The database parameters (also called VCP parameters) are stored in the Pilot database and served by Pilot Data Server to every connected client. You edit them from the Parameters panel in DataServerConfig.
Caution: These settings apply to every client connected to this Pilot Data Server and should only be changed by administrators. Some changes require a server restart before they take effect.
The parameters are grouped below by relevance:
  • Settings used by Pilot Edge and Template Builder – the settings you configure for a modern system.
  • Newsroom and system settings – newsroom (MOS) integration and system-level settings such as on-air updates and spell checking.
  • Legacy settings – kept for backwards compatibility but not used by Pilot Edge or Template Builder.
  • Settings managed internally by Pilot Data Server – the server reads or maintains these; do not change them unless instructed.
These are the parameters that affect a modern Pilot Edge / Template Builder deployment. Several of the Pilot Edge UI toggles are more conveniently set from the Pilot Edge panel in Data Server Config, but are listed here for completeness.
Parameter
Description
graphic_hub_url
Host or reverse-proxy URL of the Graphic Hub REST API used to provide scenes (for example https://<graphichubserver>:19398/). May include a base-path prefix, and an explicit port if it differs from the default 19398.
preview_server_uri
Base URL of the Preview Server used to render preview images in the editor (for example https://<previewserver>:4443/). Published by Pilot Data Server in its service document.
crop_service_uri
URL of the image Crop Service used when cropping images in templates and data elements (for example https://<cropservice>:8179/).
shared_curious_server
Viz World (maps) server IP or host name. In a multi-server setup, use a comma-separated list of IPs/host names.
vizmaps_baseurl, vizmaps_apikey, vizmaps_language, vizmaps_style
Settings for the Viz Maps service used by the map editors in Pilot Edge and Template Builder. Set from the Viz Maps section of the Pilot Edge panel. See Viz Maps.
moseditor_arc_url
URL of the Viz Arc MOS plug-in panel. When set, the Viz Arc actions tab is shown in Pilot Edge.
moseditor_arc_schema
Qualifier string that identifies the Viz Arc MOS editor when reopening Viz Arc items from the newsroom system. Default http://www.vizrt.com/mosObj/vizarc/action.
moseditor_arc_label
Title of the Viz Arc tab in Pilot Edge. Default Viz Arc.
moseditor_mosart_url
URL of the Mosart MOS plug-in panel. When set, the Mosart tab is shown in Pilot Edge.
moseditor_mosart_schema
Qualifier string that identifies the Mosart MOS editor when reopening Mosart items from the newsroom system. Default http://www.mosartmedialab.no/schema/mositem.dtd.
moseditor_mosart_label
Title of the Mosart tab in Pilot Edge. Default Mosart.
ax_hide_images
If true, the Images tab is hidden in the Pilot Edge top bar. Also configurable from the Pilot Edge panel.
ax_hide_videos
If true, the Videos tab is hidden in the Pilot Edge top bar. Also configurable from the Pilot Edge panel.
ax_disableupload
If true, uploading and pasting images into image fields is disabled in Pilot Edge. Also configurable from the Pilot Edge panel.
ax_dont_fetch_thumbnails
If true, the template and element browser default to list view without thumbnails. Also configurable from the Pilot Edge panel.
ax_disable_data_overwrite
If true, users cannot overwrite existing data elements when saving (only Save As is available). Also configurable from the Pilot Edge panel.
delete_data_from_activex
If true, users may delete data elements from the Pilot Edge element browser. Also configurable from the Pilot Edge panel.
pilotedge_settings
JSON value holding default Pilot Edge UI settings under the default key: default_template_sorting, theme_modes, show_playout_instructions, hide_media_tags and hide_template_tags. Managed from the Pilot Edge panel – not normally edited by hand.
collection_settings
JSON value holding per-profile settings (default concept, available concepts and tags) used by Pilot Edge. Managed from the Template Builder profile editor.
mosart_configuration
JSON value holding the Mosart timing configuration. Each group can set a Default Duration (defaultDuration): the Mosart timing panel fills it in for an item without a duration, and applies it when the user selects the group. Managed from the Template Builder Viz Mosart Configuration dialog.
