Datacenter 2.5.0
Release Date: 2025-11-03
These are the release notes for Datacenter version 2.5.0. This document describes the user-visible changes that have been made to the software since Datacenter 2.4.0.
New Features
  • DCE-77: The file reader data provider was extended to support XML files.
Improvements
  • DCE-69: Improved logging when using the Tracab data provider.
  • DCE-80: Improved browser cache handling, which removes the requirement of manually deleting the browser cache on version updates to get the latest UI changes.
Fixed Issues
  • DCE-67: Fixed issue with the Sportec data provider, which was not correctly handling cases where Sportec returned only one result for a request (for example, when the selected competition had only one match).
  • DCE-70: Fixed the memory leak when disabling an output and the receiving process was not reachable.
  • DCE-71: Fixed issue where Datacenter became unresponsive when the Tracab data provider was used, but Viz Arc was not running.
  • DCE-72: Fixed issue where activated add-on licenses disappeared in the license configuration.
  • DCE-78: Fixed issue where an error was shown when adding a new Dataset without a script.
  • DCE-84: Fixed several memory leaks and UI performance issues.
Known Issues
  • Stats Perform authentication fails when the server used to fetch time on the Datacenter machine differs by more than 60 seconds from the time of the Stats Performs servers (RZT-12115).
  • When having an active streaming dataset (for example, Tracab or Socket listener), the interaction with entries of other datasets (for example, adding a manual entry or copying an existing entry's value) may be hindered due to too frequent data updates (RZT-12200).
Licensing
Datacenter 2.5.0 requires a WIBU V3 software license.
Installing Datacenter
Install New Software (Required)
The setup file VizDatacenter-2.5.0.2749.msi installs all required files to run Datacenter. The installation requires the following steps:
Step 1: Remove Existing Datacenter Versions (Optional)
  • Remove any existing installation of the Datacenter (recommended).
Step 2: Install Datacenter
Info: Running the Datacenter 2.5.0 installer requires Admin privileges.
  • Locate the file VizDatacenter-2.5.0.2749.msi and double click it.
  • Follow the steps on screen and click the Install button when finished.
Step 3: Verify Datacenter's Installation
  • Make sure you have a valid Datacenter V3 WIBU license.
  • Navigate to http://127.0.0.1:5700 or double click on the Datacenter Desktop icon.
  • You should land on the following view (the Datasets list may be empty for a brand new installation):
Project Compatibility
Datasets created with versions older than 2.0.0, are not compatible with Datacenter 2.5.0.
Compatibility Notes
Datacenter 2.5.0 is compatible with:
Product
Version
Windows
Windows 10
Viz Engine
4.4.1 or newer
Viz Libero
8.2.0 or newer
Viz Arena
5.3.0 or newer
Viz Arc
1.7.0 or newer
Documentation
Documentation for Datacenter is available at the Vizrt Documentation Center:
Support
