The Control Text plug-in binds the control of Text or Classic Text to a Control Object depending on the container geometry.
If neither Text or Classic Text is in the container, the Control Text plug-in uses the scene setting to determine which render engine to use.
This plug-in expects the input value in UTF-8 encoding.
This plug-in is located in: Plugins -> Container plug-ins -> Control
Control Text Properties
  • Maximal characters: Sets the maximum number of characters which can be typed into the text field.
  • Upper Case: Converts lower case input into upper case when set to On.
  • Expose letter spacing: Allows changes to the letter spacing parameters and sets the minimum and maximum value when set to On. The exposed field is kerning.
    • All values *1: Exposes two more values of letter spacing, percentage and extended relative instead of just extended absolute. The exposed field is changed to a group of three sub-fields:
      • letter_spacing.percentage, Minimum and Maximum value can be set.
      • letter_spacing.extend_rel, Minimum and Maximum value can be set.
      • letter_spacing.extend_abs, Minimum and Maximum value can be set.
  • Expose line spacing: Allows changes to the line spacing parameters and set the minimum and maximum value when set to On. The exposed field is line_spacing.
    • All values *1: Exposes two more values of line spacing, percentage and extended relative instead of just extended absolute. The exposed field is changed to a group of three sub-fields:
      • line_spacing.percentage, Minimum and Maximum value can be set.
      • line_spacing.extend_rel, Minimum and Maximum value can be set.
      • line_spacing.extend_abs, Minimum and Maximum value can be set.
  • Expose Font: Allows selects another Font when set to On. The exposed field is font on Classic Text, or font_face on Viz Engine Text.
    • Deny Browing Upward:
  • Expose alignment: Allows changes to the text alignment when set to On. The exposed field is justification.
    • All values *1: Exposes both horizontal and vertical alignment. The exposed field is changed to a group of two sub-fields:
      • alignment.horizontal
      • alignment.vertical
  • Single Line: Converts multi-line input into a single line when set to On.
  • Use Formatted Text: Enables use of character specific formatting in supported client applications. Character specific formatting includes bold, italic, subscript, superscript, kerning, position, rotation, scaling, alpha, and color(RGB) in Classic Text, modifier, font size, color(ARGB) in Text. Formatted text cannot be used together with Text FX Write.
    • Horizontal Pivot and Vertical Pivot: Set transformation pivot of characters in Formatted Text Wrapper with this formatted text <fo:wrapper rotate-z="-45">M</fo:wrapper> <fo:wrapper scale-x="2" scale-y="2">N</fo:wrapper>. Set Horizontal Pivot to Center and Vertical Pivot to Middle rotates ‘M’ and scales 'N’ at the original center of each character.
    • To use the characters < and > correctly in Viz Multichannel, make sure that Use Formatted Text is set to OFF.
    • Character specific formatting is not supported for Viz Pilot.
    • In Viz Trio, the operator enter a required formatting mode via an assigned shortcut key. To change the format of one or more characters, hold down ALT and toggle the right and left arrow keys to shift mode. See the Viz Trio User Guide for more information on Character Formatting.
  • Escape formatted text: Simplifies formatted text output. Use XML escape characters instead of XML <![CDATA[]]> and not add an XML root element. Use <fo:wrapper/> element only with formatted words and characters. Control Text still accepts both full formatted and escape formatted text input independent of this property.
  • Include default property values: Adds all available properties of formatted text output even all values are defaults. This guarantees all supported formats by Control Text can be transferred to another Text via XML.
  • Input Value / Input Value(UTF8): Shows the current value for the plug-in. It is not necessary to set any value here. It is used for debugging purposes.
  • Use shared memory placeholders: See Shared Memory placeholders.
  • Simulate classic commands*1: Allows Viz Trio uses Classic Text commands via Control Object to control styles of Viz Engine Text.
*1: only available with Viz Engine Text
Format single or multiple characters by cover them with <fo:wrapper /> element and add any or multiple of these attribute attributes.
All Available Formatters
XML Attribute
Data Type
Min
Max
Note
Example
kerning
letter-spacing
float
  • Existing value of text is not changed if no new value of these modifiers is specified.
  • This formatter affects space between covered and next and all followed characters.
    • From this example. "END" is moved to the left side of another ("TEST").
<fo:wrapper letter-spacing="80">T</fo:wrapper>
<fo:wrapper letter-spacing="40">E</fo:wrapper>
<fo:wrapper letter-spacing="10">S</fo:wrapper>
<fo:wrapper letter-spacing="-360">T</fo:wrapper>END
color
color
3 of ubyte
#000000
#FFFFFF
Contains value of red, green and blue in hexadecimal from 00 to FF lead by #:
  • #FF0000: brightest red
  • #00FF00: brightest green
  • #0000FF: brightest blue
<fo:wrapper color="#FF0000">T</fo:wrapper>
<fo:wrapper color="#00FF00">E</fo:wrapper>
<fo:wrapper color="#0000FF">S</fo:wrapper>
<fo:wrapper color="#000000">T</fo:wrapper>
underline
underline
boolean
true/false
<fo:wrapper underline="true">TEST</fo:wrapper>
scale
scale-x
float
0.0
  • Should be only positive value otherwise the backface is on the front side and be invisible until enable "Back-Face" drawing in Expert plug-in.
<fo:wrapper scale-x="3.0" scale-y="3.0">T</fo:wrapper>
<fo:wrapper scale-x="2.0" scale-y="2.0">E</fo:wrapper>
<fo:wrapper scale-x="1.0" scale-y="1.0">S</fo:wrapper>
<fo:wrapper scale-x="0.4" scale-y="0.4">T</fo:wrapper>
scale-y
float
0.0
scale-z
float
0.0
position
pos-x
float
  • Relates to default position of each character.
<fo:wrapper pos-y="-30">T</fo:wrapper>
<fo:wrapper pos-y="-10">E</fo:wrapper>
<fo:wrapper pos-y="10">S</fo:wrapper>
<fo:wrapper pos-y="30">T</fo:wrapper>
pos-y
float
pos-z
float
rotation
rotate-x
float
  • One rotation is 360 (counterclockwise) or -360 (clockwise).
<fo:wrapper rotate-x="15">T</fo:wrapper>
<fo:wrapper rotate-x="30">E</fo:wrapper>
<fo:wrapper rotate-x="45">S</fo:wrapper>
<fo:wrapper rotate-x="60">T</fo:wrapper>
rotate-y
float
rotate-z
float
Available Classic Text Formatters
XML Attribute
Data Type
Min
Max
Note
Example
alpha
opacity
float
0
100
  • Subscript and superscript cannot be true at the same time.
<fo:wrapper opacity="80">T</fo:wrapper>
<fo:wrapper opacity="60">E</fo:wrapper>
<fo:wrapper opacity="40">S</fo:wrapper>
<fo:wrapper opacity="20">T</fo:wrapper>
bold
boolean
true/false
<fo:wrapper bold="true">TEST</fo:wrapper>
italic
boolean
true/false
<fo:wrapper italic="true">TEST</fo:wrapper>
subscript
boolean
true/false
<fo:wrapper subscript="true" superscript="false">TEST</fo:wrapper>
superscript
boolean
true/false
<fo:wrapper subscript="false" superscript="true">TEST</fo:wrapper>
font
font
FONT
<fo:wrapper font="<00AF0E0D-625C-184B-98AE54ADA55B6239>">TEST</fo:wrapper>
<fo:wrapper font="FONT*Fonts/JS-Wansika-Italic">TEST</fo:wrapper>
<fo:wrapper font="Fonts/JS-Wansika-Italic">TEST</fo:wrapper>
Available Text Formatters
XML Attribute
Data Type
Min
Max
Note
Example
color
color
3-4 of ubyte
#00000000
#FFFFFFFF
Contains value of alpha (optional), red, green and blue in hexadecimal from 00 to FF lead by #:
  • #00000000: transparent (zero alpha)
  • #FF000000: opaque (highest alpha)
Default alpha value is #FF if not specified
<fo:wrapper color="#40808080">O</fo:wrapper>
<fo:wrapper color="#80808080">P</fo:wrapper>
<fo:wrapper color="#B0808080">A</fo:wrapper>
<fo:wrapper color="#D0808080">Q</fo:wrapper>
modifier
modifier
modifier
subscript/superscript/none
<fo:wrapper modifier="subscript">TEST</fo:wrapper>
<fo:wrapper modifier="superscript">TEST</fo:wrapper>
<fo:wrapper modifier="none">TEST</fo:wrapper>
font
font
FONT_FACE
<fo:wrapper font="<41E57305-1205-4742-96DA817BCA632729>">TEST</fo:wrapper>
<fo:wrapper font="FONT_FACE*Fonts/JS_Wansika_Italic">TEST</fo:wrapper>
<fo:wrapper font="Fonts/JS_Wansika_Italic">TEST</fo:wrapper>
<fo:wrapper /> element can be covered by another such as:
Formatters
<fo:wrapper bold="true" color="#ff0000"> Th<fo:wrapper color="#ffffff"> a<fo:wrapper color="#0000ff"> il</fo:wrapper> a</fo:wrapper> nd </fo:wrapper>
Result
Th a il a nd
Entities
Support three entities in formatted text for preventing broken formatter XML.
Character
Entity
Character
Entity
&lt;
&gt;
&amp;
Example
Formatter
<fo:wrapper color="#FF0000">&lt;sender&gt;John &amp; Smith&lt;/sender&gt;</fo:wrapper>
Result
<sender>John & Smith</sender>
CDATA Section
CData section can be used for preventing broken formatter XML too, but with more readable text.
Can be used to send plain text into Control Classic Text plug-in with enabled "Use formatted text" but many existing formats such as bold, italic, underline subscript and superscript in current text still are kept.
Example
Formatter
<fo:wrapper color="#ff0000"><![CDATA[<sender>John & Smith</sender>]]></fo:wrapper>
Result
Can rest all existing formats by assigning those new values, but the plain text should not contain "]]>".
Example with Classic Text
<fo:wrapper letter-spacing="0" color="#000000" opacity="1 0 0" bold="false" italic="false" underline="false" subscript="false" superscript="false" font="<00AF0E0D-625C-184B-98AE54ADA55B6239>" ><![CDATA[Any plain text]]></fo:wrapper>
Example with Text
<fo:wrapper letter-spacing="0" color="#000000" underline="false" modifier="none" font="<41E57305-1205-4742-96DA817BCA632729>" ><![CDATA[Any plain text]]></fo:wrapper>
