Viz Pilot Edge Release Notes
Version 2.3 | Published November 03, 2022 ©
Viz Pilot Edge 2.3.0
Release Date: 2022-04-11
These are the release notes for Viz Pilot Edge and Template Builder versions 2.3.0. This document describes the user-visible changes that have been made to the software since release 2.2.0.
Release Highlights
The ability to write to the control field will allow even greater speed, flexibility and customization of the fill-in form. Leveraging functionality like the Fetch API will allow resources to be retrieved asynchronously across the network such as a JSON object, which could then be parsed and used in the fill-in form.
Adding support for Oracle DB backend with a new Oracle schema.
We are adding 2 testing endpoint APIs to Viz Pilot Data Server 8.9 to assist in training and to experiment the new functionality.
Please use the following:
HTTP://<PDS-HOST>:8177/testing/fakepremierleague/
HTTP://<PDS-HOST>:8177/testing/fakepersonsearch/
Note: The release notes for Template Builder can be found in both Pilot Edge and Template Builder. In future versions they will be merged into Pilot Edge.
Changes and New Features
Error messages when opening a template are now more explicit (VPE-4364).
Custom layout tooltips look better (VPE-4440).
Added support for emojis in data element names (VPE-4402).
Preserve "Find Media" > "Tags" user selection between sessions (VPE-3460).
Template Builder:
Scripting: It is now possible to change field values from the script. Please check Viz Pilot Edge User Guide for more information (VPE-4346).
Error messages when saving a template are now more explicit (VPE-4366).
It's now possible to delete templates using the template list right-click menu (VPE-2846).
Custom layout date fields are now resizable (VPE-4406).
The Mosart Timing custom HTML panel sample has been updated (VPE-4059).
It is now possible to resize the FieldID column (VPE-3539).
Fixed Issues
Maps in a library element on a video timeline, will now display correctly (VPE-4357).
Fixed an issue where the wrong template was selected, when clicking from the template list (VPE-4393 & VPE-4204).
Fixed an exception that could occur after adding a child field to a template that already has data elements (VPE-4409).
Hidden fields in a library data element will still be hidden when viewed from a video timeline (VPE-4408).
Empty asset fields and empty map fields in a library data element won't trigger an error when viewed from a video timeline (VPE-4419).
Fixed an issue that could truncate the content of multiline fields with a max length (VPE-4392).
Improved behavior when trying to type in a field that doesn't have space for more characters (VPE-3952 & VPE-4399).
Fixed an issue where white bars were added around thumbnails of portrait images to make them landscape (VPE-4230).
Fixed a bug where the tags dropdown was not displaying in media search (VPE-4368).
Videos are now properly unloaded when closed (VPE-4460).
Minor improvements for the asset tag selector (VPE-4427 & VPE-4311).
Improved error message when an image High Resolution Preview fails (VPE-4414).
The Find Media / Find Graphics tabs won't close if you drag an element inadvertently (VPE-4407).
Data elements opened from an iNews story won't have to be closed twice (VPE-4448).
First-time opening a data element in iNews now works (VPE-4352).
Keyboard navigation for choice drop-down now works (VPE-3713).
Timeline shortcuts Ctrl+left/right now works on Mac (VPE-3865).
Searching for a data element that contains ¶ now works (VPE-4387).
Template Builder:
Made sure the Script Editor suggestions are always visible (VPE-4450).
CTRL + SHIFT + S shortcut wrongly allowed "Save As" when the corresponding icon was disabled (VPE-3814).
Automatic changes/updates made when opening a template are now clearly indicated with a message to the user (VPE-3982).
Users weren't able to leave the Script Editor once tabbed into it (VPE-4324).
Setting a value to hidden using the script was interfering with the "hide/show all fields" button (VPE-4343).
System Requirements
Hardware
There are no known hardware limitations for Viz Pilot Edge and Template Builder, other than requirements stipulated by newsroom systems hosting the client.
Software
Vizrt components:
Pilot Data Server 8.9.0
Graphic Hub 3.6.0 (with Graphic Hub REST 2.6.0)
Preview Server 4.5.0
Viz Artist 4.2.0
Viz Engine 4.2.0
Note: Viz Artist 4.2 and Viz Engine 4.2 are required for transition logic and combo template support. See Setup and Configuration > Configuring Viz Artist in the Template Builder User Guide.
Note: TGA image support requires a codec program like https://www.fastpictureviewer.com/codecs/, to be installed on the same machine as crop service.
Browser
If running Viz Pilot Edge inside a browser, these are the tested browsers:
Chrome Version 99.0.4844.82 (Official Build) (64-bit)
FireFox 96.0.3
Safari is 14.1.1
Safari 9
MS Edge Version 99.0.1150.55 (Official build) (64-bit)
Newsroom Systems Used for Testing
iNEWS 7.7.0.14
ENPS 9.0.177 (Browser type Internet Explorer)
Open Media 4.4.4359
Octopus X (see also Known Issues above)
Upgrading
When upgrading from a previous version of Pilot Edge, the previous version may still be presented by the host browser for a short time due to client side caching. To prevent this, clear the host browser cache. If you are using the default Internet Explorer host, open Internet Explorer, press CTRL + SHIFT + DEL, select Temporary Internet files and website files and click DELETE.
Important Notes
If there are any issues with map fields when running in Microsoft Internet Explorer 11 +, remove include all local sites not listed in other zones and turn off detection of intranet zones in the IE11 policy settings (VPE-2329).
Documentation
Documentation for Viz Pilot Edge, Template Builder and related software is available at the Vizrt Documentation Center:
Support
