Supported Codecs
The Channel Recorder supports the following containers and codecs.
Note: If a combination of CODEC / CONTAINER / RESOLUTION is not supported, Channel Recorder floods the logs with errors. If this happens stop the recording using RECORD STOP. Please make sure that the mentioned combination are supported by consulting the tables below.
Note: Only the containers AVCINTRAMXF, DVCPROMXF, XDCAMMXF, XAVCMXF support capturing of closed captions. The closed captions must be part of SMPTE 334M CDP. The captured close caption is found in the recorded clip in the wrapper according to SMPTE 436M and in the actual MXF essence.
Note: The examples below are not exhaustive. Some parameters such as the number of audio channels have other options.
PAL Codecs
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 720x576 |
Alpha: No Bitrate: 10-50 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes |
No Audio PCM: - 2 ch: 24 in 32bit; 48kHz - 4 ch: 24 in 32bit; 48kHz - 8 ch: 24 in 32bit; 48kHz - 16 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC IFrame CONFIG SET CONTAINER AVI CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
Specifying this codec / container combination is not supported through MVCP. If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type. |
DVCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DV/DVCAM 4:2:0 720x576 |
Alpha: No Bitrate: 25 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
CONFIG SET CODEC DvCam CONFIG SET CONTAINER AVI CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mov |
Alpha: No Bitrate: 25 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: N/A CC: No |
No Audio PCM: - 4 ch: 24 in 32bit; 48kHz - 8 ch: 24 in 32bit; 48kHz - 16 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC DvCam CONFIG SET CONTAINER MOV CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mxf |
Alpha: No Bitrate: 25 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: Yes CC: No |
No Audio |
CONFIG SET CODEC DvCam CONFIG SET CONTAINER MXF RECORD CLIP clip RECORD START |
DVCPRO
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO 4:1:1 |
No Audio PCM: - 2 ch: 24 in 32bit; 48kHz; - 4 ch: 24 in 32bit; 48kHz; - 8 ch: 24 in 32bit; 48kHz; - 16 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER AVI CONFIG SET BITRATE 25 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.avi |
DVCPRO 50 4:2:2 |
Alpha: No Bitrate: 50 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER AVI CONFIG SET BITRATE 50 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mov |
DVCPRO 4:1:1 |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MOV CONFIG SET BITRATE 25 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mov |
DVCPRO 50 4:2:2 |
Alpha: No Bitrate: 50 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: N/A CC: No |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MOV CONFIG SET BITRATE 50 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
DVCPRO 4:1:1 |
Alpha: No Bitrate: 25 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER DVCPROMXF CONFIG SET BITRATE 25 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "25000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf (OP1a) |
DVCPRO 50 4:2:2 |
Alpha: No Bitrate: 50 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER DVCPROMXF CONFIG SET BITRATE 50 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf Panasonic P2 (OP-Atom) |
DVCPRO 4:1:1 |
No Audio |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MXF CONFIG SET BITRATE 25 RECORD CLIP clip RECORD START |
Specifying this codec / container combination is not supported through MVCP. If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type |
DVCPRO 50 4:2:2 |
No Audio |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MXF CONFIG SET BITRATE 50 RECORD CLIP clip RECORD START |
XDCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX50) 4:2:2 |
Alpha: No Bitrate: 50 Bit depth: 10 VBI: required Timecode: required TDIR: Yes CC: Yes |
AES3: - 8ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC XDCam CONFIG SET CONTAINER XDCAMMXF CONFIG SET BITRATE 50 CONFIG SET AUDIOCHANNELS 4 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX40) 4:2:2 |
