General
Viz Arc's scripting has many classes and types that are exposed and accessible via code. The script's main class is called arc and it exposes all the functions that are capable of interacting with the remaining parts of Viz Arc as well as many helper functions. All of arc's functions can be accessed via scripting by calling them directly, since they are all exposed directly to the global script, or via the arc keyword.
The following samples and codes snippets are all written using the V8 JavaScript syntax:
Accessing Viz Arc Functions
// Getting a reference to an action called VersusTemplate
var versus = arc.GetAction("VersusTemplate")
var versus = GetAction("VersusTemplate")
Note: You can also find this section in Viz Arc by selecting the Help button in the script section when in edit mode.
Action
All actions in the current project can be accessed using the GetAction method, whose content can be manipulated. See Action Properties for more details.
  • BaseAction GetAction (string actionNameOrGUID)
    • Returns the first action found with the name provided. When a valid GUID is provided as a string, it returns the action found with the provided GUID.
  • BaseAction GetAction (string actionName, string tabName)
    • Returns the first action found with the name provided inside the action tab named tabName.
  • BaseAction GetActionByName (string actionName)
  • BaseAction GetActionByName (string actionName, string tabName)
  • BaseAction GetActionByUUID (Guid actionUUID)
    • Returns the first action found with the provided GUID.
  • BaseAction[] GetSelectedActions ( )
    • Returns an array containing all the actions that are selected on the action canvas
  • BaseAction[] GetActionsOfTab (string tabName, string actionType = "ALL")
    • Returns an array with all the actions inside the tab named tabName of type equal to the one provided in actionType input. Default value ("ALL") includes all actions found.
  • BaseAction[] GetActions (string actionType = "ALL")
    • Returns an array with all the actions of the entire project of type equal to the one provided in actionType input. Default value ("ALL") includes all actions.
GetAction Example
// Getting a reference to an action explicitly by its name "VersusTemplate"
var versus = GetActionByName("VersusTemplate")
// Getting a reference using a GUID
var versus = GetAction("e87a8031-a86b-4997-a169-c6f791920449")
// Getting all NDI actions
var nidActions = GetActions("NDI")
Playlist
arc provides an alternative way of getting a BaseControlObject from a ControlObject/Blueprint action.
  • void ExecuteSelectedPlaylistRow ( )
    • Executes the selected row on the playlist.
  • void ExecuteSelectedPlaylistRowAndNext ( )
    • Executes the selected row on the playlist and changes selection to the next row.
  • void PreviewSelectedPlaylistRow ( )
    • Previews the selected row on the playlist.
  • BaseAction GetSelectedPlaylistRowAction ( )
    • Returns the action that's attached to the selected row on the playlist.
  • void SetSelectedPlaylistRow (params string[] path)
    • Tries to find the row at path (path should contain a string per depth level) and makes it the selected row.
Playlist Example
// Selects the row at "StatsDisplayGroup/AwayTeam/Show" and then previews and executes it.
SetSelectedPlaylistRow("StatsDisplayGroup", "AwayTeam", "Show")
PreviewSelectedPlaylistRow()
ExecuteSelectedPlaylistRowAndNext()
Control Object
  • BaseControlObject GetControlObject (ControlObjectAction action, string id)
    • Returns the control object with a specific ID from ControlObject action.
Getting a Specific ControlObject from a ControlObjectAction
// Get the ControlObject Action
var MatchDayAction = GetAction("MatchdayTable")
// Get Title ControlObject (ControlText) and change its value
GetControlObject(Co, "Title").Value = "Sunday Fixtures"
// Get the Blueprint Action
var HeadlineBp = GetAction("HeadlineBp")
// Get Title ControlObject (String Variable) and change its value
GetControlObject(HeadlineBp , "Title").Value = "Lorem Ipsum"
MIDI
Attached and configured MIDI devices can be used to receive MIDI events using the OnMIDIEvent callback. It's also possible to send MIDI events to an attached device using the following methods:
  • bool SendMIDIControlMessage (string DeviceName, int Channel, int Number, int Value)
    • Sends a MIDI control message to a the device named DeviceName, using Channel, Number and Value.
  • bool SendMIDINoteMessage (string DeviceName, bool On, int Channel, int Note, int Velocity)
    • Sends a MIDI note message to a the device named DeviceName, using Channel, Note and Velocity. The parameter On determines whether the event is a note on or note off event.
Note: Both of the methods above return true on successful completion and false if not successful.
MIDI Sample
Global.OnButtonPressed = function (id)
SendMIDIControlMessage("Midi Fighter Twister", 1, 1, 127) // send control message to Midi Fighter Twister on channel 1, number 1, value 127
SendMIDINoteMessage("nanoPAD2", true, 1, 5, 100) // send note down event to nanoPAD2 device
Global.OnMIDIEvent = function (midiEvent)
// just print the midi event on the console
Console.WriteLine("midi event |" + midiEvent.DeviceName + "| " + midiEvent.EventType + "\n" + midiEvent.ToString())
Art-Net DMX
A sample on how to use the OnDMXEvent callback in a template or global script.
Art-Net Script Sample
Global.OnDMXEvent = function (dmxEvent)
Console.WriteLine( "Universe " + dmxEvent.Universe + " first change at channel " + dmxEvent.firstDiff )
Console.WriteLine( "Channel 7 has changed: " + dmxEvent.HasChanged(7) )
Console.WriteLine( "Channel 7 value is: " + dmxEvent.DMXData[7])
You can enable or disable the DMX signals using the following methods
  • void EnableDMX ( )
    Enables callbacks of the connected Art-Net devices to be sent to connected actions and script callbacks.
  • void DisableDMX ( )
    Disables callbacks of the connected Art-Net devices to be sent to connected actions and script callbacks.
  • bool IsDMXEnabled ( )
    Returns whether the Art-Net callbacks are enabled.
MQTT
Message Queuing Telemetry Transport is supported through the possibility to instantiate a MQTT client and send/receive messages
  • ArcMqttClient createMQTTClient (string server, int port)Creates a MQTT client connected using server and port
The returned client ArcMqttClient supports the following methods
  • void Subscribe (string topic, int qos = 1)
    Subscribes the client to the given topic with the specified quality of service (default 1).
  • void Unsubscribe (string topic)
    Unsubscribes the client from the given topic.
  • void sendMessage (string topic, string payload)
    Sends a message payloadto topic.
  • void Dispose ( )
    Disconnects and deletes the client.
Whenever a message is received from a topic a client has subscribed to, the new data is set to the global DataMap using the topic as key and the payload as value. Payload data in JSON format is passed as a JSON object, anything else is passed as a string object.
MQTT Sample
var mqttClient
Global.OnInit = function ()
mqttClient = createMQTTClient("localhost", 6548)
mqttClient.Subscribe("hello/world/news")
SubscribeDataMap("hello/world/news")
Global.OnDataMapValueChanged = function (varName)
if( varName == "hello/world/news" )
Console.WriteLine("breaking news alert: " + GetData(varName))
A sample server written in C# illustrating the server side code using the MQTTnet library.
MQTT Server Sample
using MQTTnet;
using MQTTnet.Extensions.ManagedClient;
using MQTTnet.Server;
using System;
using System.Threading;
namespace testmqtt
class Program
static void Main(string[] args)
var optionsBuilder = new MqttServerOptionsBuilder()
.WithConnectionBacklog(100)
.WithDefaultEndpointPort(6548);
var mqttServer = new MqttFactory().CreateMqttServer();
mqttServer.StartAsync(optionsBuilder.Build());
int i = 0;
MqttApplicationMessage message = null;
while (true)
message = new MqttApplicationMessageBuilder()
.WithTopic("hello/world/news")
.WithPayload("Temperatures below " + i + " !")
