Viz World Release Notes
Viz World 23.0.0
Release Date: 2023-12-12
These are the release notes for Viz World 23.0.0. This document describes the user-visible changes that have been made to the software since release 22.0.0.
Functionality Removed or Changed
Summary |
Key |
Subfolders now correctly inherits the permissions of the klm/folder |
Improved quality of base map province borders for Iran and Afghanistan |
Known Issues
Viz World Server Launcher must run with elevated privileges to launch Viz World Server as a service (MAPS-5530).
Viz World Server must be restarted after manually scanning street data (MAPS-6275).
Viz World Server leaks memory when targeted by a port scan (MAPS-5597).
When editing multi-hop scenes, it is possible to select Favorites. This is not intended functionality, and it causes errors if you do (MAPS-6319).
Styles with names including non-English letters can exhibit bugs (MAPS-5714). Workaround: Use English letters only.
Favorites with names including the plus symbol + can exhibit bugs (MAPS-5731). Workaround: Avoid the use of the plus symbol.
If the MapService.Service process is running, it must be manually stopped before uninstalling Viz World Client (MAPS-5902).
Viz World Server Classic crashes when using trail ahead with slide out animation (MAPS-7608).
Viz World Server restarts when loading street data (MAPS-7606).
This has also been observed after data is loaded and the Streets tool is selected.
Rendering issue (land color covers ocean) in Stereographic projection (MAPS-7609).
Compatibility Notes
Viz World 23.0.0 was tested with:
Viz Engine 5.1.1
Viz Engine 4.4.1
Viz Engine 3.14.5
Viz Pilot 8.9.1
Viz Pilot Edge 3.0.0
Viz Pilot Data Server 9.0.0
Viz Trio 4.2.0
Documentation
Documentation for both Viz World and Viz World Classic are available at the Vizrt Documentation Center:
Support
