The Control Geom plug-in exposes the control of geometry objects to the user.
Control Geom Properties
  • Geom location Prefix: Sets a path to a folder. The geometry location exposed to the control client can be a simple string, instead of a full path. This is relevant if connected to a newsroom system. For example, if a user wants to edit a text and geometry on the same tab-field by just entering a text string. If for instance the user have a folder of weather symbols and the control client receives “sunny” from the external system it loads the geometry object with the path: “geom location prefix + sunny”, which then typically would be an image of a shining sun.
  • Input Value: Shows the current input value. Enter a value to test the relation of max/min. input and scale values.
  • Deny Browsing Upwards: Restricts the user from browsing for objects in folders other than the selected folder and its sub-folders when enabled.
  • Use Reference: Overwrites materials if an object is going to be replaced with another one already within the pool. Turn this option off if you encounter issues with wrong materials assigned. Default is active.