.WithExactlyOnceQoS()
.Build();
mqttServer.PublishAsync(message);
Thread.Sleep(1000);
Console.WriteLine(i + "");
i--;
Object Tracker
The script exposes some useful functions that allows customization and remoting of the Object Tracker. For example, the StopTracker and TakeOutTracker function could be used to quickly remove tracking or On Air graphics.
  • int GetActiveTracker ( )
    • Gets the currently active tracker index (starting from 1).
  • int SetActiveTracker (int tracker)
    • Sets the currently active tracker index (starting from 1). Returns the active tracker index.
  • void TakeTracker ( )
    • Takes tracker On Air all trackers.
  • void TakeOutTracker ( )
    • Takes tracker Off Air all trackers.
  • void PreviewTracker ( )
    • Previews all trackers.
  • void PreviewOutTracker ( )
    • Removes all trackers from preview.
  • void StopTracker ( )
    • Stops all trackers.
  • void StopTracker (int index)
    • Stops the tracker with index (starting from 1).
  • void ResetPointerOffset(int index)
    • Reset the pointer offset for tracker with index (starting from 1).
Viz Arena
The script exposes some useful functions concerning the Viz Arena integration.
  • bool DetectArenaCalibration ( )
    • Redetects the camera calibration (same as the D shortcut in Viz Arena).
  • bool ClearArenaCalibration ( )
    • Clears the camera calibration (same as the BACKSPACE shortcut in Viz Arena).
  • bool ClearArenaKeyer ( )
    • Clears the Keyer mask (same as the C shortcut in Viz Arena).
  • string[] GetArenaCameraList ( )
    • Returns a string-list of available cameras.
  • string GetCurrentArenaCamera ( )
    • Returns the name of the current camera.
  • int GetCurrentArenaCameraIndex ( )
    • Returns the zero based index of the current camera.
  • bool IsArenaConnected ( )
    • Returns whether Viz Arena is running and connected to Viz Arc.
Parameter
All parameters are exposed to the global script and can be accessed via their unique ID.
arc provides an alternative way of getting them.
  • BaseParameter GetParameter (string id)
    • Gets the parameter identified by the unique id that was input.
It's also possible to get and set a parameter's value directly from arc.
  • dynamic GetParameterValue (string id)
    • Gets the value of the parameter identified by the unique id that was input. [dynamic] The returned value's type depends on the parameter type.
  • void SetParameterValue (string id, dynamic value)
    • Sets the value of the parameter identified by the unique id that was input. [dynamic] Input variable value can be of any type, see parameters for valid types.
In case you don't want the callback function OnParameterChanged to be triggered when changing a value using SetParameterValue, you can use SetParameterRawValue. This method does not trigger any calls to OnParameterChanged.
  • void SetParameterRawValue (string id, dynamic value)
Buttons are a special case in the sense that they don't hold a value, and therefore have a separate method for triggering their click.
  • void PushParameterButton (string id)
    • Triggers a pressed event on the button identified by the unique id that was input.
Note: Button presses trigger the global script's callback OnButtonPressed.
Note: Parameter value changes trigger the global script's callback OnParameterChanged.
Parameter Examples
// Setting the value of a bool parameter (id = ShowHighlights) to false
// direct assigment
ShowHighlights.Value = false
// Get parameter via arc and then assign to Value
GetParameter("ShowHighlights").Value = false
// Set Parameter value via arc without interacting with the actual parameter
SetParameterValue("ShowHighlights", false)
// Getting the value of a bool parameter (id = ShowHighlights)
var highlightState = GetParameterValue("ShowHighlights")
// Push LoadFixtures button
PushParameterButton("LoadFixtures")
Channel
arc grants access to Viz Arc profiles. This is useful whenever more precise control is required for communicating with the Engines.
  • ScriptingProfile GetSelectedProfile ( )
    • Returns the currently selected profile.
  • int GetChannelCount ( )
    • Returns the number of channels on the currently selected profile.
  • ScriptingChannel GetChannel (int index)
    • Returns the channel at the index position on the currently selected profile.
  • ScriptingChannel GetChannel (string channelName)
    • Returns the channel named channelName on the currently selected profile.
  • ScriptingChannel GetPreviewChannel ( )
    • Returns the preview channel of the currently selected profile.
  • ScriptingChannel GetProgramChannel ( )
    • Returns the program channel of the currently selected profile.
  • ScriptingChannel GetSelectedChannel ( )
    • In a template script it returns the currently selected channel of the Template Action.
      In the global script it returns the program channel of the currently selected profile.
Channel Handling Examples
// Clear main layer on all channels using GetChannelCount() and GetChannel(int)
for (var i = 0; i < GetChannelCount(); i++) {
GetChannel(i).SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT")
// Send message to VideoWallchannel via GetSelectedProfile () and GetChannel(string)
GetChannel("VideoWall").SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT")
GetSelectedProfile().GetChannel("VideoWall").SendSingleCommand("RENDERER*MAIN_LAYER SET_OBJECT")
Viz Engine/Unreal Engine Communication
arc provides quick access functions for sending messages to specific channels/Engines.
  • void SendSingleCommand (string command, string channelName)
    • Sends command to all the Engines in the specified channel channelName.
  • void SendMultipleCommands (string[] commands, string channelName)
    • Sends all the input commands to all the Engines in the specified channel channelName.
  • string GetFromEngine (string command, string channelName)
    • Sends command to all the Engines in the specified channel channelName. Returns the answer to the sent command.
  • string GetFromVizEngine (string command)
    • Sends command to the currently selected profile's Viz editing Engine. Returns the answer to the sent command.
  • string GetFromUnrealEngine (string command)
    • Sends command to the currently selected profile's Unreal editing Engine. Returns the answer to the sent command.
  • string GetFromEngineAsync (string command, string channelName)
  • string GetFromVizEngineAsync (string command)
  • string GetFromUnrealEngineAsync (string command)
Viz Engine Communication
// Get scene from parameter and set it to Viz Engine main layer
SendSingleCommand(GetParameterValue("MainSceneSelector"), "Main")
// Clear Main, Back and Front layers on channel
var CleanCommands = ["RENDERER*MAIN_LAYER SET_OBJECT", "RENDERER*BACK_LAYER SET_OBJECT", "RENDERER*FRONT_LAYER SET_OBJECT"]
SendMultipleCommands(CleanCommands, "Viz")
// Query Viz channel and Viz editing engine for the currently loaded scene
GetFromEngine("SCENE SCENE*SCENE GET", "Viz")
GetFromVizEngine("SCENE SCENE*SCENE GET")
The async variants can be used only when using the JavaScript language and have the advantage that they do not lock up the UI.
Async Samples
Global.OnButtonPressed = async function (id)
if( id == "getVersionButton" ){
const answer = await GetFromEngineAsync("VERSION", "localviz")
Console.WriteLine("Viz Version is: " + answer)
Note: If you use await, the enclosing function needs to be async. You can add this attribute manually in case you use it within a Viz Arc callback.
Tracking Hub Command
arc provides quick access functions for sending messages to the configured Tracking Hub.
  • void SendSingleTHCommand (string command)
    • Sends command to the Tracking Hub (if configured and connected).
  • string GetFromTH (string command)
    • Sends command to the Tracking Hub (if configured and connected) and returns the answer.
  • string GetFromTHAsync (string command)
    • The asynchronous version of GetFromTH.
SMM Handling
  • void SendToSMM (string key, string value, bool doEscape)
    • Sends key-value pair to Shared Memory to the first channel of the current profile. doEscape specifies whether the value string is escaped.
  • void SendToSMM (string key, string value, bool doEscape, string channel)
    • Sends key-value pair to Shared Memory to all Engines contains in channeldoEscape specifies whether the value string is escaped.
