Viz Ticker 4.2.0
Release Date: 2025-01-30
These are the release notes for Viz Ticker version 4.2.0. This document describes the user-visible changes that have been made to the software since release 4.1.1.
WIBU Licensing
From Viz Ticker version 4.2.0, the product is under WIBU licensing and requires either a license server or license file to register as being fully licensed.
New Features
  • Ticker Service is now a reimplemented 64-bit Windows service.
Improvements
  • Custom buttons indicate their status by showing green if all custom logic states are true.
  • Elements in carousel now have fixed height to remove visual resizing when selecting and deselecting elements.
Fixed Issues
  • Viz Ticker Wizard component now supports Viz Engine 5.
  • Branding of playing and selected elements use the classic color scheme again.
  • System Tool no longer fails to delete a channel even if there is a lack of /sys/gpi node in the stored data structure. The data is also force-set when creating a new channel.
  • When using an updated Media Sequencer, the Viz Ticker Feed no longer resets message count upon receiving an edited version of a message.
Changed Features
  • Logging and storing of settings files are moved from user-specific log-location to %ProgramData%/Vizrt/Viz Ticker/ with a sub-directory per component.
Installation and Upgrading
Uninstall the previous version before upgrading to new version. Install each component where needed and follow the instructions as seen in the dialogs shown.
System Requirements
The Viz Ticker system consists of:
  • Viz Ticker Client
  • Viz Ticker Web Client
  • Viz Ticker Wizard
  • Viz Ticker System Tool
  • Viz Ticker Feed
  • Viz Ticker Service
The Viz Ticker system requires the following minimal software versions:
  • Microsoft .NET Framework 4.8 or later
  • Viz Engine 3.14 or later
  • Graphic Hub 2.3.1 or later
  • Graphic Hub REST 1.1 or later
Note: Graphic Hub REST 2.0 (or later) is required for the VTW image search functionality.
Note: Graphic Hub REST is only required if message templates are using tab-fields pointing to Graphic Hub resources or if using the VTW image search functionality with Graphic Hub as search provider storage.
  • Media Sequencer 2.0 or later
Caution: Avoid using Media Sequencer 3.1.0 because of a known issue with the background scene reference in that version.
Operating systems that have reached their end-of-life cycle and are no longer officially supported by their manufacturers are not supported for use with Viz Ticker.
System Requirements for Viz Ticker OneBox
The Viz Ticker OneBox system requires the following versions of Viz Engine:
  • 3.14.5 or above on the 3.x release line, or
  • 4.3.0 or above on the 4.x release line, or
  • 5.x.x or above on the 5.x release line.
If Viz Ticker OneBox is not enabled, see the requirements above.
Documentation
Documentation for Viz Ticker is available at the Vizrt Documentation Center:
Support
