te_template
The table te_template contains the individual templates with information that is shared among all galleries.
Note that information regarding a single template is divided into three parts / tables:
te_template: Contains basic template information. This information is shared among all galleries (i.e. gallery independent).
td_templatedescription: Contains typically template information to be presented to users that is gallery dependent.
ti_templateimplementation: Contains the template implementation as created by the Mosart template editor. This information is gallery dependent.
Name |
Type |
Allow Null |
Description |
te_recno |
integer |
No |
Primary key. |
te_ts_recno |
integer |
No |
Foreign key referencing the corresponding template set in the ts_templateset table. |
te_tt_recno |
integer |
No |
Foreign key referencing the corresponding template type in the tt_templatetype table. |
te_variant |
varchar(32) |
No |
The Mosart template variant. |
te_description |
varchar(128) |
Yes |
Optional template description. |
te_hidden |
smallint |
Yes |
Set to true (1) if this template is to be hidden from any user presentations. |
te_name |
varchar(128) |
Yes |
Optional template name. |
te_sendtoncs |
smallint |
Yes |
Set to true (1) if the template implementation is to be sent to NCS. Used by some NCS only. |
