Object Tracker 1.3.0
Release Date: 2024-04-10
These are the release notes for Object Tracker version 1.3.0. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since release 1.2.1.
Object Tracker allows tracking individual or multiple objects within a video to focus on the key parts of the action. This fully software-based and only requires video input.
Improvements
New detection backbone that improves detection results and reduces the global delay.
Added configuration presets: These enable assignment of each TrackingID to a different detection algorithm, the Object Tracker automatically activates the correct analysis when switching TrackingID. For example, ID 1 can be assigned to Detection&Tracking, while ID 2 can be assigned to Simple Tracker. The switch of analysis is seamless without the necessity of re-initialize the Object-Tracker.
A warning triangle appears every time a parameter is changed to point out that the analysis is not consistent with the current configuration.
Compatibility Notes
Object Tracker 1.3 is compatible with:
Viz Engine version 4.4.0 and later.
Viz Arc version 2.0.0 and later.
Documentation
Documentation for Object Tracker and related products are available on the Vizrt FTP and on the Vizrt Documentation Center:
Support
