AI Terminal User Guide
Version 1.0 | Published August 30, 2023 ©
Output
NDI Output
Use this output to integrate with other application capable of reading NDI.
Parameters
Name |
Type |
Explanation |
NDI Output |
Text |
Specifies the name of the NDI output. |
Image |
Image |
Specifies an image to be sent with this output. |
Errors and Warnings
Severity |
Text |
Potential Fixes |
Error |
Setup has failed. Revisit this outputs' configuration. |
Restart the computer. |
Error |
Initialization has failed. Revisit this outputs' configuration. |
Check that there is no other NDI signal generated on this computer with the same name. |
Error |
Failed to write output. |
Error |
Data does not conform with this output module's requirements. |
Make sure an image is assigned. The data provided by the tool does not conform with this output module's requirements. Check the tool's documentation for more information. |
Pose Data Sender
Use this sender to communicate detected pose data to the Pose Data Receiver Viz Engine Plugin (distributed with the Reality Connect tool).
Parameters
Name |
Type |
Explanation |
3D Positions |
3D-Positions |
Specifies the 3D positions to be sent with this output. |
Hostname |
Text |
Specifies the host address of the Viz Engine. |
Number of joints |
Number |
Specifies the number of joints contained in the pose. |
Port |
Number |
Specifies the communication port of the Viz Engine. |
Errors and Warnings
Severity |
Text |
Potential Fixes |
Error |
Error |
Check that the Viz Engine is running and has the same communication port configured as specified here. |
Error |
Check that the Viz Engine is running and has the same communication port configured as specified here. Check that the Viz Engine is configured with a valid UDP port (search the Viz Engine config for smm_udp_service). |
Error |
Position data does not conform with this sender's requirements. |
Make sure that 3D positions are assigned. The data provided by the tool does not conform with this output module's requirements. Check the tool's documentation for more information. |