  • void SendToSMM (string key, string value, bool doEscape, string channel, string destination)
    • destination can be either SYSTEM, COMMUNICATION or DISTRIBUTED
The shared memory updates are sent to the UDP or TCP port configured on the target Viz Engine; if both are configured, it is sent to the UDP port. The Viz Communication Shared Memory map is therefore utilized. You can read more on Shared Memory configuration in the Profiles section in the Viz Arc User Guide.
SMM Example
// Send to Viz Channel SMM the variable "Target1" with the value from TargetState
SendToSMM("Target1", TargetState.Value, false, "Viz")
// Send to Viz Channel SMM the variable "Target2" with the value "Hello World!".
// The last parameter "DISTRIBUTED" indicates that the value will be propagated to all engines connected to the same GraphicHub
SendToSMM("Target2", "Hello World!", false, "Viz", "DISTRIBUTED")
GPI
The connected GPI state can be changed via the arc functionalities:
  • void SignalGpiChannel (int channelIndex, bool signalHigh)
    • Signals set the GPI channel at channelIndex to either high or low.
The following snippet presents a function that loads a scene to the "Main" channel and signals the GPI:
GetAction Example
function LoadScene()
// Set gpi channel 2 to High
SignalGpiChannel(2, true)
Note: GPI must be enabled on the config.
Timer
  • void CreateTimer (string id)
    • Creates a timer that can be accessed via its unique id.
  • void CreateTimer (string id, int ms)
    • Starts a timer that can be accessed via its unique id and has a tick interval of ms.
  • void StartTimer (string id, int ms)
    •  Gets the timer identified by id, sets the tick interval to ms and starts it.
  • void StopTimer (string id)
    •  Gets the timer identified by id and stops it.
The following example creates a timer on the OnInit callback, makes use of two buttons to start/stop the timer and writes to the console whenever the timer ticks:
Timer Example
// Timer id
var heartBeatTimerId = "HeartBeat"
// Create timer with id heartBeatTimerId
CreateTimer(heartBeatTimerId)
if(id == "TimerStart")
StartTimer(heartBeatTimerId, 1000)
else if(id == "TimerStop")
StopTimer(heartBeatTimerId)
// Script callback for timer ticks
Global.OnTimer = function (id)
Console.WriteLine("Timer Tick " + id)
Note: Whenever a timer ticks the global script's callback OnTimer is called.
StreamDeck
Any connected StreamDeck that is configured to be used exclusively with arc, can have its buttons customized using one of the following methods:
  • void SetStreamdeckKey (int key, string label, int fontSize)
    • Baseline version, sets streamdeck key at key index image to a black square with label text of fontSize size.
  • void SetStreamdeckKey (int key, string label, int fontSize, string imageFullPath)
    • Same as the baseline version but instead of a black block it sets a local image (at imageFullPath) as background. imageFullPath can be either a local file system path or a Graphic Hub path.
  • void SetStreamdeckKey (int key, string label, int fontSize, int r, int g, int b)
    • Same as the baseline version but instead of black it uses an RGB color as background.
  • void SetStreamdeckKey (int key, string label, int fontSize, int r, int g, int b, string imageName)
    • Same as baseline version using background color r, g, b and imageName on top of the background color (in case the image contains an alpha channel).
  • void SetStreamdeckKey (int key, string label, int fontSize, string horAlignment, string vertAlignment, string textAlignment, int r, int g, int b, string imageName)
    • Same as the previous version, where text is horAlignment aligned horizontally, vertically by vertAlignment and the text itself is centerd through textAlignment.
      • horAlignment can be either "Left", "Center" or "Right"
      • vertAlignment can be either "Top", "Center" or "Bottom"
      • textAlignment can be either "Left", "Center" or "Right"
Any key can have its contents cleared with the following method:
  • void ClearStreamdeckKey (int key)
    • Clears the content of the Streamdeck key at key index
StreamDeck Key Configuration Example
function SetupStreamDeck()
// Key 0: Black background, size 20 "Clear" text
SetStreamdeckKey(0, "Clear", 20)
// Key 1: Image background, size 20 "Load AR" text
SetStreamdeckKey(1, "Load AR", 20, "D:/Soccer/Images/ARThumbnail.png")
// Key 2: Blue background, size 20 "Continue" text
SetStreamdeckKey(2, "Continue", 20, 0, 0, 255)
// Key 3: Gray background, using headshot from Graphic Hub (image may contain an alpha channel)
SetStreamdeckKey(3, " ", 20, 100, 100, 100, "IMAGE*/Default/MasterImages/headshot_0123")
// Key 4: Gray background, using headshot from Graphic Hub (image may contain an alpha channel), Text "John Doe" is top left aligned
SetStreamdeckKey(4, "John Doe", 20, "Left", "Top", "Left", 100, 100, 100, "IMAGE*/Default/MasterImages/headshot_0123")
Global.OnInit = function () {
// Clean first 3 keys
  ClearStreamdeckKey(0)
ClearStreamdeckKey(1)
ClearStreamdeckKey(2)
SetupStreamDeck()
Another sample that prints some useful information using the external StreamDeck plugin.
function printSDEvenyInfo(sdEvent)
// print all the available information for a StreamDeck event
Console.WriteLine("StreamDeck Event Info:")
Console.WriteLine("Event Type: " + sdEvent.EventType)
Console.WriteLine("Device Index: " + sdEvent.DeviceIndex)
Console.WriteLine("Device ID: " + sdEvent.Id )
Console.WriteLine("Column: " + sdEvent.XKey )
Console.WriteLine("Row: " + sdEvent.YKey )
Console.WriteLine("Payload: " + sdEvent.Payload )
// if it's a dial or touch event print additional info
// for StreamDeck + devices only
if( sdEvent.hasOwnProperty("Ticks") )
Console.WriteLine("Ticks: " + sdEvent.Ticks )
if( sdEvent.hasOwnProperty("TapPosX") )
Console.WriteLine("TapPosX: " + sdEvent.TapPosX )
if( sdEvent.hasOwnProperty("TapPosY") )
Console.WriteLine("TapPosY: " + sdEvent.TapPosY )
Global.OnStreamDeckTouchTap = function (sdEvent)
Global.OnStreamDeckDialRotate = function (sdEvent)
Global.OnStreamDeckDialDown = function (sdEvent)
Global.OnStreamDeckDialUp = function (sdEvent)
Global.OnStreamDeckKeyDown = function (sdEvent)
Global.OnStreamDeckKeyUp = function (sdEvent)
Graphic Hub REST
arc provides some methods that allow to retrieve information about the current Graphic Hub REST server in use. It is meant to help using the Graphic Hub REST interface directly.
  • string GetGHHost ( )
    • Returns the Graphic Hub REST host name (for example, localhost or 10.81.44.71).
  • string GetGHPort ( )
    • Returns the Graphic Hub REST port (for example, 19398).
  • string GetGHConnectionString ( )
    • Returns the complete connection string based on the configured Host and Port (for example, http://localhost:19398).
  • string GetGHUser ( )
    • Returns the Graphic Hub REST user name (for example, Guest or Admin).
  • string GetGHAuthenticationValue ( )
    • Returns the base64 authentication string which is a combination of the user name and password (for example, QWRtaW46Vml6RGI=).
Below is a code sample that fetches all the image names of a given Graphic Hub path using the GetGHConnectionString and GetGHAuthenticationValue functions.
