Version 2.5 | Published March 06, 2024 ©
Supported NLE Systems
Versions other than those listed here are not officially supported, unless expressly stated in the documentation.
The following systems are supported:
Adobe Premiere Pro
Graphics Plugin for Adobe has been tested against, and supports the following versions:
Premiere Pro CC 2021 (15)
Premiere Pro CC 2020 (14). Limitations to metagraphics workflow have been found on versions 14.1.
Premiere Pro CC 2019 (13)
Note: This plugin works on both Windows and Mac machines.
Avid Media Composer
Graphics Plugin for Avid supports the following versions:
Avid Media Composer 2019
Avid Media Composer 2020
The following systems support the Avid Extensions (AVX) 2.0 System Development Kit (SDK):
Avid Digital Studio (DS).
Media Composer (Older Release and Post Adrenaline HD release that can run software only), Media Composer Adrenaline, and Media Composer Adrenaline HD.
Symphony and Symphony Nitris.
Xpress, Xpress Pro, and Xpress Pro HD.
Grass Valley EDIUS
Graphics Plugin for EDIUS supports the following versions:
EDIUS X
Note: The latest version supporting Edius 8 and 9, is version 2.3.1.
Note: This plugin only works on Windows machines.
Apple Final Cut Pro
Graphics Plugin for Final Cut works together with Apple Final Cut Pro X. This plugin only works on Mac-machines.
Quantel Rio
Graphics Plugin for Quantel works together with Quantel Rio 4.3, or later. Version 2.0 of Graphics Plugin supports earlier versions of Quantel QEffects/Rio (version 4.2).