Alpha: No Bitrate: 40 Bit depth: 10 VBI: required Timecode: required TDIR: Yes CC: Yes |
CONFIG SET CODEC XDCam CONFIG SET CONTAINER XDCAMMXF CONFIG SET BITRATE 40 CONFIG SET AUDIOCHANNELS 4 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "40000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX30) 4:2:2 |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "30000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1
NTSC Codecs
MPEG IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 720x480 |
Alpha: No Bitrate: 10-50 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
CONFIG SET CODEC IFrame CONFIG SET CONTAINER AVI CONFIG SET BITRATE 50 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
DVCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DV/DVCAM 4:1:1 720x480 |
.mov |
Alpha: No Bitrate: 25 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: N/A CC: No |
No Audio |
DVCPRO
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO 4:1:1 720x480 |
Alpha: No; Bitrate: 25; Bit depth: 8; VBI: N/A; Timecode: N/A TDIR: Yes CC: No |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER AVI CONFIG SET AUDIOCHANNELS 8 CONFIG SET BITRATE 25 RECORD CLIP clip RECORD START |
.avi |
DVCPRO 50 4:2:2 720x480 |
Alpha: No; Bitrate: 50; Bit depth: 8; VBI: N/A; Timecode: N/A TDIR: Yes CC: No |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER AVI CONFIG SET AUDIOCHANNELS 8 CONFIG SET BITRATE 50 RECORD CLIP clip RECORD START |
.mov |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MOV CONFIG SET AUDIOCHANNELS 8 CONFIG SET BITRATE 25 RECORD CLIP clip RECORD START |
.mov |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MOV CONFIG SET AUDIOCHANNELS 8 CONFIG SET BITRATE 50 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
Alpha: No Bitrate: 25 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: Yes |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER DVCPROMXF CONFIG SET AUDIOCHANNELS 8 CONFIG SET BITRATE 25 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
Alpha: No Bitrate: 50 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: Yes |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER DVCPROMXF CONFIG SET AUDIOCHANNELS 8 CONFIG SET BITRATE 50 RECORD CLIP clip RECORD START |
No Audio |
No Audio |
XDCAM
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX50) 4:2:2 720x512 |
Alpha: No Bitrate: 50 Bit depth: 10 VBI: Required Timecode: Required TDIR: Yes CC: Yes |
AES3: - 4 ch: 24 in 32bit; 48kHz |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX40) 4:2:2 720x512 |
Alpha: No Bitrate: 40 Bit depth: 10 VBI: Required Timecode: Required TDIR: Yes CC: Yes |
AES3: - 4 ch: 24 in 32bit; 48kHz - 8ch: 24 in 32bit; 48kHz |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "40000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf XDCAM (OP1a) |
D10 (IMX30) 4:2:2 720x512 |
Alpha: No Bitrate: 30 Bit depth: 10 VBI: Required Timecode: Required TDIR: Yes CC: Yes |
CONFIG SET CODEC XDCam CONFIG SET CONTAINER XDCAMMXF CONFIG SET BITRATE 30 CONFIG SET AUDIOCHANNELS 4 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2" SET U1 MED vtr.media.mpeg.bit_rate "30000000" SET U1 MED vtr.media.audio.input.channels "4" CUER U1 REC U1 |
720p50 and 720p59.94 (60M) Codecs
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 1280x720 |
Alpha: No Bitrate: 50-300 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
DVCPRO HD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO HD 1280x720 |
Alpha: No Bitrate: 100 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER AVI CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mov |
DVCPRO HD 960x720 |
Alpha: No Bitrate: 100 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: N/A CC: No |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MOV CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
DVCPRO HD 960x720 |
Alpha: No Bitrate: 100 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER DVCPROMXF CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
DVCPRO HD 960x720 |