Sample
function getFolderId( path )
let folderId = ""
let request = new XMLHttpRequest()
request.onreadystatechange = function() {
if (request.readyState == 4 && request.status == 200 ) {
//Console.WriteLine("respones: " + request.responseText)
xmlDoc = new XmlDocument()
xmlDoc.LoadXml(request.responseText)
//Console.WriteLine("nodes " + xmlDoc.ChildNodes.Count)
// create namespace manager
nsmgr = new XmlNamespaceManager(xmlDoc.NameTable)
// add namespace
nsmgr.AddNamespace("x", "http://www.w3.org/2005/Atom")
// search for x:model
root = xmlDoc.DocumentElement
folderId=root.SelectSingleNode("/x:feed/x:entry/x:id", nsmgr).InnerXml.split(':')[2]
Console.WriteLine("folder id " + folderId)
request.open("GET", GetGHConnectionString()+"/translator/?path="+path, true)
request.setRequestHeader("Authorization", "Basic " + GetGHAuthenticationValue())
request.send();
// fetch the images using the folder uuid
GetImagesOfFolder(folderId)
function GetImagesOfFolder(folderId)
// add namespace
// search for nodes 'entry'
imageNodes=root.SelectNodes("/x:feed/x:entry", nsmgr)
//Console.WriteLine("nodes " + imageNodes.Count)
let imageList = []
for( node of imageNodes )
Console.WriteLine("image " + node.SelectSingleNode("./x:title", nsmgr).InnerXml)
imageList.push(node.SelectSingleNode("./x:title", nsmgr).InnerXml)
// set the dropdown
// imagesDD.SetItems(imageList)
request.open("GET", GetGHConnectionString()+"/files/" + folderId + "/?term=IMAGE", true)
request.send()
Other functions relative to the Graphic Hub:
  • async Task<string[]> GetImages(path)
    • returns a string list of images in the Graphic Hub.
async function fetchImages(path)
Console.WriteLine("fetching images in " + path)
const results = await GetImages(path).then(results =>
dropdown_0.SetItems(results)
if( id == "button_0" )
dropdown_0.Clear()
fetchImages("sports/soccer/headshots")
The above code snippet populates a dropdown with the image names contained in the Graphic Hub path sport/soccer/headshots.
DataMap
arc provides a simple interface (get and set) for interacting with Viz Arc's DataMap:
  • dynamic GetData (string varName)
    • Returns the value belonging to the variable named varName. [dynamic] Returned value depends on what was set to varName.
  • void SetData (string varName, dynamic value)
    • Inserts (or overwrites if varName already exists) the key:value pair into Viz Arc's DataMap. [dynamic] Input value can be of any type.
  • bool HasData (string varName)
    • Returns true if varName exists in the DataMap.
  • void SubscribeDataMap (string variableName)
    • Subscribes to a specific key (Empty string subscribes to all changes). The subbed variables feedback triggers the script callback "OnDataMapValueChanged".
  • void UnsubscribeDataMap (string variableName)
    • Unsubscribes from a specific key (Empty string unsubscribes to all changes).
  • string[] GetDataKeys ( )
    • Returns a complete list of all DataMap key entries.
DataMap Example
// make sure OnDataMapValueChanged is called when "someData" changes
SubscribeDataMap("someData")
// use blank string to subscrive to all DataMap changes
//SubscribeDataMap("")
// create a timer that triggers every second
CreateTimer("aTimer")
StartTimer("aTimer", 1000)
// Callback for DataMap changes
if(varName == "someData")
UpdateSomeData(GetData(varName))
function UpdateSomeData( theData )
// do something here
Console.WriteLine( "new data " + theData )
// generate some fresh data using the current time for testing
// such that OnDataMapValueChanged gets called
if( id == "aTimer" )
SetData("someData", Date.now())
function printDataMap()
var keys = GetDataKeys()
for( k of keys )
Console.WriteLine(k + " = " + GetData(k) )
Note: Whenever a DataMap variable changes the global script's callback OnDataMapValueChanged is called.
NDI
arc provides an interface to handle metadata feedback from NDI sources.
  • string[] GetNDISourceList ( )
    • Returns an array with all the names of the available NDI sources.
  • string[] GetNDIPTZSourceList ( )
    • Returns an array with all the names of the available NDI sources with PTZ control capabilities.
  • void SubscribeNdiSourceMetadata (string source)
    • Subscribes to the metadata feedback on the NDI source identified by the provided source input. The feedback is sent to the datamap with key equal to the source name.
  • void UnsubscribeNdiSourceMetadata (string source)
    • Unsubscribes the NDI feedback.
  • bool SendNDIMetadata (string name, string XMLString)
    • Sends a XMLString to a source identified by name. Returns true on success, false otherwise.
DataMap Example
// Get a list of available NDI sources (can take some time to update)
var sources = GetNDISourceList()
// subscribe to metadata changes on a ndi stream
SubscribeNdiSourceMetadata("NEWTEKPTZ (Channel 1)")
// metadata will be written into the DataMap, so register to the DataMap changes also
SubscribeDataMap("NEWTEKPTZ (Channel 1)")
Console.WriteLine(varName + " changed")
// NDI metadata is typically in xml format
Console.WriteLine(GetData(varName).ToString())
Global.OnParameterChanged = function (id)
if( id == "sendMetadata")
SendNDIMetadata("NEWTEKPTZ (Channel 1)", "<?xml version='1.0' encoding='UTF-8'?><camera_control><command group_id='0' parameter_id='3' value='0.43'></camera_control>")
File Handling
  • string ReadTextFile (string filename, string encoding = "UTF8")
    • Returns a encoding encoded string containing the whole content of the text file.
  • bool WriteTextFile (string FullPath, string data, string encoding = "UTF8")
    • Writes a file at FullPath with its content equal to the encoded input data.
Valid encodings: "UTF8" , "ASCII", "BigEndianUnicode", "Default" [System defined encoding], "UTF32", "UTF7"
File Handling Example
// Get the StartList file content from the directory defined by the Directory parameter "WorkingDir"
ReadTextFile( WorkingDir.Value + "\\StartList.json")
// Write the results to the directory defined by the Directory parameter "WorkingDir"
WriteTextFile( WorkingDir.Value + "\\RaceResults.json", results)
JSON
  • dynamic ParseJson (string data)
    • Deserializes the input data and returns a JSON object if successful.
On the returned JSON object you can access the members directly using their name. Use the "ToString()" method on any of the objects to convert them to strings.
var json = ParseJson("{time: '1994-11-05T13:15:30Z', title: 'Viz Arc', subtitle: 'Vizrt', messageId: 1}")
Console.WriteLine("the whole json " + json.ToString())
Console.WriteLine("the title is " + json.title.ToString())
When using the V8 Scripting Engine the built-in JSON.parse and JSON.stringify methods can be used
var json = JSON.parse('{"time": "1994-11-05T13:15:30Z", "title": "Viz Arc", "subtitle": "Vizrt", "messageId": 1}')
Console.WriteLine("the whole json " + JSON.stringify(json))
Console.WriteLine("the title is " + json.title)
Excel
  •  string convertXLSToCSV (string excelFilePath, string csvOutputFile, string separator = "\t", int worksheetNumber = 1)
    • Converts an existing .xls file excelFilePath to a comma separated CSV file csvOutputFile usign separator (default tab separator) and using worksheet number worksheetNumber (1 default being the first worksheet in the Excel file).
    • On successful conversion the function returns the CSV output as a string.
  • string convertXLSToCSVString (string excelFilePath, string csvOutputFile, string separator = "\t", int worksheetNumber = 1)
    • Converts an existing .xls file excelFilePath to a comma separated CSV string using separator (default tab separator) and using worksheet number worksheetNumber (1 default being the first worksheet in the Excel file).
    • On successful conversion the function returns the CSV output as a stirng.
