Gateway Administrator Guide
Version 5.1 | Published June 04, 2018 ©
Common sources of error
NCS and MOS ID’s are case-sensitive (check the newsroom system and Gateway).
Gateway must be restarted after configuration changes.
Software or hardware firewalls are blocking connections. Verify that the gateway has connections to all newsroom systems and control stations.
