Version 1.4 | Published August 14, 2019 ©
Upgrading from Channel Recorder 1.0
The biggest difference between Channel Recorder versions 1.0 and Channel Recorder with Service Host 1.4 is that Service Host is now the front end controller. Starting with Channel Recorder version 1.1, Channel Recorder is considered a plugin of Service Host. This means that the Channel Recorder is managed by Service Host through the web interface that it provides. With Service Host you can:
Register a new instance.
Remove an existing instance.
Start an existing instance.
Stop an existing instance.
Provide an initial configuration to an instance.
For more information, refer to the Service Host documentation.
Matrox DSX.Utils
Channel Recorder with Service Host 1.4 requires Matrox DSX.utils version 10.1.020.24098.
Configuration File
For users upgrading from Channel Recorder 1.0, the only required step is the translation of the configuration into the new format. Previously, the configuration was provided via a simple text file located in %programdata%/vizrt/Channel Recorder.
This file might contain the following:
COMMAND_HANDLER PORT SET 6810MAIN BOARD SELECT A523502MVCP PORT 10000CONFIG SET RINGBUFFERSIZE 60MAIN CLOCKTYPE GENLOCKMAIN CONNECTOR SELECT ACONFIG SET FILEEXTENSION OFFCONFIG SET PRIORITY REALTIMECONFIG SET CLIP_ROOT D:/CONFIG SET TIMEOUT 5000CONFIG SET AUDIOCHANNELS 4CONFIG SET CODEC XDCamHDCONFIG SET CONTAINER XDCAMMXFCONFIG SET TIMECODE TIME_OF_DAYCONFIG SET TDIRENABLE FALSECONFIG SET VBI OFFIn Channel Recorder 1.3, the configuration is provided via an xml file located in %programdata%/vizrt/ServiceHost. The configuration file name is the Service Name used when registering the Channel Recorder instance. This xml file can be edited directly, however, it is highly recommended that you use the Service Host web interface.
Note: All configuration settings that were in 1.0 are still present with the same parameters and similar names.
You must use the Service Host web interface and configure Channel Recorder appropriately to achieve the same behavior as in the old version. Configuration is described in Channel Recorder Configuration.
Note: Do not forget to restart the instance after any changes to the configuration.
Log File
As with the configuration file, the log file is now located in %ProgramData%/vizrt/ServiceHost instead of %programdata%/vizrt/Channel Recorder.
The old file used to configure the logging mechanism is gone. The only option in the new version is to change the logging level. Refer to the Service Host Section in Channel Recorder Configuration.