  • void convertXLSToCSVDataMap (string excelFilePath, string dataMapPrefix, string separator = "\t", int fromSheet = 1, int toSheet = -1)
    • Converts an existing .xls file excelFilePath to a comma separated CSV file csvOutputFile usign separator (default tab separator) and using an optional range of worksheets. When toSheet is -1 it converts all worksheets. The resulting worksheets are written into the DataMap using the specified prefix in dataMapPrefix. The name of the worksheet is written to the DataMap key dataMapPrefix<name>_<index>.
let separator = ";"
// convert excel to CSV file, use ; as separator and read the second sheet
convertXLSToCSV("c:/tmp/ExcelData.xlsx", "c:/tmp/ExcelData.csv", separator, 2)
// read the whole csv file into a string
var fileContent = ReadTextFile("c:/tmp/ExcelData.csv")
var EntryArr = fileContent.split("\n")
// First line is for the headers, ignore it
for(i = 0; i < EntryArr.length; i++)
// split the row
var spl = EntryArr[i].split(separator)
if( spl.length <= 1 )
continue;
Console.WriteLine("row " + i + ":")
// print colums one by one separated by a whitespace
for( entry of spl )
Console.Write( entry.trim() + " " )
Console.WriteLine("")
// another writing all worksheets to the DataMap, use separator ","
convertXLSToCSVDataMap("c:/tmp/ExcelData.xlsx", "excelData_", ",")
How the resulting DataMap might look like after calling convertXLSToCSVDataMap when the excel file contains just one worksheet.
Callbacks
  • OnParameterChanged (string parameterID)
    • Called whenever a parameter (except button and table) changes. parameterID is the ID of the parameter that triggered the callback.
  • OnButtonPressed (string buttonName)
    • Called when a parameter button is pressed. buttonName is the ID of the button that triggered the callback.
  • OnMiddleButtonPressed (string buttonName)
    • Called when a button is pressed with the middle mouse button. buttonName is the ID of the button that triggered the callback.
  • OnRightButtonPressed (string buttonName)
  • OnTimer (string timerID)
    • Called when a timer ticks (completes a cycle). timerID is the ID of the timer that triggered the callback.
  • OnDataMapValueChanged (string varName)
    • Called whenever a DataMap variable changes. varName is the ID of the variable that was changed.
  • OnStreamDeckKey (string key)
    • Called whenever a StreamDeck button is pressed. key indicates the index of the pressed button.
    • This callback is used in conjunction with the internal Stream Deck integration
The following StreamDeck callbacks are used with the external Stream Deck integration:
  • OnStreamDeckKeyUp (sdEvent)
    • Called whenever a Stream Deck button has been released.
    • sdEvent contains the following fields:
      • string EventType (the event type, for example, "keyUp")
      • string Id (the unique ID of the device)
      • int DeviceIndex (the index assigned to this device)
      • int XKey (the column index of the key)
      • int YKey (the row index of the key)
      • string Payload (the user defined payload)
  • OnStreamDeckKeyDown (sdEvent)
    • Called whenever a Stream Deck button has been pressed.
    • sdEvent contains the same fields as OnStreamDeckKeyUp
  • OnStreamDeckDialUp (sdEvent)
  • OnStreamDeckDialDown (sdEvent)
  • OnStreamDeckDialRotate (sdEvent)
    • sdEvent contains the same fields as OnStreamDeckKeyUp and additionally:
      • int Ticks positive number for clockwise rotation and negative for anticlockwise rotation. Minimum value is 1 and increases when doing fast movementes.
  • OnStreamDeckTouchTap (sdEvent)
      • int TapPosX number from 0 to 200 (on Stream Deck + device) representing the horizontal touch position
      • int TapPosY number from 0 to 100 (on Stream Deck + device) representing the vertical touch position
  • OnMidiEvent (midiEvent)
    • Called whenever a midi event is registered on one of the attached and configured midi devices.
    • midiEvent contains the following fields:
      • string DeviceName (the name of the device triggering the midi event.
      • string EventType (either "ControlChange", "NoteOn" or "NoteOff").
      • int Channel (the control channel of the event).
      • int Number (the control number of the event).
      • int Value (the value of the event, in the range [0..127]).
      • int Note (the note of the event in case EventType is NoteOn or NoteOff).
      • int Velocity (the velocity of note event in case EventType is NoteOn or NoteOff).
  • OnDMXEvent (dmxEvent)
    • Called whenever a dmx lighting value changes
    • dmxEvent contians the followinf fields:
      • short Universe (the Univers ehtat changed)
      • byte[] DMXData (the entire 512 byte long data array)
      • byte[] change (a 512 byte long array containing information about channel changes)
      • int firstDiff (the index of the first channel that changed)
    • bool HasChanged(int index)
      Call this function to check whether a certain channel has changed
  • Table Callbacks
    • OnTableColumnsChanged (string tableID)
      • Called whenever a table parameter's columns change in number. tableID is the ID of the table that triggered the callback.
    • OnTableRowsChanged (string tableID)
      • Called whenever a table parameter's rows change in number. tableID is the ID of the table that triggered the callback.
    • OnTableCellValueChanged (string tableID, int row, int column, BaseBlock cell)
      • Called whenever a table parameter's cell changes value. tableID is the ID of the table that triggered the callback. row and column indicate the position of the cell within the caller table parameter. cell is the cell object that was changed. Users can interact directly with it. When Trigger on live changes is enabled on the table property, this callback is called also while editing the cell, if not the callback is called when keyboard focus is lost on the edited cell.
Exposed Objects
Console
  • void Write (string message)
    • Writes the message to the scripting console.
  • void WriteLine (string message)
    • Writes the message to the scripting console followed by a new line.
Info: When Viz Arc’s log level is set to TRACE, the strings sent to Write and WriteLine are also logged in the global log file.
MessageBox
  • void Show (string message)
    • Shows a message box with its content equal to message.
  • void Show (string message, string title)
    • Shows a message box with titled title and with its content equal to message.
// Log an error and show a message to the user
Console.WriteLine("Unable to load data")
MessageBox.Show("Unable to load data", "Load Error")
XmlDocument
XmlDocument allows you to read XML files or strings and aggregate data using XPath. Read more about XMLDocument and other classes here.
// create XmlDocument and load a xml from disc
xmlDoc.Load("C:/tmp/TestData.xml")
// add namespace
nsmgr.AddNamespace("x", "http://www.contoso.com/books")
// search for book nodes under the books node
nodeList=root.SelectNodes("/x:books/x:book", nsmgr)
Console.WriteLine("books " + nodeList.Count)
for( var book of nodeList )
Console.WriteLine("ISBN: " + book.GetAttribute("ISBN") + " title: " + book.SelectSingleNode("./x:title", nsmgr).InnerXml)
The content of the sample test file C:/tmp/TestData.xml might look like this:
<?xml version="1.0" encoding="utf-8"?>
<books xmlns="http://www.contoso.com/books">
<book genre="novel" ISBN="1-861001-57-8" publicationdate="1823-01-28">
<title>Pride And Prejudice</title>
<price>24.95</price>
</book>
<book genre="novel" ISBN="1-861002-30-1" publicationdate="1985-01-01">
<title>The Handmaid's Tale</title>
<price>29.95</price>
</book>
<book genre="novel" ISBN="1-861001-45-3" publicationdate="1811-01-01">
<title>Sense and Sensibility</title>
<price>19.95</price>
</book>
</books>
XMLHttpRequest
With the XMLHttpRequest class you can fetch data from a remote server. Below is a sample that fetches asynchronously JSON data from a server.
var request = new XMLHttpRequest()
Console.WriteLine("we are here")
var json = JSON.parse(request.responseText)
Console.WriteLine(JSON.stringify(json))
for (elem of json)
Console.WriteLine(elem.name)
request.open("GET", "https://jsonplaceholder.typicode.com/users", true)
request.setRequestHeader( "Content-Type", "application/json" ) // make sure the request header is set AFTER calling open
request.send()
Prevent Caching
It is possible that requests through XMLHttpRequest get cached and the results of the queries might seem outdated. In order to prevent caching you can add a random number as parameter of the request.
request.open("GET", "https://jsonplaceholder.typicode.com/users?dummy="+Date.now() , true)
In this case a dummy parameter is assigned with the current EPOCH date in milliseconds.
xlAppType
This type allows you to read Excel sheets directly.
