Object Tracker 1.5.0
Release Date: 2026-09-02
These are the release notes for Object Tracker version 1.5.0. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since release 1.4.0.
New Features
New backbone for detection, improving detection stability.
New backbone for pose tracking, improving pose tracking stability.
Detection and Segmentation — a new analysis mode combining object detection with segmentation.
Improvements
Overall speed and stability
UI fixes and simplifications
Engine compilation now waits for the GPU to go idle before building, so a busy GPU no longer results in a slower, suboptimal engine.
The installer now installs all required NVIDIA dependencies (CUDA, cuDNN, TensorRT) automatically — no need to install them independently.
The installer now automatically installs the Microsoft Visual C++ Redistributable and .NET 8 runtimes it needs — no manual download required.
Compatibility Notes
Object Tracker 1.5 is compatible with:
Viz Engine version 4.4.0 and later.
Viz Arc version 3.0.0 and later.
CUDA 13.0, TensorRT 10.13.3.9, and cuDNN 9.13.0 (previously CUDA 12.1 / TensorRT 8.6.1.6 / cuDNN 8.9.0).
An NVIDIA GPU with compute capability 7.5 or higher (Turing architecture and newer). Maxwell, Pascal, and Volta GPUs — e.g. GeForce GTX 900/10-series, Quadro P-series, Tesla V100 — are no longer supported.
NVIDIA display driver version 580.65.06 or later.
Documentation
Documentation for Object Tracker and related products are available on the Vizrt FTP and on the Vizrt Documentation Center:
Support
