Viz Pilot Edge Release Notes
Version 1.6 | Published July 10, 2020 ©
Viz Pilot Edge 1.6.1
Release Date: 2020-07-10
These are the release notes for Viz Pilot Edge version 1.6.1. This document describes the user-visible changes that have been made to the software since release 1.6.0.
Changes and New Features
Fixed Issues
System Requirements
Hardware
There are no known hardware limitations for Viz Pilot Edge, other than requirements stipulated by newsroom systems hosting the client.
Software
If running Viz Pilot Edge inside a browser, the following minimum requirements apply:
Microsoft Internet Explorer 11 +
Chrome 64 +
Safari 11.0 +
Upgrading
When upgrading from a previous version of Pilot Edge, the previous version may still be presented by the host browser for a short time due to client side caching. To prevent this, clear the host browser cache. If you are using the default Internet Explorer host, open Internet Explorer, press CTRL + SHIFT + DEL, select Temporary Internet files and website files and click DELETE.
Important Notes
If there are any issues with map fields when running in Microsoft Internet Explorer 11 +, remove include all local sites not listed in other zones and turn off detection of intranet zones in the IE11 policy settings. (VPE-2329)
Viz Pilot Edge 1.6.0
Release Date: 2020-05-28
These are the release notes for Viz Pilot Edge version 1.6.0. This document describes the user-visible changes that have been made to the software since release 1.5.1.
This release includes a major update of Template Builder.
Added the ability to sort Templates by modification date. (VPE-3120 )
Added support for automated opt-in collection of anonymized usage metrics, if used with Pilot Data Server 8.5 or above. (VPE-2810)
Auto-generated data element titles will now ignore " <unspecified>" values. ( VPE-3003)
Added support for native spellchecking in normalized text fields. (VPE-3287)
Fixed Issues
MOS fields <description> and <mosAbstract> are no longer truncated to 128 characters. (VPE-3245)
Note: The auto generated title on save is capped at 200 characters. If a title generation string is specified, the 200 character limit does not apply. Director may still show truncated descriptions in the MOS playlist, as the Media Sequencer uses the <objSlug> field to populate the "description" attribute.
Opening Viz One MOS objects without media now gives a dialog instead of an error message. (VPE-2486)
Refreshing the data element list after clicking "Show more" now works properly. (VPE-3208)
System Requirements
Hardware
Software
Chrome 64 +
Safari 11.0 +
Upgrading
Important Notes
Known Issues
Graphic elements in timelines created using the Pilot Edge plug-in in OpenMedia do not appear in Director's MOS playlist. (VPE-2193)
In Octopus 8, images of 4K resolution and above are not supported due to memory constraints. (VPE-2412)
In Octopus 8, keyboard navigation via TAB does not work reliably due to constraints in Octopus. (VPE-2615)
Documentation
Documentation for Viz Pilot Edge is available at the Vizrt Documentation Center:
Support