Note: This object only works if there is a local Excel installation on the same machine where Viz Arc is running.
FSO
The FSO object allows you to read, create and write files.
  • OpenTextFile (filename, [ iomode, [ create, [ format ]]])
    • iomode can be one of the following: IOMode.ForReading, IOMode.ForWriting, IOMode.ForAppending
    • format can be of the following: Tristate.TristateUseDefault (system default), TriState.TristateTrue (Unicode), TriState.TristateFalse (ASCII).
Reading a UTF8 Encoded Text File
var file = new FSO()
var stream = file.OpenTextFile("d:/testexport.txt")
// or
var stream = file.OpenTextFile("d:/testexport.txt", IOMode.ForReading, false, Tristate.TristateTrue)
Console.WriteLine(stream.ReadAll())
xHost
The xHost object gives you access to virtually any .NET resource.
V8 Script Sample
var List = xHost.type('System.Collections.Generic.List')
var DayOfWeek = xHost.type('System.DayOfWeek')
var week = xHost.newObj(List(DayOfWeek), 7)
week.Add(DayOfWeek.Sunday)
You can even import entire assemblies:
V8 Enumerate Files in Directory
var clr = xHost.lib('mscorlib', 'System', 'System.Core', 'System.IO')
dropdown_0.Clear()
var dir = clr.System.IO.Directory
dropdown_0.SetItems(dir.GetFiles('c:\\tmp'))
// another sample that starts an external process "calc.exe"
var proc = xHost.lib('System.Diagnostics.Process')
proc.System.Diagnostics.Process.Start("calc.exe")
In the example above, a UI dropdown element named dropdown_0 is populated with a file list contained in c:\tmp using .NET System.IO.Directory class instance.
Performance
The performance object provides access to performance-related information.
  • now ( )
    Returns a floating point value of the EPOCH time in milliseconds.
  • sleep (milliseconds, precise)
    Sleep for a certain amount of milliseconds. Set precise to true when a high precision timer is required.
let timeA = Performance.now()
Performance.sleep(500, true) // high perf sleep half second
// do something else
let timeB = Performance.now()
Console.WriteLine("timeA " + timeA)
Console.WriteLine("timeB " + timeB)
Console.WriteLine("time difference " + (timeB- timeA) + " ms")
SQL Sample
If you know the assembly name of a specific type, you can instantiate it using xHost.type(name, assemblyName) method.
var queryString = "SELECT * FROM someTable"
var connetionString = "Server=192.168.1.42,1433;UID=aUserID;PWD=SomePassword;"
// get types using xHost.type
var SqlConnection = xHost.type('System.Data.SqlClient.SqlConnection', 'System.Data.SqlClient')
var SqlCommand = xHost.type('System.Data.SqlClient.SqlCommand', 'System.Data.SqlClient')
var SqlDataReader = xHost.type('System.Data.SqlClient.SqlDataReader', 'System.Data.SqlClient')
connection = new SqlConnection(connetionString)
connection.Open()
var command = new SqlCommand(queryString, connection)
var reader = command.ExecuteReader()
// do something with the data
while (reader.Read())
// iterate over the result and print the result on the console
Console.WriteLine(reader.GetString(0))
connection.Close()
SQLite Sample
Another sample that uses the xHost.type function is the usage of a simple SQLite database. It is required that the SQLite libraries/DLLs are in the search path of the system or in the same directory as the Viz Arc executable.
var SQLiteConnection = xHost.type('System.Data.SQLite.SQLiteConnection', 'System.Data.SQLite')
// those two below are not needed for this sample as they dont get instantiated explicityl
var SQLiteDataReader = xHost.type('System.Data.SQLite.SQLiteDataReader', 'System.Data.SQLite')
var SQLiteCommand = xHost.type('System.Data.SQLite.SQLiteCommand', 'System.Data.SQLite')
function ReadData(conn)
// create q query
sqlite_cmd = conn.CreateCommand()
sqlite_cmd.CommandText = "SELECT Name FROM Artist LIMIT 10;" // read first 10 artists of the table
// execute the query
sqlite_datareader = sqlite_cmd.ExecuteReader();
while (sqlite_datareader.Read())
Console.WriteLine(sqlite_datareader.GetString(0));
function testSQLiteDB()
// create a new connection specifying the database file name and the version
// sample database can be found here https://github.com/lerocha/chinook-database
conn = new SQLiteConnection("Data Source=C:\\tmp\\Chinook.db;Version=3;")
try
// Open the connection:
conn.Open()
// read some data
ReadData(conn)
// close the connection
conn.Close()
catch (ex)
Console.WriteLine("error in SQLite query " + ex)
testSQLiteDB()
HtmlAgility Example
The classes HtmlDocument and HtmlWeb are exposed by the HtmlAgility library and enable parsing and data extraction  of html pages.
//sample to use HtmlDocument class from HtmlAgility
var doc = new HtmlDocument()
doc.Load("c:/tmp/HtmlAgilityTest.html")
for (var table of doc.DocumentNode.SelectNodes("//table")) {
Console.WriteLine("Found: " + table.Id)
for (var row of table.SelectNodes("tr")) {
for (var cell of row.SelectNodes("th|td"))
Console.Write(cell.InnerText + " ")
// sample to use HtmlWeb class from HtmlAgility
var html = "http://html-agility-pack.net/"
var web = new HtmlWeb()
var htmlDoc = web.Load(html)
var node = htmlDoc.DocumentNode.SelectSingleNode("//head/title")
Console.WriteLine("Node Name: " + node.Name + "\n" + node.OuterHtml)
The contents of the file from the sample above c:/tmp/HtmlAgilityTest.html:
HTML Sample with Table
<!DOCTYPE html>
<html>
<style>
table, th, td {
border: 1px solid black;
</style>
<body>
<h2>A HTML table to test HTML Agility</h2>
<table style="width:100%" id="dataTable">
<tr>
<th>Name</th>
<th>Number</th>
<th>Country</th>
</tr>
<tr>
<td>Athlete A</td>
<td>42</td>
<td>Italy</td>
</tr>
<tr>
<td>Athlete B</td>
<td>34</td>
<td>Japan</td>
</tr>
</table>
<p>Here is some more text</p>
</body>
</html>
Read more about HtmlAgility here.
Main Script-only
There are functionalities that are specific to Viz Arc's main script:
Canvas Tabs Handling
  • void SetActionsSelectedTab (string tabName )
    • Looks for a tab named tabName and sets it as active.
  • void SetActionsSelectedTab (int tabIndex)
    • Sets the Action selected tab to the tab at tabIndex index.
  • string GetActionsSelectedTabName ( )
    • Returns the currently selected tab's name.
  • string[] GetActionsTabs ( )
    • Returns a string array with all tab names.
Action Template Handling
Arc's main scripts allows the user to interact with template actions on the action canvas.
  • void PreviewSelectedTemplate ( )
    • Previews the currently selected template action.
  • void ExecuteSelectedTemplate ( )
    • Executes the currently selected template action.
  • void UpdateSelectedTemplate ( )
    • Updates the currently selected template action.
  • void ContinueSelectedTemplate ( )
    • Continues the currently selected template action.
  • void StillPreviewSelectedTemplate ( )
    • Generates a still preview of the currently selected template action.
Note: The method presented only works when one and only one action (template action) is selected on the action canvas.
Callbacks
  • PreActionExecute (string actionName)
    • Called whenever an is executed and before the actual execution occurs.
    • actionName is the name of the action that is being executed.
  • PosActionExecute (string actionName)
    • Called whenever an is executed and after the actual execution occurs.
  • OnInit ( )
    • Called when the main script is started (User clicks on the Start button).
Template Script-only
The template script is a specific version that is used on the template designer and on the template action.