order_mgt_uri_template
URL template used to open the Viz One order-management form for image/asset orders.
env-vizrt-spellcheck-language
Default language used for spell checking (for example en_US). Replaces the legacy spellcheck_dict_filename parameter.
env-vizrt-spellcheck-path
URL that serves the dictionary files used for spell checking. Replaces the legacy spellcheck_dict_path parameter.
env-style
Name of the default style for template forms in Pilot Edge and Template Builder. Empty uses the built-in style. Set from the Template Builder Style Editor or the Pilot Edge panel; the $style URL parameter overrides it. See Styling.
These settings configure newsroom (MOS) integration and system-level behavior. They are relevant to a modern deployment but are set less often than the core settings above.
Parameter
Description
ax_MOSID
Overrides the MOSID used in the MOS items produced for the newsroom system. Default PILOT.
data_server_url
Public URL of this Pilot Data Server, or of the reverse proxy in front of it (for example http://exampleserver.com:8177). May include a base-path prefix at the end of the URL (for example http://exampleserver.com:8177/pds). Clients and search providers use this address to reach the server. Replaces the legacy app_server parameter.
mos_plugin_url
URL of the Pilot MOS HTML plug-in that Trio/Director uses to open elements and templates that do not have a proper legacy form. Must point at the final (non-redirecting) Pilot Edge URL – for example http://pds:8177/app/pilotedge/PilotEdge.html rather than a URL that issues an HTTP redirect.
live_update_interval
Poll interval, in seconds, for update scripts. When Update at regular intervals while on air is enabled for a template, the Media Sequencer invokes the update service using this interval. Minimum 2 seconds; default 5.
video_mode
Channel video mode, PAL or NTSC. Also used by the server to derive MOS timing (see mos_override_objtb).
Legacy settings (not used by Pilot Edge or Template Builder)
These parameters are used by the legacy ActiveX Newsroom Component (Viz Pilot News / Director), the legacy Template Wizard, or Viz Object Store. They are kept for backwards compatibility and have no effect in a Pilot Edge / Template Builder system.
Parameter
Description
activex_preview_timeout
Timeout, in milliseconds, waiting for the Viz Preview Engine connection before continuing. Default 10000.
allow_subfield_in_view
Used by the legacy client to decide whether sub-fields can be added to custom layouts.
ax_dataelement_timer_enabled
Default for showing/hiding the Graphic Event Timing options in the newsroom component when saving an element. Could be overridden per template in Template Wizard.
ax_disable_clear_layers
Disables clearing all layers as the first commands sent when sending to preview.
ax_disable_dragdrop
Disables drag-and-drop in the newsroom component (for newsroom systems that do not support it).
ax_disable_media_drag
Disables dragging media from search results to the rundown.
ax_disable_overlay_saving
Disables saving of overlay timelines for clip assets that have an overlay_timeline link.
ax_enable_refresh_button
Shows the refresh button in the ActiveX external preview form.
ax_enableMediaSendToRundown
Enables the Add to Rundown option in media search (for newsroom systems without drag-and-drop).
ax_force_detached_pvw
Forces a detached snapshot-preview window in the ActiveX/VCP client.
ax_hide_data_elements
Hides the data element list in the legacy newsroom component. Pilot Edge does not read this database parameter; the equivalent behavior is controlled by the showpilotelements URL parameter (?showpilotelements=false).
ax_hide_media_tab
Hides the media tab in the newsroom component.
ax_include_mosobj_tag
Adds a mosobj node to the MOS XML generated client-side. Required for some (Dalet) integrations.
ax_mos_edit_save_returns
Controls whether the ActiveX returns to the template list after saving (when editing).
ax_preview_host
Host name of the Viz Engine used by the legacy client to generate snapshot previews and fetch resource icons.
ax_preview_img_protocol
Requests snapshots in different image formats.
ax_preview_port
Port of the Viz Engine used by the legacy client for snapshot previews and resource icons.
ax_preview_tl_legacy_support
Sends values to the legacy transition-logic location ($other$object) in addition to the normal behavior when previewing.
