 Viz Mosart User Guide
Version 5.6 | Published April 04, 2024 ©
Template Router Keys
You can re-route a template to an alternative end point, through an accessory, often to a new crosspoint.
Note: Template Router is the new name for what was previously called Wall Manager. This is a pure name change, the functionality has not changed.
Working with Template Router Buttons
Example Workflow
As an example, you can create a template router keyboard button that re-routes any template that is dragged onto it, to a screen in the studio (This is achieved by defining the crosspoint for the studio screen in to the button).
An operator can then drag a template (for example a PACKAGE) on to the new template router button. The template is then merged with the Accessory template (here a studio screen) that is allocated to the button. The original package content displays on the screen.
Creating a Template Router Button
To Create a Template Router Button
-     From Viz Mosart main menu, select Tools > Keyboard shortcuts.
-     Choose which keyboard button (for example F8, or as in this example, R) to work with.
-     Click the blue arrow (in this example, next to ACCESSORY).
-     Select the option Template Router Button > Accessory merge.
-     Attach an Accessory template from the drop-down list of alternatives.
-     Click Save.
For further details about Accessory templates in the section Template Router.
Note: The section Template Router also describes how you can modify button placement inside the Template Router canvas.