Action/Designer Handling
  • void ExecuteTemplate ( )
    • Execute the owner template action or loaded template in the designer.
  • void ContinueTemplate ( )
    • Continues the owner template action or loaded template in the designer.
  • void OutTemplate ( )
    • Takes out the owner template action or loaded template in the designer.
  • void UpdateTemplate ( )
    • Updates the owner template action or loaded template in the designer.
  • void UpdateTemplate (string COs = null)
    • Updates the owner template action or loaded template in the designer. The parameter COs is a space separated list of Control Object ID's that shall be updated. For large templates containing a big amount of ControlObjects this is a very efficient alternative whenever only a small part in the scene needs to be updated. For example, UpdateTemplate("currentScore totalScore") updates only the two ControlObjects with id "currentScore" and "totalScore".
  • void UpdateTemplate ("BP_Name.VariableName")
    • Updates the owner template action or loaded template in the designer. This method can be used if the scene is in Unreal Engine. For large templates containing a large amount of variables, this is a very efficient alternative when only a variable in the blueprint needs to be updated.
  • void UpdateTemplate ("BP_Name", "[ VariableName1, VariableName2, ecc... ]")
    • Updates the owner template action or loaded template in the designer. This method can be used if the scene is in Unreal Engine. For large templates containing a large amount of variables, this is a very efficient alternative when only a few variables in the blueprint need to be updated.
  • void PreviewTemplate ( )
    • Previews the owner template action or loaded template in the designer.
  • void PreviewExecuteTemplate ( )
    • Executes the owner template action or loaded template in the designer to the preview channel.
  • void PreviewContinueTemplate ( )
  • void PreviewOutTemplate ( )
  • void PreviewUpdateTemplate (string COs = null)
    • Updates the owner template action or loaded template in the designer to the preview channel. The parameter COs is a space separated list of Control Object ID's that shall be updated. For large templates containing a big amount of ControlObjects this is a very efficient alternative whenever only a small part in the scene needs to be updated. For example, UpdateTemplate("currentScore totalScore") updates only the two ControlObjects with id "currentScore" and "totalScore".
Properties
  • BaseAction ThisAction
    • Returns the script accessor of this template. ThisAction might be null when using the template editor.
if( ThisAction ){
// set the action's name
ThisAction.Name = "Hello"
// set the action's tooltip description
ThisAction.Description = "Hello Description"
Control Object Handling
The template script allows the user to interact with the template's control objects.
  • void SetControlObject (string objectID, dynamic value)
    • Sets the control object with id equal to objectID's value to value. The set object's value is sent on template execute/update.
    • ControlObject ID's set by this methods which have not been present in the payload during template creation, are added dynamically.
Note: SetControlObject only works on control objects that aren't already linked to parameters.
Template Channels Handling
The template script allows the user to change the program output channel.
  • void SetSelectedChannel (string name)
    • Sets the selected program output channel to name.
    • Returns the currently selected program channel of the template action.
ScriptingChannel
The ScriptingChannel class is used for finer control on the Engines contained in the channel.
Properties
  • Name
    • The channel's name.
  • Count
    • The number of Engines in the channel.
Methods
  • void SendSingleCommand (string command)
    • Sends command to all the Engines in the channel.
  • void SendMultipleCommands (string[] commands)
    • Sends all the input commands to all the Engines in the channel.
    • Sends key-value pair to Shared Memory to all Engines contained in the channel. doEscape specifies whether the value string is escaped.
  • void SendToSMM (string key, string value, bool doEscape, string destination)
Template Scene Handling
The template script allows the user to set the scene that should be loaded when executing.
  • void SetSceneFullpath (string fullpath = null)
    • The input fullpath is the value that is sent to the Engine when executing the template. When no full path is provided the user config value is removed and the original attached scene is used.
  • string GetBaseContainerPath ( )
    • Returns the current base container path where the root control object is located.
  • bool SetBaseContainerPath ( )
    • Sets the base container path where the root control object is located. This might be useful to redirect the destination of the ContolObjects to a different container in the same scene.
  • string GetDirector ( )
    • Gets the current director executed on Execute or on Continue.
  • bool SetDirector (string dir)
    • Sets the director executed on Execute or on Continue.
Template Action Configuration
  • bool IsCommandHeaderVisible
    • Indicates whether the CommandHeader should be visible on the template action.
  • bool UpdateOnSelected
    • When this flag is set, the script callbacks are only triggered when the template action is selected on the action canvas (blue border).
Callbacks
  • OnCreated ( )
    • Called when the template script is executed (when the template action is created and when the template opened on the designer is started).
  • OnShow ( )
    • Called when the template is shown (when the template action's pop-up is opened, when the action becomes embedded and when the template opened on the designer is started).
  • OnExecute ( )
    • Called when the template is executed.
  • OnPreviewExecute ( )
    • Called when the template is executed to the preview channel.
  • OnContinue ( )
    • Called when the template is continued.
  • OnPreviewContinue ( )
    • Called when the template is continued to the preview channel.
  • OnUpdate ( )
    • Called when the template is updated.
  • OnPreviewUpdate ( )
    • Called when the template is updated to the preview channel.
  • OnOut ( )
    • Called when the template is taken out.
  • OnPreview ( )
    • Called when the template is previewed.
  • OnTrackerAction (string action)
    • Called on certain Object Tracker events. the action parameter determines the type of event:
      • take: Triggered when Object Tracker is taken On Air.
      • takeout: Triggered when Object Tracker is taken Off Air.
      • preview: Triggered when Object Tracker preview is taken.
      • previewout: Triggered when Object Tracker preview is taken out.
      • newTracker <index>: Triggered whenever a new object has been selected for tracking. index is 1 based.
      • lostTracker <index>: Triggered whenever a tracked object has lost tracking. index is 1 based.
Sample Usage of Object Tracker Script API
Global.OnTrackerAction = function (action)
Console.WriteLine("tracker action " + action )
if( action == "take" )
GetAction("DATA").Execute()
else if( action.startsWith("newTracker" ) ){
// we want to take off air whatever is On Air when we select a new tracked object
TakeOutTracker()
Console.WriteLine("OFF AIR" )
  • OnArenaPosition (double screenX, double screenY, double worldX, double worldY, double worldZ)
    • Called when the user clicks on the Viz Arena view with the positioning tool.
      • screenX and screenY are the screen coordinates of the mouse click. The lower left corner of the arena screen is the origin (0,0).
      • wolrdX, worldY and worldZ are Viz Engine world coordinates, the units (default meters) are the same as for the selected Viz Arena project.
Common Callbacks
Callbacks that can be used in the global script and template scripts
  • OnVideoMouseLeftButtonDown (point)
    • Called when the user pressed the left mouse button on the video output.
      • point.X normalized value in the range [-0.5, 0.5]
      • point.Y normalized value in the range [-0.5, 0.5]
  • OnVideoMouseRightButtonDown (point)
  • OnVideoMouseMove (point)
    • Called when the user moved the mouse on the video output.
  • OnVideoMouseWheel (delta)
    • Called when the user rolled the mouse wheel on the video output.
      • delta is a floating point value, typical values are -120.0 for mouse wheel down and 120.0 for mouse wheel up.
Parameters
Parameters are the base components of Viz Arc's scripting. A list of all existing parameters types and their associated properties is presented below.
Base Parameters Functionality
The following properties and methods are shared among all parameters
  • string Label [Get, Set]
    • Gets/sets the label that is displayed on the UI.
  • bool IsEnabled [Get, Set]
    • Gets/sets the enabled status of the parameter. Disabled parameters can be interacted with.
  • bool IsVisible [Get, Set]
    • Whether the parameter is visible. Invisible parameters are visible (displayed as grayed out) only while editing (and scripts are not running).
