Viz Mosart Web Applications Release Notes
Version 1.4 | Published August 05, 2022 ©
Viz Mosart Web Applications is a growing suite of modern, browser-based utilities, designed to enrich Mosart workflows.
Current Version
The current version of Viz Mosart Web Applications is 1.4.
To download this version, please visit https://download.vizrt.com/ → / products/VizMosart/Latest Version/WebComponents/
Included Applications
The latest installer contains the following applications:
Key features
HTTPS support
The Web Applications suite supports HTTPS authentication for the applications running under it, with a centralized interface to help with certificate configuration. Note that depending on the application, some additional configuration may be needed in connected applications (e.g. Mosart itself) to enable HTTPS communication.
images/download/attachments/105087792/image2022-7-25_15-17-38.png
Previous Versions
None.
Supported System Requirements
  • Microsoft Windows 10 (runs on the same machine as the Viz Mosart server)
Support
