Mosart Web Applications Guide
Version 1.7 | Published March 14, 2024 ©
Mosart Web Applications are value-adding utilities and plugins that simplify working with Viz Mosart.
Mosart Web Applications are not part of a standard Viz Mosart delivery.
The following Mosart Web Applications are available:
Download
Collect the latest software bundle from Vizrt's customer FTP at https://download.vizrt.com/
by navigating to /products/VizMosart/Latest Version/WebApplications/.
Note: If upgrading, make sure an existing instance of the Mosart Web Applications Configuration Tool is not open.
Installation
The Mosart Web Applications bundle shall be installed on the Viz Mosart server.
Run the downloaded file MosartWebApplications.Bundle-n.n.n.n.exe.
The web applications that will be installed are listed.Note: The Installer places two applications on the local machine
Vizrt Mosart Web Applications
Vizrt Mosart Web Applications Configuration Tool
Click Install.
Any previously installed versions of the Mosart Web Applications are automatically upgraded. -
After successful installation, a Mosart Web Applications Configuration Tool automatically displays.
Note: A desktop shortcut to Mosart Web Applications Configuration Tool is added by default.
Port settings (optional)
Where security policies restrict ports firewall ports, these are the necessary port numbers for Mosart Web Applications:-
Web Apps REST API
HTTP: 55142.
HTTPS: 55143. -
Remote Control Service (Used by the Timing Display and Rundown Viewer)
HTTP: 55167.
HTTPS: 55168.
For further setup, follow the Configuration sections of the Setup and Administration for the different Web Applications, NRCS Plugin, Timing Display and Rundown Viewer.
Related Documents
Viz Mosart User Guide: Contains information on how to use Viz Mosart in live production.
For more information about all of the Vizrt products, visit:
Feedback and Suggestions
Legal
Copyright © 2024 Vizrt. All rights reserved.
Disclaimer
Antivirus
Vizrt does not recommend or test antivirus systems in combination with Vizrt products, as the use of such systems can potentially lead to performance losses. The decision for the use of antivirus software and thus the risk of impairments of the system is solely at the customer's own risk.
There are general best-practice solutions, these include setting the antivirus software to not scan the systems during operating hours and that the Vizrt components, as well as drives on which clips and data are stored, are excluded from their scans (as previously stated, these measures cannot be guaranteed).
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