No Audio |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER MXF RECORD CLIP clip RECORD START |
XDCAM HD 422
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD 422 1280x720 |
No Audio PCM: - 8 ch: 24 in 32bit; 48kHz - 16 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC XDCam CONFIG SET CONTAINER XDCAMMXF CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "mpeg2-ibp-422p@hl" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
XDCAM EX HQ
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM EX HQ 1280x720 |
Alpha: No Bitrate: 35 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
No Audio PCM: - 2 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC XDCamEX CONFIG SET CONTAINER XDCAMMXF RECORD CLIP clip RECORD START |
AVC-Intra
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
AVCIntra Class 50 960x720 |
CONFIG SET CODEC AVCIntra50 CONFIG SET CONTAINER AVCINTRAMXF CONFIG SET BITRATE 50 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "avc-intra" SET U1 MED vtr.media.mpeg.bit_rate "50000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
.mxf (OP1a) |
AVCIntra Class 100 1280x720 |
CONFIG SET CODEC AVCIntra100 CONFIG SET CONTAINER AVCINTRAMXF CONFIG SET BITRATE 100 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "avc-intra" SET U1 MED vtr.media.mpeg.bit_rate "100000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
No Audio |
CONFIG SET CODEC AVCIntra50 CONFIG SET CONTAINER AVCINTRAMXF CONFIG SET BITRATE 50 RECORD CLIP clip RECORD START |
Alpha: No Bitrate: 100 Bit depth: 8 VBI: N/A Timecode: N/A TDIR: Yes CC:No |
No Audio |
CONFIG SET CODEC AVCIntra100 CONFIG SET CONTAINER AVCINTRAMXF CONFIG SET BITRATE 100 RECORD CLIP clip RECORD START |
ProRes
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mov |
I-Frame 4:2:2 1280x720 |
Alpha: No Bitrate: 100 (LT), 147, 220 (HQ) Bit depth: 10 VBI: N/A Timecode: N/A TDIR: Yes, with .Ref file CC: No |
CONFIG SET CODEC ProRes CONFIG SET CONTAINER MOV CONFIG SET BITRATE 100 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
DNxHD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
DNxHD (50) 120, 175 DNxHD (59.94) 145, 220 1280x720 |
Alpha: No Bitrate (50): 120,175 Bitrate (59.94): 145,220 Bit depth: 8 VBI: N/A Timecode: N/A CC: No |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER DNXHDMXF CONFIG SET BITRATE 120 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
DNxHD (50) 175x DNxHD (59.94) 220x 1280x720 |
Alpha: No Bitrate (50): 175x Bitrate (59.94): 220x Bit depth: 10 VBI: N/A Timecode: N/A CC: No |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER DNXHDMXF CONFIG SET BITRATE 175 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
No Audio |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER MXF CONFIG SET BITRATE 120 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
No Audio |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER MXF CONFIG SET BITRATE 175 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
1080i25 and 1080i29.97 (30M) Codecs
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
MPEG2-IFrame422 1920x1080 |
DVCPRO HD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
DVCPRO HD (25) 1920x1080 DVCPRO HD (29.97) 1260x1080 |
.mov |
Alpha: No Bitrate: 100 Bit depth: 10 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
No Audio |
.mxf (OP1a) |
Alpha: No Bitrate: 100 Bit depth: 10 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
PCM: - 4 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC DvCPro CONFIG SET CONTAINER DVCPROMXF RECORD CLIP clip RECORD START |
UADD CS_ENCODER1 * SHAR dart SET U1 MED vtr.media.video.input.compression.type "dvcpro" SET U1 MED vtr.media.mpeg.bit_rate "100000000" SET U1 MED vtr.media.audio.input.channels "8" CUER U1 REC U1 |
XDCAM HD 422
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD 422 1920x1080 |
XDCAM HD LP
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD LP 1440x1080 |
Alpha: No Bitrate: 18 Bit depth: 8 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
No Audio PCM: - 4 ch: 16 in 32bit; 48kHz |
