About Actions
Actions, such as Viz Commands and GPI Functions, can automate certain tasks. For example, Viz commands can be used to:
  • Take specific pages on air.
  • Clear specific render layers.
  • Send Stop, Continue, Start and other commands to a specific render layer.
Viz commands are created globally, and can be used on all defined channels.
Note: All commands must first be defined using the Viz Channel Branding client, in order to be available as secondary events.
Defining Actions
To define secondary event actions
  1. Click Actions
    • Predefined commands are displayed:
  2. Right-click one of the actions and select New Viz Command or New GPO Command
  3. In the dialog box enter:
    • Description is the descriptive term that is seen in the Actions list, as well as any drop-down list in the Rules and GPI settings panels.
    • Command is the actual command line sent.
    • Name is a pre-generated name based on type selected (for example viz_newcommand) that is verified as unique upon generation and may be changed into something more descriptive. Name is the value used for scheduling (as “page name”’).
  4. Click OK.
Note: For more information about Viz Commands, consult the Viz Command documentation included with your Viz Engine/Viz Artist installation.
Referenced Actions
Each occurrence of a Viz or GPI action in a playlist is independent, and editing it from within the playlist will only change that specific instance.
However, you can set up a playlist in such a way as to allow for last-minute global changes by associating referenced actions to primary events. In such a use case, an action is associated by reference to primary events in the playlist. When the action has been changed, either in the actions list (left panel) or by double-clicking on one of the referenced actions in the actual playlist, all occurrences in all playlists in the current channel are changed both retroactively and henceforth.
To create a referenced action
  1. Use an existing action or create a new one.
  2. Press and hold Alt + drag and drop the action to the playlist.
    The action will receive the following icon:
