |
PRIORITY [priority] |
Sets the process priority class. The values correspond to the Windows process priority. Valid values for [priority] are:
The default value is REALTIME. |
CAPTURE
All the configuration below requires a channel restart. This can be achieved by restarting the service or by calling MAIN CONNECTOR SELECT while Channel Recorder is running.
Variable |
Value |
CLIP_ROOT [path] |
Sets the root folder for the captured files. If the filename in command RECORD CLIP does not contain a absolute path name, the CLIP_ROOT is prepended. |
UHD [bool] |
Enables detection of UHDTV signals. When set to On, the Channel Recorder scans the signal resolution on the four corresponding input connectors. If four 3G signals are detected, they are interpreted as one UHDTV signal. When set to OFF, the four connectors are treated as separate 3G signals. This flag must be set before selecting a connector using MAIN CONNECTOR SELECT . The default value is Off. |
V210 [bool] |
Uses the 10-bit surface format V210. This is needed to record XAVC. It also increases performance when for example recording ProRes. This surface format is not supported on the Matrox X.mio2+. This flag must be set before selecting a connector using MAIN CONNECTOR SELECT . The default value is Off. |
COLORIMETRY |
Specifies the colorimetry to be used to be able to record in HDR. By default, ITUR_BT_601 is used for SD resolution and ITUR_BT_709 for HD and UHD resolution. |
VBI [bool] |
Turns off VBI recording. The default value is On. This flag must be set before selecting a connector using MAIN CONNECTOR SELECT. |
RESOLUTION [resolution] |
Sets the default resolution. Format of [resolution] is:
M is optional, and as an alternative, you can use framerate with two decimal points (e.g. 30M = 29.97). The default value is NTSC. |
SDASPECTRATIO [type] |
Specifies the aspect ratio for SD resolution. Available sources are:
ALIASNODESOURCE [type] |
Specifies the input source of an alias node. Available sources are:
RESTARTINGDELAY [delay] |
Specifies the time in milliseconds before the channel is restarted after detecting a change in resolution. |
RESTARTING [bool] |
Enable or disable restarting after detecting a change in resolution. |
RESOLUTIONDETECTION [bool] |
Enable or disable resolution detection. |
ALIASNODESOURCE [source] |
Specifies the source of the alias node which specify from which output or input connector the application records. |
TEST
Variable |
Value |
PERFORMANCETESTMODE [mode] |
Sets the number of audio channels to record. How many channels are actually recorded depends on the codec and the input signal. |
MANAGER
Variable |
Value |
RINGBUFFERSIZE [size] |
Sets the size of the capture ring buffer. The default value is 60. |
TIMEOUT [timecode] |
Sets the timeout for the capture operation in milliseconds. If the recorder reports timeout errors, increasing the timeout could help. Refer to Data Types for information on time code formatting. |
PERSISTENCE
Variable |
Value |
PERSISTENCE [bool] |
Turns on persistence for operational data like the config and the timeline. Network changes done by NMOS will persist through service restarts. The default value is Off. |
PERSISTENCEINTERVAL [seconds] |
Sets the interval, at which the data is written to the disk. The value is in seconds and fractions of seconds, meaning both 0.1 and 1.0 are considered valid values. A value of 0 means that every change is written. |
SCHEDULER
Variable |
Value |
WRITERSCOUNT [number] |
Sets the number of writers to initialize. More writers cause more memory usage. This flag must be set before selecting a connector |
TRIGGERTHRESHOLD [frames|timecode] |
If a timed command missed the execution time, but is still within the trigger threshold, it will be executed (late). Outside of this window it will just be ignored until the next time the timecode is received. The value can either be a number of frames or a timecode based relative value. The default value is 5 frames. |
TIMECODESOURCE [source] |
Specifies the timecode source. Available sources are:
INCLUSIVEOUT [bool] |
When enabled the last timecode written to the file is the defined out point of the recording. The default value is NO/FALSE/OFF. |
DISCONTINUOUSTC [bool] |
When enabled each field / frame will use the timecode calculated from the system time in case of TIME_OF_DAY and ATC/VITC / ATC/LTC embedded in the fields / frames if this is chosen as timecode source. This option is useful to support DST (Daylight Saving Time) or when the input's timecode is expected to have gaps and this must be kept in the recorded file. StartTC will not work when this is enabled. The default value is NO/FALSE/OFF. |
LOG
Variable |
Value |
TCLOGINTERVAL [frames|timecode] |
Specifies the interval at which the current timecode is logged. The value can either be a number of frames or a timecode-based relative value. The default value is 0, which means that every full second is logged. |
CLIP
For the following parameters to take effect Channel Recorder does not need to be restarted, however, a new recording must be issued.
Variable |
Value |
FILE_EXTENSION [bool] |
Enables or disables automatically adding a file extension to the file name. If this feature is turned off, the client application has full control over the file name. The default value is On. Please refer to Data Types for details on accepted boolean values. |
CONTAINER [container type] |
Sets the container type of the recorded file. With the container type, a default codec is also set. By setting the container type, a valid recording can be started. Available container types are:
Note: To utilize the TDIR capabilities of the ProRes codec with a .mov container in Viz Engine, you must use the .Ref-file Note: When container is XDCAMMXF, the default codec is XDCam which is HD422. The default bitrate for XDCam, XDCamEX and XDCamHD are 50, 35 and 35 or 25 respectively. XDCamEX outputs 1920x1080 clip at 35 Mbps and XDCamHD outputs 1440x1080 clip at 35 Mbps (VBR) or 25 Mbps (CBR) depending on the bitrate chosen. Refer to the Supported Codecs for further details. |
CODEC [codec type] |
Sets the codec type of the recorded file. By setting the codec type, default values for bitrate and audio are also set. These values can be changed (Refer to the Supported Codecs for further details). Not all codec types are available with all container types. Available codec types are:
Note: To utilize the TDIR capabilities of the ProRes codec with a .mov container in Viz Engine, you must use the .Ref-file. Note: When container is XDCAMMXF, the default codec is XDCam which is HD422. The default bitrate for XDCam, XDCamEX and XDCamHD are 50, 35 and 35 respectively. XDCamEX outputs 1920x1080 clip at 35 Mbps and XDCamHD outputs 1440x1080 clip at 35 Mbps (VBR) or 25 Mbps (CBR) depending on the bitrate chosen. Refer to the Supported Codecs for further details. |
BITRATE [rate] |
Sets the bitrate for the video encoding. The value can either be applied as bits per second or as Megabits per second. Not all codecs allow changes to the bitrate. In such cases, BITRATE is ignored. |
IN [timecode] |
Sets the default value for the recording start time. The initial value is empty. |
OUT [timecode] |
Sets the default value for the recording stop time. The initial value is empty. |
DURATION [frames|timecode] |
Sets the default value for the recording duration. The initial value is 0. When applying a duration to the RECORD START command, the default value is ignored but not changed. Refer to Data Types for information on time code formatting. |
STARTTC [timecode] |
Sets the default value for the starting timecode. The value must be in timecode format: 00:00:00:00. |
AUDIOCHANNELS [channels] |
DISKACCESSSIZE [size] |
Sets the size of data blocks written to the disk in byte. Postfixes like KiB, Kb, k, etc., are allowed, but must not be separated from the value with a blank space (see example).
