Version 1.2 | Published January 23, 2019 ©
Recording Viz Engine
From version 1.2, Channel Recorder supports recording input and output signals from Viz Engine. This feature is controlled by the parameter AliasNodeSource in the configuration.
The execution order of the applications is very important. To capture from Viz Engine, this must be executed before Channel Recorder.
Other things to take into account:
  • The write-to-read delay of the node to be read must be larger than 0.
  • For the reason above, the only supported board is an X.mio3 without Fast Texture Mode enabled.