ax_preview_tl_show_next_sub
Uses the \Toggle*continue_noanim command when previewing transition logic.
ax_remove_continue_count
Disables sending continueCount in mosExternalMetadata.
ax_remove_objSlug
Removes objSlug from the MOS XML generated client-side (needed when hosted in AvidCommand).
ax_required_version
Minimum required version of the Vizrt newsroom component; a warning is shown if the client is older.
ax_savesas_cancels_edit
Changes Save As New behavior so the original item in the script is not replaced.
ax_show_hints
Turns tooltips in the ActiveX on/off (tooltips could crash the Dalet newsroom system).
ax_showsavechanges_dlg
Asks users whether to save the open element or template when opening another.
ax_use_custom_gui_dlg
Embeds the Viz Curious Maps Editor inside the newsroom component window.
clip_default_itemchannel
Default channel for video clips, written to the itemChannel element of the MOS XML by the legacy client.
country_language
Language used for the legacy country list. English is supported by default.
DELETE_DATA_PASSWORD
Password protecting data-element deletion in the legacy client. Empty means no password.
disable_built_in_vos_search
Disables the built-in Viz Object Store search (used when moving to RESTful VOS search).
image_order_uri_template
Placeholder URL template for image orders.
image_share
Path the legacy image Crop Tool uses when saving a cropped image (UNC or Windows path).
MediaSearch_itemPerPage
Number of media-search items per page in the legacy client.
mse_script_runner
Overrides the (legacy VBScript) script runner used by the Media Sequencer. Superseded by the modern Update Service.
script_runner_uri
URL of the legacy VBScript script runner that executed update scripts. Superseded by the modern Update Service.
show_playlist_element_index
Shows an index column in the legacy VCP playlist.
slim_mos_xml
Reduces the client-generated MOS XML by removing optional tags.
Dictionary/affix file base name for the legacy spell checker (default en_US). Superseded by env-vizrt-spellcheck-language in Pilot Core Service.
Path to the legacy spell-checker dictionary files. Superseded by env-vizrt-spellcheck-path in Pilot Core Service.
timeline_update_service
Service-document URL for the legacy Timeline Update Service.
VOS_PASSWORD
Encrypted Viz Object Store password. Set it through the VOS change-password dialog, not here.
vos_allow_edit_from_dll
Enables/disables the Object Store toolbar for editing images and person information (Y/N).
vtw_disable_unique_name_check
Allows saving templates with the same name in different concepts in the legacy Template Wizard.
Pilot Data Server reads or maintains these parameters itself. Do not change them unless a Vizrt representative instructs you to.
Parameter
Description
app_server
Legacy hostname:port of the running Pilot Data Server. Set by the server at startup and kept for backwards compatibility – use data_server_url instead.
schema_version
Major version of the database schema. Read by the server on startup. Do not modify.
schema_build
Minor build version of the database schema. Do not modify.
vcp_schema_name
Database schema name (for example PILOT). Do not modify.
compatible
Internal schema/version compatibility marker. Do not modify.
model_uri_template
URL template the server uses to build the model-document link for a template. Used by the Maps Preview Server and certain external systems. Do not change.
payload_uri_template
URL template the server uses to build the payload-document link for a data element. Used by certain external systems. Do not change.
croptool_max_image_area
Maximum area (width × height, in pixels) of a cropped image served by the server; larger images are resized while keeping the crop aspect ratio. 0 = disabled. Safe for administrators to tune.
ax_add_itemchannel
When enabled, the server adds the element's default channel (itemChannel) to the generated MOS XML.
ax_add_dbdata_to_mosexternal
When enabled, the server adds the element's stored page data to the MOS item (used by some Mosart integrations).
mos_override_objtb
Overrides the <objTB> value in the MOS XML served by the server. Normally 50 or 60; setting it to 0 breaks the timing information in Playout Instructions.
mos_override_objtype
Overrides the <objType> value in the MOS XML for Pilot graphics elements. Default PILOT.
mos_override_objdur
Overrides the <objDur> value in the MOS XML for Pilot graphics elements. Default 1.
