Version 5.4 | Published July 22, 2024 ©
ti_templateimplementation
The table ti_templateimplementation contains the gallery specific template implementation as created by the Mosart template editor (i.e. this information is gallery dependent).
Name |
Type |
Allow Null |
Description |
ti_recno |
integer |
No |
Primary key. |
ti_te_recno |
integer |
No |
Foreign key referencing the corresponding template te_recno in the te_template table. |
ti_ga_recno |
integer |
No |
Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table. |
ti_xml |
longtext |
Yes |
The actual xml-formatted template implementation as created by the Mosart template editor. |
Information: The template implementation must be created per gallery and is stored using its native XML representation, as received from the Mosart template editor
