The Slide Show plug-in allows you to create a sequence where a group of containers fade in and out one by one in the same manner as a normal slide show.
Slide Show Properties
Blend Value: Controls the slide show sequence. Animate this value to create the change from slide to slide.
Use Offset: Enable this option if the slides have the same initial position and you want them to move along some of the axes as the slides are being shown.
X, Y, and Z Offset: Sets the offset values of each slide calculated form the one previously shown.
Fade Out: May be set Off, On (every slide) or Last (last slide only)
Start with: Sets what should be visible if slide show is not started.
To Create a Slide Show
Add a group to the scene tree, and name it
slideshow.Add a number of Sub-Containers that are used to house the slide(s).
Add Slide Show to the slideshow container.
Position the Sub-Containers in advance using the transformation editors for each container, or open the Slide Show editor and offset them to create a moving sequence.
Animate the blend value to create the slide show sequence.
Click the Initialize button to initialize the plug-in. Each of the Sub-Containers automatically get an alpha icon.
