The following keyboard shortcuts can be used to operate Viz Ticker:
Viz Ticker Client and Ticker Wizard
Function | Key + Mouse Combination |
Selects the next tab in the Main Menu | CTRL + TAB |
Viz Ticker Client’s Pool Frame
Jumps to the Pool Search text box | CTRL + F |
Copies currently selected messages | CTRL + C |
Cuts currently selected messages | CTRL + X |
Deletes currently selected messages | DELETE |
Opens a new message in Elements Editor based on the default template | CTRL + N |
Opens the Select Template dialog box, where any available message template can be selected | CTRL + T |
Pastes messages | CTRL + V |
Selects all messages | CTRL + A |
Viz Ticker Client’s Carousel Frame
Activates the Find text box in the Carousel Search | CTRL + F |
Activates currently selected messages | INSERT |
Deactivates currently selected messages | CTRL + INSERT |
Viz Ticker Client’s Elements Editor
Saves the current element | CTRL + S |
