Object Tracker Release Notes
Version 1.0 | Published June 09, 2022 ©
Object Tracker 1.0.1
Release Date: 2022-06-09
These are the release notes for Object Tracker version 1.0.1. This document contains a list of references to the new features, fixed issues and additional remarks regarding the user-visible changes that have been made to the software since release 1.0.0.
Fixed Issues
Added compatibility with NVIDIA Ampere graphics card family.
Simple Tracker picking target had a constant pixel offset.
Fixed crash when there was no valid SMURF stream on the Viz Engine.
Fixed potential crash after long sessions.
Improvements
Performance improvements on NVIDIA RTX graphics cards (~20%).
More stable and steady tracking output.
Removed some unnecessary console output messages.
Improved filter algorithm when objects overlap.
Object Tracker 1.0.0
Release Date: 2022-04-07
These are the release notes for Object Tracker version 1.0.0. This is the first release of Object Tracker.
Object Tracker allows tracking individual or multiple objects within a video to focus on the key parts of the action. This fully software-based and only requires video input.
Compatibility Notes
Object Tracker 1.0 is compatible with:
Viz Engine 4.3.0 and newer
Viz Arc 1.5.0 and newer
Tracking Hub 1.5.0 and newer
Documentation
Documentation for Object Tracker and related products are available on the Vizrt FTP and on the Vizrt Documentation Center:
Support
