![](assets/images/logos/MediaService.png)
Media Service User Guide
Version 3.0 | Published October 10, 2019 ©
Status and Logs
The log file, MediaService.log, can be accessed in the same location as the Media Service configuration files (normally _C:\ProgramData\Vizrt\Media Service_) which is accessible through the System Tray icon menu. The log file(s) will rotate when they grow big, retaining the last 9 log files.
The System Tray Icon will visually indicate the status or diagnostics of the running services.
The top part of the System Tray Icon represents the state of the Media Service service. Orange means it is running normally, gray means needs attention.
The lower part indicates the state of Coder and it’s helper-processes Coder Master and Coder Slave. Orange means running, gray means needs attention as explained in the table below.
Icon status |
Meaning |
All services running. This is the expected and normal status. If any parts of the icon is gray corrective action is recommended. |
No response or error from Media Service. |
No response or error from Coder Master. |
No responsive Coder Slaves reported from Coder Master. |
No response or error from Coder Master. No responsive Coder Slaves. |
If there is an error in Media Service, click the Tray Icon and consult the resulting pop-up window for more details about status. Click here for more information.
