Vizrt Licensing 3.1.3
Release Date: 2024-09-24
These are the release notes for Vizrt Licensing version 3.1.3. This document describes the user-visible changes that have been done to the software since release 3.1.2.
Improvements
  • Introduced an additional permission for the Vizrt Licensing Department (T-164037).
  • Updated design on the Re-Hosting page (T-164035).
Vizrt Licensing 3.1.2
Release Date: 2024-08-20
These are the release notes for Vizrt Licensing version 3.1.2. This document describes the user-visible changes that have been done to the software since release 3.1.1.
Improvements
  • Order Number handling has been improved and does not have to be changed on each renewal (T-164049).
  • Updated the loading symbols to match Vizrt branding (T-164034).
  • Removed the “Cancellation Until” column from the License Admin view as it was a duplicate of the “End Date” column (T-164036).
  • The text on the column visibility button has been changed in the License View (T-164038).
  • Added an additional download option that allows creation of a License Container in an offline virtual environment (T-164029).
Fixed Issues
  • Fixed an issue where hitting the Enter Key during license creation immediately created the license (T-163061).
  • Fixed an issue where the Auto Update function was not working on Cloud / VM Environments (T-157452).
  • Fixed issue where it was not possible to change all features during license creation (T-164032).
Vizrt Licensing 3.1.1
Release Date: 2024-07-23
These are the release notes for Vizrt Licensing version 3.1.1. This document describes the user-visible changes that have been done to the software since release 3.1.0.
Improvements
  • The function buttons on the Admin Page have been moved from the Licenses section to the top (T-163064).
  • The default value for newly created licenses is set to "network" (T-163066).
  • The OrderID of the previous order is now displayed during the license renewal (T-163071).
  • The buttons in the Ticket section have been redesigned (T-163069).
  • The toggle between Online and Offline License Activation has a renamed button to match Vizrt's terminology (T-163067).
Fixed Issues
  • Fixed an issue where the displayed expiration date was one year after the actual expiration date (T-163099).
  • Fixed an issue where it was possible to create a license without selecting an expiration date (T-163062).
Vizrt Licensing 3.1.0
Release Date: 2024-04-22
These are the release notes for Vizrt Licensing version 3.1.0. This document describes the user-visible changes that have been done to the software since release 3.0.0.
Improvements
  • Implemented an Activation Summary Page during Activation/Auto Update.
  • Added a column visibility selector to the licenses page.
  • Added filter options to the licenses page.
  • Added the information about the ticket source to the Containers tab.
  • Added Drop-Down-Option to open and close individual containers to improve visibility.
  • Moved the Account Information to a separate menu.
  • Function buttons (Activate License, Auto Update,...) on the Licenses Page, are greyed instead of not displayed, if no license is available to use this function.
  • Added tooltips.
  • Simplified UI.
  • Updated the color scheme.
  • Updated the Vizrt logo.
Fixed Issues
  • Fixed issue where the License Quantity was not displayed.
  • Fixed issue where the License Expiration Date was not shown correctly.
  • Fixed issue where the "Select All" Checkbox stayed selected when removing the filter during activation.
  • Fixed issue that kept refreshing the browser on the licenses page when the CodeMeter Runtime software was not installed locally.
  • Fixed issue that caused old Permanent License features to restore the complete history of the license dongle / Software Container.
  • Fixed issue where the previously used "Reset Feature" restored the complete history of the license dongle / Software Container.
System Requirements
The following browsers are supported for online activation of licenses: Google Chrome, Mozilla Firefox and Microsoft Edge.
For a list of the supported products, see the System Requirements page in the Vizrt Licensing Admin Guide.
Documentation
Documentation for Viz Licensing is available at the Vizrt Documentation Center:
Support
Support is available at the Vizrt Support Portal .
