Viz Pilot Edge Release Notes
Version 2.1 | Published April 14, 2021 ©
Viz Pilot Edge 2.1.0
Release Date: 2021-04-14
These are the release notes for Viz Pilot Edge version 2.1.0. This document describes the user-visible changes that have been made to the software since release 2.0.0.
Changes and New Features
In a custom layout, you can now browse for assets by clicking anywhere in their container (VPE-3921).
Fixed Issues
Hidden fields won't receive focus (VPE-3825).
Improved fields focus when using keyboard navigation (VPE-3824).
Tempered visual artifacts when closing a template containing a custom layout (VPE-3781).
No more blank space and scrollbar after resizing the browser window (VPE-3831 & VPE-3934).
Context menus, number sliders, and date pickers respond better when used in multiple tabs (VPE-3748).
Improved custom layout responsiveness (VPE-3797 & VPE-3935).
Read-only map thumbnails now display correctly (VPE-3891).
Known Issues
4K resolution images are not supported in Octopus 8 and Octopus X due to memory constraints (VPE-2412).
System Requirements
Hardware
There are no known hardware limitations for Viz Pilot Edge, other than requirements stipulated by newsroom systems hosting the client.
Software
Vizrt components
Pilot Data Server 8.6
Preview Server 4.4.1
Viz Engine 4.2.0
Viz Engine 3.14.5
Note: Viz Engine 4.2.0 is required to enable support for transition logic and combo templates.
Note: TGA image support requires a codec program like https://www.fastpictureviewer.com/codecs/ to be installed on the same machine as crop service.
Browser
If running Viz Pilot Edge inside a browser, the following minimum requirements apply:
Microsoft Internet Explorer 11 +
Chrome 64 +
Safari 11.0 +
Newsroom Systems Used for Testing
iNEWS 7.7.0.14
Octopus 8.3 (see also Known Issues above)
ENPS 9.0.177 (Browser type Internet Explorer)
Open Media 4.4.4359
Octopus X (see also Known Issues above)
Upgrading
When upgrading from a previous version of Pilot Edge, the previous version may still be presented by the host browser for a short time due to client side caching. To prevent this, clear the host browser cache. If you are using the default Internet Explorer host, open Internet Explorer, press CTRL + SHIFT + DEL, select Temporary Internet files and website files and click DELETE.
Important Notes
If there are any issues with map fields when running in Microsoft Internet Explorer 11 +, remove include all local sites not listed in other zones and turn off detection of intranet zones in the IE11 policy settings. (VPE-2329)
Documentation
Documentation for Viz Pilot Edge is available at the Vizrt Documentation Center:
Support