Example: CONFIG SET DISKACCESSSIZE 1024KiB |
VBR [bool] |
Activates variable bit rates for codecs which support it (currently XAVC only). The default setting is Off. |
TDIR [bool] |
Sets the default behavior of TDIR (Time Delayed Instant Replay). The default setting is On. |
TDIRINTERVAL [time] |
Sets the interval of file header updates in TDIR recordings. The value is in seconds and fractions of seconds, meaning both 0.1 and 1.0 are considered valid values. Minimum allowed value is 0.001, which is interpreted by Channel Recorder as every frame. A typical value would be 10.0, the default value is 3.0. Warning: To secure proper operation with Viz Engine, this value must not exceed 10.0. |
UPDATEMT [bool] |
Updates the modification time of the recorded clip regardless of TDIR value. The initial value is On. |
STOPATEND [bool] |
Sets the default behavior at the end of the recording. |
CLOCK
Variable |
Value |
CLOCKTYPE [type] |
Defines the type of clock used. Valid values for [type] are:
Note: INPUT clock should be use if automatic detection of input is a requirement. |
GENLOCKFLYWHEEL [bool] |
Uses the flywheel in case of genlock loss, if genlock is used. The default value is Off. |
FLYWHEELTIMEOUT [timeout] |
Sets the timeout for the genlock flywheel in seconds. This defines the time until the genlock switches to free run, as well as the maximum time the flywheel can use to resynchronize. The initial value is 5.0. |
IPOUT
Variable |
Value |
IPOUT SDIIP ADDRESS [address] |
Destination IPv4 address. The default value is 239.0.12.10. |
IPOUT SDIIP PORT [port] |
IPOUT IPVIDEO [bool] |
IPOUT IPVIDEO ADDRESS [address] |
Sets destination IPv4 address. The default value is 239.0.12.10. |
IPOUT IPVIDEO PORT [port] |
IPOUT IPVIDEO RTPPAYLOADID [id] |
Indicates the RTP (Real-time Transfer Protocol) Payload ID to capture. Used when RTP Payload ID is set to true. The default value is 97. |
IPOUT IPAUDIO [bool] |
IPOUT IPAUDIO ADDRESS [address] |
Sets destination IPv4 address. The default value is 239.0.12.12. |
IPOUT IPAUDIO PORT [port] |
Sets destination port. The default value is 50004. |
IPOUT IPAUDIO RTPPAYLOADID [id] |
Indicates the RTP (Real-time Transfer Protocol) Payload ID to capture. Used when RTP Payload ID is set to true. The default value is 98. |
IPOUT IPAUDIO USETRACKCOUNT [bool] |
Uses track count to specify the number of tracks for the outgoing IP stream if True. The default value is False . |
IPOUT IPAUDIO TRACKCOUNT [count] |
The default value is 8 . |
IPOUT IPAUDIO PACKETDURATION [duration] |
The default value is 3 . |
IPOUT IPANC [bool] |
Enables ANC flow if True. |
IPOUT IPANC ADDRESS [address] |
Sets destination IPv4 address. The default value is 239.0.12.14. |
IPOUT IPANC PORT [port] |
Sets destination port. The default value is 50006. |
IPOUT IPANC RTPPAYLOADID [id] |
Indicates the RTP (Real-time Transfer Protocol) Payload ID to capture. Used when RTP Payload ID is set to True. The default value is 100. |
IPOUT IPANC SMPTE352 [bool] |
Enables SMPTE 352 packets if True. The default value is False. |
SHMOUT
Variable |
Value |
SHMOUT SHMNAME [name] |
Sets shared memory name. The default value is SHM_CR. |
SHMOUT ADDRESS [address] |
Sets d estination IPv4 address. The default value is 127.0.0.1 . |
SHMOUT PORT [port] |
Sets destination port. The default value is 10002. |
COMMUNICATION
Command |
Description |
COMMAND_HANDLER PORT SET [port] |
Sets the port of the command interface. A port can only be set once. |
COMMAND_HANDLER DUMP |
Prints this list of available commands. |
MVCP PORT [port] |
Sets the port for the MVCP communication. This command is required to initialize MVCP. |
EXIT
Command |
Description |
exit, EXIT |
Stops all channels, clean up the hardware and stop the service. |
