Viz Plug-in Release Notes
Viz Plug-ins 5.2.1
Release Date: 2024-03-20
These are the release notes for Viz Plug-ins version 5.2.1. This document describes the user-visible changes that have been made to the software since release 5.2.0.
Fixed Issues
Viz Plug-ins 5.2.0
Release Date: 2024-02-07
These are the release notes for Viz Plug-ins version 5.2.0. This document describes the user-visible changes that have been made to the software since release 5.1.1.
Information: Viz Weather plug-ins are not yet included and need to be installed separately by installing the latest released Viz Weather Version.
This document includes the Release Information for:
Viz Basic Plug-ins
Viz DataPool Plug-ins
Viz Extensions Plug-ins
Viz Maps Plug-ins
Viz PixelFX Plug-ins
Viz Socialize Plug-ins
Installer Notes
The installation wizard guides you through the installation process. Make sure to close any running Viz application prior to the installation. In order to run Viz Artist or Viz Engine independent of a database server, you need to install the Viz Graphic Hub database software locally.
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
The basic plug-ins are installed by default. All other plug-in packages are optional.
Softclip comes in 32-bit (default) and 64-bit versions. To use the 64-bit version, replace the file Softclip.vip in \plugins with the one from the subfolder %ProgramFiles%\VizEngine\plugin\disabled.
Upgrade Notes
All plug-in installers are installed per-machine starting with 5.2.0. Uninstalling all previous per-user plug-in installations before upgrading is recommended to avoid duplicated installer entries.
The path for the DataPool-related files has been set to %\ProgramData%\vizrt\VizEngine\DataPool.
New Features
New Features: Viz Basic Plug-ins
Summary |
Improve handling of multiple control plugins with same field id |
Control Material plugin: Support PBR and Phong Material Definition materials |
New Features: Viz DataPool Plug-ins
Summary |
Fixed Issues
Fixed Issues: Viz Basic Plug-ins
Fixed Issues: Viz DataPool Plug-ins
Summary |
Animation randomly gets stuck using Datakeyframe in Transition Logic |
Plugin Installers are installed perUser but should be perMachine |
Fixed Issues: Viz Extension Plug-ins
Fixed Issues: Viz Maps Plug-ins
Fixed Issues: Viz PixelFX Plug-ins
Fixed Issues: Viz Socialize Plug-ins
Changes
The User Interfaces of the following plug-ins have been ported to native QT style:
CFxPlusPlus
Dexter
ImageFx
pxGradient
pxLensRays
pxRecolor
RFxSmoke
TFXPlusPlus
Wave
Known Issues
General
Summary |
VLC plugin "loop" function not supported and needs to be removed |
[cherry-pick] - Change in TextFX emoticons plugin breaks lower third graphics |
Viz Basic Plug-ins Known Issues
On Dual channel setups Browser Plug-in causes performance impacts on second or higher instance.
RTT Shaders consume about 300-400 MB of RAM once they are initialized. If you do not use them or if you don't own a license, it is recommended to disable the plug-ins in the configuration panel in section Plugins (VIZENG-10224).
Softclip: Lagarith Codecs are playing slower on Windows Server Operating Systems. This issue can be solved by enabling Use Multithreading option in Lagarith codec configuration.
Viz Socialize Plug-ins Known Issues
Viz Engine can't access mapped network shares on Windows 10 for security reasons. If media files are stored on a network share, please be sure to enable Network Linking in Viz Configuration (Local Settings).
Trio 3.x and Viz Artist (UI) do not have full Unicode support yet (e.g. not all Emojis can be set by these control applications).
VLC plug-in requires some additional steps:
Download the archive from VLC: http://download.videolan.org/pub/videolan/vlc/2.2.6/win64/vlc-2.2.6-win64.zip
Extract the zip file and copy all files from:
vlc-2.2.6\plugins to <VizDirectory>\plugins
vlc-2.2.6\lua to <VizDirectory>\lua
Viz Maps Plug-ins Known Issues
When freezing a Map, including Pyramids in CWMClient, Hop scenes no longer work (VIZPL-45).
Supported Hardware and Software
This software has been tested to run on:
Windows 10 (LTSC 1809), Windows 10 LTSC 21H2
Windows 11
Windows Server 2019
Windows Server 2022
Note: Only English language Operating System(s) are supported.
Build Information
Platform Toolset: Visual Studio 2019 (v142)
Windows SDK Version: 10.0.14393.0
Documentation
Documentation for both Viz Engine and Viz Artist are available at the Vizrt Documentation Center:
Support
