The trio:wait
macro command is useful to hold execution flow for some time. The waiting time is specified as a mandatory argument and is set in milliseconds:
trio:wait
5000
Unlike the trio:sleep
command, trio:wait
does not block other commands execution.
It is recommended to use trio:wait
in all cases, where a delay in script or macro execution is required. trio:sleep
is now considered deprecated while kept for backward compatibility, and specific cases.
Controlling Post-Execution Waiting Times for Macro Commands
Various setups may have their own latency in terms of how much time it takes to finish execution of a certain command.
It is a common practice to use the trio:sleep
command to wait until the right time, while executing a macro or a script. A typical application in the macro would look like this:
======== MyMacro1 ========
page:read
1002
trio:sleep
2000
This code can be interpreted as "read the page 1002 and wait for 2 seconds”, assuming this would be enough time for the page to be read.
Each time a user adjusted the waiting time period, the corresponding lines would have to be modified for all macros and scripts, in all shows (for example, changing the 2000 value to 3000).
Since Viz Trio 4.4, there is the possibility to control waiting times from one place, without modifying existing macros and scripts.
Trio Folder
In the Viz Trio folder (C:\\Program Files\\Vizrt\\Viz Trio), you can find the trio.config
file, an XML configuration file that can be used for centralized control over command waiting times.
Edit the file's content, save it, and then restart Viz Trio to apply the new configuration.
Using the example above, this is the following configuration:
xml
version
"1.0"
configuration
commands
command
name
"page:read"
delay
"2000"
commands
configuration
The configuration specifies that any call to the page:read
command from any macro or script, is followed by a wait time of 2000 milliseconds. Therefore, if we use this configuration with the macro example mentioned previously, the overall waiting time is 4000 milliseconds (2000 milliseconds done automatically by Viz Trio, and an additional 2000 milliseconds requested by trio:sleep
It is recommended to remove the direct waiting command, so the updated MyMacro1 resembles the following:
page:read
1002
Adjusting Post-Execution Waiting Times
Any Viz Trio command's post-execution waiting time can be adjusted in the configuration file.
Info:
Specify the full command name (with the namespace format
namespace:command
) in the configuration file.Viz Trio uses a "non-intrusive" method for post-execution waiting (running the
trio:wait
command each time it needs to wait). Please refer to thetrio:wait
description for more information on its behavior.By default, when a command is not mentioned in the
trio.config
file, the post-execution waiting time is zero. There is no benefit using negative delay values.If the
trio.config
file content is damaged and violates XML rules, it is ignored by Viz Trio.
Overall Guidelines
Identify which commands require waiting time adjustments.
Modify the content of the
trio.config
file in a text editor, to include a separate command tag for all necessary commands:<
command
name
"fullcommandname1"
delay
"2000"
command
name
"fullcommandname2"
delay
"500"
command
name
"fullcommandname3"
delay
"1000"
Save the
trio.config
file.Modify macros and/or scripts to remove
trio:sleep
calls after these commands. Ensure your changes to macros and/or scripts are saved.Restart Viz Trio.
Note: If you have several scripts and don't want to modify them, you can still set the waiting time for commands in trio.config
. However, you may need to be more conservative with the waiting time values set in the configuration, as they are added to times specified in existing trio:sleep
calls.
