Viz Mosart User Guide
Version 5.4 | Published February 28, 2024 ©
Viz Mosart User Interface
The Viz Mosart GUI (Multi GUI) is the main control interface for operators and can be customized to suit your workflow.
  • You run the GUI either on the Mosart server or with one or more GUIs connected over the Mosart server network.
  • A common customization is having user action shortcuts on a separate touch-enabled screen, detaching the keys to a floating window.
    View > Floating windows > Function buttons.
The areas of the Viz Mosart GUI are described in the following sections:
images/download/attachments/140806284/image-2023-9-18_15-20-31.png
In addition, the following editors/panels can also be opened or configured as part of the layout:
