Service Host
Version 1.0 | Published November 15, 2017 ©
Supported Codecs
The Channel Recorder supports the following containers and codecs.
PAL Codecs
MPEG-IFrame
Container
Codec
Features
Audio
.avi
MPEG2-IFrame422
720x576
Alpha: No
Bitrate: 10-50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
- 2 ch: 24 in 32bit; 48kHz
- 4 ch: 24 in 32bit; 48kHz
- 8 ch: 24 in 32bit; 48kHz
- 16 ch: 24 in 32bit; 48kHz
DVCAM
Container
Codec
Features
Audio
.avi
DV/DVCAM 4:2:0
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mov
DVCAM 4:2:0
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mxf
Panasonic P2(OP-Atom)
DVCAM 4:2:0
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
No Audio
DVCPRO
Container
Codec
Features
Audio
.avi
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
- 2 ch: 24 in 32bit; 48kHz;
- 4 ch: 24 in 32bit; 48kHz;
- 8 ch: 24 in 32bit; 48kHz;
.avi
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mov
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mov
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mxf (OP1a)
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf (OP1a)
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf Panasonic P2 (OP-Atom)
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
XDCAM
Container
Codec
Features
Audio
.mxf XDCAM (OP1a)
D10 (IMX) 4:2:2
720x608
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: required
Timecode: required
TDIR: Yes
AES3
- 4ch: 24 in 32bit; 48kHz
Uncompressed
Container
Codec
Features
Audio
.avi
Uncompressed YUYV 4:2:2
720x576
Alpha: No
Bitrate: 160
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
NTSC Codecs
MPEG IFrame
Container
Codec
Features
Audio
.avi
MPEG2-IFrame422
720x480
Alpha: No
Bitrate: 10-50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
DVCAM
Container
Codec
Features
Audio
.avi
DV/DVCAM 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mov
DVCAM 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mxf
Panasonic P2
(OP-Atom)
DVCAM 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: N/A
No Audio
DVCPRO
Container
Codec
Features
Audio
.avi
DVCPRO 4:1:1
720x480
Alpha: No;
Bitrate: 25;
Bit depth: 8;
VBI: N/A;
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.avi
DVCPRO 50 4:2:2
720x480
Alpha: No;
Bitrate: 50;
Bit depth: 8;
VBI: N/A;
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mov
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mov
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mxf (OP1a)
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
PCM:
.mxf (OP1a)
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
PCM:
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
XDCAM
Container
Codec
Features
Audio
.mxf XDCAM (OP1a)
D10 (IMX) 4:2:2
720x512
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: Required
Timecode: Required
TDIR: Yes
AES3
Uncompressed
Container
Codec
Features
Audio
.avi
720x486
Alpha: No
Bitrate: 160
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
720p50 and 720p59.94 (60M) Codecs
MPEG-IFrame
Container
Codec
Features
Audio
.avi
MPEG2-IFrame422
1280x720
Alpha: No
Bitrate: 50-300
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
DVCPRO HD
Container
Codec
Features
Audio
.avi
DVCPRO HD
1280x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mov
DVCPRO HD
960x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
No Audio
PCM:
.mxf (OP1a)
DVCPRO HD
960x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf
DVCPRO HD
960x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
XDCAM HD
Container
Codec
Features
Audio
.mxf XDCAM (OP1a)
XDCAM HD422,
IBP HD 4:2:2,
1280x720
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: N/A
PCM:
AVC-Intra
Container
Codec
Features
Audio
.mxf (OP1a)
AVCIntra Class 50
960x720
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf (OP1a)
AVCIntra Class 100
1280x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
AVCIntra Class 50
960x720
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
AVCIntra Class 100
1280x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
ProRes
Container
Codec
Features
Audio
.mov
I-Frame 4:2:2
1280x720
Alpha: No
Bitrate: 100 (LT), 147, 220 (HQ)
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes, with .Ref file
No Audio
PCM:
Uncompressed
Container
Codec
Features
Audio
.avi
1280x720
Alpha: No
Bitrate: 700
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
1080i25 and 1080i29.97 (30M) Codecs
MPEG-IFrame
Container
Codec
Features
Audio
.avi
MPEG2-IFrame422
1920x1080
Alpha: No
Bitrate: 50-300
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
DVCPRO HD
Container
Codec
Features
Audio
.avi
DVCPRO HD
1920x1080
(1080i25)
1260x1080 (1080i29.97)
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mov
DVCPRO HD
1280x1080
(1080i25)
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
.mxf
Panasonic P2
(OP-Atom)
DVCPRO HD
1280x1080
(1080i25)
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
.mxf (OP1a)
DVCPRO HD
1280x1080
(1080i25)
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
XDCAM HD 422
Container
Codec
Features
Audio
.mxf (OP1a)
XDCAM HD,
IBP HD 4:2:2,
Elementary,
Program,
Transport
1920x1080
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
- 8 ch: 16 in 16bit; 48kHz
AVC-Intra
Container
Codec
Features
Audio
.mxf (OP1a)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf (OP1a)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
ProRes
Container
Codec
Features
Audio
.mov
I-Frame 4:2:2
1920x1080
Alpha: No
Bit depth: 10
VBI: N/A
Timecode: N/A
No Audio
PCM:
Uncompressed
Container
Codec
Features
Audio
.avi
1920x1080
Alpha: No
Bitrate: 800
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
1080p50 and 1080p59.94 (60M) Codecs
AVC-Intra
Container
Codec
Features
Audio
.mxf (OP1a)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf (OP1a)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
PCM:
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
MPEG-IFrame
Container
Codec
Features
Audio
.avi
MPEG2-IFrame422
1920x1080
Alpha: No
Bitrate: 50-300
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
ProRes
Container
Codec
Features
Audio
.mov
I-Frame 4:2:2
1920x1080
Alpha: No
Bit depth: 8, 10
VBI: N/A
Timecode: N/A
No Audio
PCM:
Uncompressed
Container
Codec
Features
Audio
.avi
1920x1080
Alpha: No
Bitrate: 2000
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
2160p50 and 2160p59.94 (60M) Codecs
XAVC
Container
Codec
Features
Audio
.mxf (OP1a)
MPEG2-IFrame422 3840x2160
Alpha: No
Bitrate: 300, 480, (VBR/CBR)
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: N/A
PCM:
