Viz Pilot Edge User Guide
Version 1.1 | Published January 31, 2018 ©
Keyboard Shortcuts
The most important keyboard shortcuts in Viz Pilot Edge are the ones used in the timeline editor. They allow the user to navigate and make edits within the video clip.
Keyboard shortcut information is available clicking the
button in the timeline editor.
The following keyboard shortcuts are available:
Action |
Shortcut |
Move 1 frame back |
, (comma) |
Move 1 frame forward |
. (period) |
Move 10 frames back |
Shift + M |
Move 10 frames forward |
Select previous item |
Select next item |
Delete on selection |
Backspace or Delete |
Mark In point |
I |
Mark Out point |
O |
Play backward - press multiple times to increase speed |
J |
Play forward - press multiple times to increase speed |
L |
Play backward at 0.5x speed |
Alt + J |
Play forward at 0.5x speed |
Alt + L |
Pause playout |
K |
Mute |
M |
Play/pause |
Space |
Go to In point |
Shift + I |
Go to Out point |
Shift + O |
Zoom timeline |
Shift + scroll |
Pan timeline |
H + drag |
Move selected item left by 1s |
Ctrl + ← |
Move selected item right by 1s |
Ctrl + → |
Move selected item left by 10s |
Ctrl + Shift + ← |
Move selected item right by 10s |
Ctrl + Shift + → |
Grow selected item by 1s |
Ctrl + Alt + → |
Shrink selected item by 1s |
Ctrl + Alt + ← |
Grow selected item by 10s |
Ctrl + Alt + Shift + → |
Shrink selected item by 10s |
Ctrl + Alt + Shift + ← |
A Log Window displaying Messages, Warnings and Errors becomes available using shortcut: Alt + 1.
