Viz World User Guide
Installing Viz World Server
Note: Before starting an installation, ensure that the Viz World Server USB license dongle and license file are available. If the license is MAC address based, only a license file is required.
The Viz World Data and Viz World Server installers are required.
To Install Viz World Data
Start the Viz World Data installer VizWorldDb23.0.0.msi.
Click Next.
Select the features to install. Combination and Relief are mandatory features while Extras is optional (Extras feature contains UK MapData with Metropolitan counties of England to be imported as street data if required).
Click Install to begin the installation.
Click Finish.
To Install Viz World Server and Classic
Before Viz World Classic is installed, you have to install Viz World Data.
Viz World Server and Classic may run in a virtualized environment.
Note: The licensing dongle does not show up when connecting to the machine with Remote Desktop (RDP). Instead, use a different remote access technology.
Note: Exit all Windows programs before running the Setup Program.
Start the Viz World Server installer VizWorld23.0.0.msi.
Click Next.
Read the End-User license agreement and accept it.
Click Next.
Select destination directory, and click Next. Default installation directories are:
32-bit: C:\Program Files (x86)\Curious Software\Curious World Maps
64-bit: C:\Program Files\vizrt\Viz World
Click Install to start the installation.
Click Finish.
Optional: Install QuickTime if it is not previously installed. If a newer version of QuickTime is installed the installation stops.
Tip: If you do not already have QuickTime installed, you can download the installer from the Apple website.
