Viz Vectar Plus User Guide
Version 1.2 | Published April 12, 2022 ©
Installation Requirements
Hardware
  • Graphics
    • nVidia Board that supports
      • NVenc and NVdec
      • Cuda
    • For Vectar Plus Viz Engine requires
      • nVidia board with OpenGL support
      • Minimum of 6GB of memory for UHD resolutions
  • Disk Space
OS
  • Windows 10 Build 1809 or higher
  • Windows Server 2019 or higher
Upgrading
  • Uninstall any previous version of Viz Vectar Plus before installing the new package.
  • All local settings and configurations are automatically saved and reapplied after an upgrade.
Installation Procedure
Installation has two flavors, a PC-based switcher, or a PC-based switcher with one or two instances of a rendering engine, Viz Engine.
  1. Remove any existing instances of Viz Vectar Plus.
  2. Download your installation software from the Vizrt FTP https://download.vizrt.com/
    under /products/VizVectarPlus/LatestVersions/
  3. Follow steps in the Installation Wizard.
Licensing
For Viz Engine installations, please refer to section Licensing.
Documentation