CONFIG SET CODEC XDCamHD CONFIG SET CONTAINER XDCAMMXF CONFIG SET BITRATE 18 RECORD CLIP clip RECORD START |
XDCAM HD SP
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD SP 1440x1080 |
CONFIG SET CODEC XDCamHD CONFIG SET CONTAINER XDCAMMXF CONFIG SET BITRATE 25 RECORD CLIP clip RECORD START |
XDCAM HD HQ
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM HD HQ 1440x1080 |
CONFIG SET CODEC XDCamHD CONFIG SET CONTAINER XDCAMMXF CONFIG SET BITRATE 35 RECORD CLIP clip RECORD START |
XDCAM EX HQ
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XDCAM EX HQ 1920x1080 |
No Audio PCM: - 2 ch: 16 in 32bit; 48kHz |
AVC-Intra
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
AVCIntra Class 50 1440x1080 |
.mxf (OP1a) |
AVCIntra Class 100 1920x1080 |
Alpha: No Bitrate: 50 Bit depth: 10 VBI: N/A Timecode: N/A TDIR: Yes CC: No |
No Audio |
CONFIG SET CODEC AVCIntra50 CONFIG SET CONTAINER MXF CONFIG SET BITRATE 50 RECORD CLIP clip RECORD START |
No Audio |
CONFIG SET CODEC AVCIntra100 CONFIG SET CONTAINER MXF CONFIG SET BITRATE 100 RECORD CLIP clip RECORD START |
ProRes
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mov |
I-Frame 4:2:2 1920x1080 |
DNxHD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
DNxHD (30) 120, 185 DNxHD (29.97) 145, 220 1920x1080 |
Alpha: No Bitrate (50): 120,185 Bitrate (59.94): 145,220 Bit depth: 8 VBI: N/A Timecode: N/A CC: No |
.mxf (OP1a) |
DNxHD (30) 185x DNxHD (29.97) 220x 1920x1080 |
Alpha: No Bitrate (50): 185x Bitrate (59.94): 220x Bit depth: 10 VBI: N/A Timecode: N/A CC: No |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER DNXHDMXF CONFIG SET BITRATE 185 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
No Audio |
No Audio |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER MXF CONFIG SET BITRATE 185 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
1080p50 and 1080p59.94 (60M) Codecs
AVC-Intra
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
Alpha: No Bitrate: 50 Bit depth: 10 VBI: N/A Timecode: Yes TDIR: Yes CC: Yes |
CONFIG SET CODEC AVCIntra50 CONFIG SET CONTAINER AVCINTRAMXF CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
CONFIG SET CODEC AVCIntra100 CONFIG SET CONTAINER AVCINTRAMXF CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
No Audio |
No Audio |
MPEG-IFrame
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.avi |
ProRes
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mov |
Alpha: No Bitrate: 100 (LT), 147, 220 (HQ) Bit depth: 8, 10 VBI: N/A Timecode: N/A TDIR: Yes, with .Ref file CC: No |
CONFIG SET CODEC ProRes CONFIG SET CONTAINER MOV CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
DNxHD
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
DNxHD (50) 240, 365 DNxHD (59.94) 290, 440 1920x1080 |
Alpha: No Bitrate (50): 240, 365 Bitrate (59.94): 290, 440 Bit depth: 8 VBI: N/A Timecode: N/A CC: No |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER DNXHDMXF CONFIG SET BITRATE 240 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
.mxf (OP1a) |
DNxHD (50) 365x DNxHD (59.94) 440x 1920x1080 |
Alpha: No Bitrate (50): 365 x Bitrate (59.94): 440x Bit depth: 10 VBI: N/A Timecode: N/A CC: No |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER DNXHDMXF CONFIG SET BITRATE 365 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
Alpha: No Bitrate (50): 240 , 365 Bitrate (59.94): 290 , 440 Bit depth: 8 VBI: N/A Timecode: N/A CC: No |
No Audio |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER MXF CONFIG SET BITRATE 240 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
No Audio |
CONFIG SET CODEC DNxHD CONFIG SET CONTAINER MXF CONFIG SET BITRATE 365 CONFIG SET AUDIOCHANNELS 8 RECORD CLIP clip RECORD START |
2160p50 and 2160p59.94 (60M) Codecs
XAVC
Container |
Codec |
Features |
Audio |
VizSend Example |
MVCP Example |
.mxf (OP1a) |
XAVC |
Alpha: No Bitrate: 300, 480, (VBR/CBR) Bit depth: 10 VBI: N/A Timecode: Yes TDIR: N/A CC: Yes HDR: Yes |
PCM: - 16 ch: 24 in 32bit; 48kHz |
CONFIG SET CODEC XAVC CONFIG SET CONTAINER XAVCMXF CONFIG SET BITRATE 300 RECORD CLIP clip RECORD START |
Note: A M264 board is required for recording UHD.
