Object Tracker User Guide
Version 1.2 | Published May 25, 2023 ©
Prerequisites
After installing Object Tracker and after enabling and configuring the server in Viz Arc, you should see a green light in the status bar and an additional TRACKING button on the left hand tool bar in the Viz Arc UI.
images/download/thumbnails/105109822/toolstracker.png images/download/thumbnails/105109822/snapstatusbar2.png
  • Load an appropriate scene on the renderer, a sample archive containing a scene can be found in the Viz Arc installation folder (C:/Program Files/vizrt/VizArc <version>/Resources/ObjectTracker).
  • Viz Engine needs to run on on Matrox based hardware.
  • Make sure you have the MezzIP Output license on the program Engine where the Object Tracker is running.
images/download/attachments/105109822/missinglicense.png
In case the license is missing or Viz Engine is offline, an error message appears as shown above.