  • double X [Get, Set]
    • Gets/sets the horizontal position of the parameter on the canvas.
  • double Y [Get, Set]
    • Gets/sets the vertical position of the parameter on the canvas.
  • double Width [Get, Set]
    • Gets/sets the width of the parameter.
  • double Height [Get, Set]
    • Gets/sets the height of the parameter.
  • void SetColor (byte r, byte g, byte b, byte a = 255)
    • Sets the parameter's color to the input RGBA color.
  • string Color
    • Gets/sets the parameter's selected color in Hex format, for example, #FF0A0A8C (#RRGGBBAA).
  • int ColorR
    • Gets/sets the parameter's selected red color value in the range [0, 255].
  • int ColorG
    • Gets/sets the parameter's selected green color value in the range [0, 255].
  • int ColorB
    • Gets/sets the parameter's selected blue color value in the range [0, 255].
  • int ColorA
    • Gets/sets the parameter's selected alpha value in the range [0, 255].
  • string Tooltip [Get, Set]
    • Gets/sets the tooltip of the UI element.
  • string LinkedCO [Get]
    • The name of the associated ControlObject (Template Scripting only).
A sample use of the LinkedCO property:
// get linked ControlObject id associated to parameter 'id'. It is null if it's not linked to any CO.
let linkedCO = GetParameter(id).LinkedCO
if( linkedCO )
Console.WriteLine("Changed: " + id + ", Linked Control Object ID: " + linkedCO)
// live update the template
UpdateTemplate(linkedCO)
Layout
The layout parameters allow the user to organize and improve the usability of a script/template.
Panel
  • BaseParameter [ ] Children [Get]
    • Returns an array with all of the panel's children.
  • BaseParameter GetParameter (string parameterID)
    • Tries to find a child with id equal to parameterID. Returns it if successful.
Tabs
  • string Value [Get, Set]
    • Set: Attempts to find a tab with its name equal to the input. If found, sets it as selected tab.
    • Get: Returns the name of the selected tab.
  • bool AllowReordering
    • Whether a user can reorder the tabs.
  • int SelectedIndex [Get, Set]
    • Gets/sets the index of the selected tab.
Info
    • Gets/sets the info text that displays on the parameter.
Label
TextColor
    • Gets/sets the labels text color in Hex format, for example, #FF0A0A8C (#RRGGBBAA).
Dialogs
Color
  • int R [Get]
    Gets the value of the red component in the range [0, 255].
  • int G [Get]
    Gets the value of the green component in the range [0, 255].
  • int B [Get]
    Gets the value of the blue component in the range [0, 255].
  • int A [Get]
    Gets the value of the alpha component in the range [0, 255].
  • int RPercent [Get]
    Gets the value of the red component in the range [0, 1].
  • int GPercent [Get]
    Gets the value of the green component in the range [0, 1].
  • int BPercent [Get]
    Gets the value of the blue component in the range [0, 1].
  • int APercent [Get]
    Gets the value of the alpha component in the range [0, 1].
  • void SetR (int R)
    Sets the red component in the range [0, 255].
  • void SetG (int G)
    Sets the green component in the range [0, 255].
  • void SetB (int B)
    Sets the blue component in the range [0, 255].
  • void SetA (int A)
    Sets the alpha component in the range [0, 255].
  • void SetRGB (int R, int G, int B)
    Sets the red, green and blue components in the range [0, 255].
  • void SetRGBA (int R, int G, int B, int A)
    Sets the red, green, blue and alpha components in the range [0, 255].
  • void SetRPercent (double R)
    Sets the red component in the range [0, 1].
  • void SetGPercent (double G)
    Sets the green component in the range [0, 1].
  • void SetBPercent (double B)
    Sets the blue component in the range [0, 1].
  • void SetAPercent (double A)
    Sets the alpha component in the range [0, 1].
  • void SetRGBPercent (double R, double G, double B)
    Sets the red, green and blue components in the range [0, 1].
  • void SetRGBAPercent (double R, double G, double B, double A)
    Sets the red, green, blue and alpha components in the range [0, 1].
Directory
    • Gets/sets the selected directories fullpath.
    • Set: The input value must be a valid directory in the file system.
File
    • Gets/sets the selected file's fullpath.
Asset
    • Gets/sets the selected asset's fullpath.
    • Set: The input path needs to be valid.
Note: Valid input values are: Graphic Hub items (Image, Geom, Material), Media service links (http://...) or local file system files.
WebView
This component lets you view a web page.
    • Gets/sets the URL of the web page to be visualized.
The browser used for rendering is based on CEF. It might not play all video codecs.
Bool
  • bool Value [Get, Set]
    • Gets/sets the parameter's bool value.
Button
  • void Click ( )
    • Trigger a click event on the button parameter.
  • string BackgroundImage
    • Gets/sets the path to the background image. It can be either a local file path (for example, c:/tmp/someimage.png) a GraphicHub path (for example, IMAGE*/project/A/imageButton) or a URL (for example, http://storage.internal/image.jpg).
  • string ImageMargin
    • Gets/sets the margins in pixels of the background image. Specify either one, two or four comma separated margins. A value of 5 applies a margin of 5 pixels in all directions, a value of 5, 3 applies a margin of 5 pixels on the left and right and a margin of 3 at the top and bottom. A value of 1, 2, 3, 4 applies the respective margins in the order left, top, right and bottom.
  • string DirectorPath
    • Gets/sets the Stage Director to be executed on click. For example, $Director$SubDirector
  • string DirectorExecute
    • Gets/sets the type of action type to execute on click. Possible values are <nothing>, START, CONTINUE, CONTINUE REVERSE, PAUSE or RESET.
  • string ActionExecute
    • Gets/sets the name or UUID of the action to be executed on click.
Toggle Button
  • void SetCheckedColor (byte r, byte g, byte b, byte a = 255)
    • Sets the toggle's color to the input RGBA color when the toggle is in it's checked state.
  • string CheckedColor
    • Gets/sets the toggle's color in Hex format, for example, #FF0A0A8C (#RRGGBBAA) when the toggle is in it's checked state.
  • int CheckedColorR
    • Gets/sets the toggle's red color value in the range [0, 255] when the toggle is in it's checked state.
  • int CheckedColorG
    • Gets/sets the toggle's green color value in the range [0, 255] when the toggle is in it's checked state.
  • int CheckedColorB
    • Gets/sets the toggle's blue color value in the range [0, 255] when the toggle is in it's checked state.
  • int CheckedColorA
    • Gets/sets the toggle's alpha value in the range [0, 255] when the toggle is in it's checked state.
  • bool IsChecked
    • Gets/sets the toggle button's state to checked or unchecked.
  • string ContainerPath
    • Gets/sets the Viz scene container path (for example, $object$ALL$left) to be used when VisibilityCheckd/VisibilityUncheckd or KeyChecked/KeyUnchecked actions are set.
    • Gets/sets the Stage Director path (for example, $Director$SubDirector)to be executed when DirectorCheckd/DirectorUnchecked actions are set.
  • string ActionChecked
    • The action name or uuid to be executed when the toggle button gets checked.
  • string ActionUnchecked
    • The action name or uuid to be executed when the toggle button gets unchecked.
  • string VisibilityChecked
    • Gets/sets the visibility of the container specified in ContainerPath when the toggle button gets checked. Possible values are <nothing>, ON or OFF.
  • string VisibilityUnchecked
    • Gets/sets the visibility of the container specified in ContainerPath when the toggle button gets unchecked. Possible values are <nothing>, ON or OFF
  • string DirectorChecked
    • Gets/sets the action to be executed on the director specified in DirectorPath when the toggle gets checked. Possible values are <nothing>, START, CONTINUE, CONTINUE REVERSE, PAUSE or RESET.
  • string DirectorUnchecked
    • Gets/sets the action to be executed on the director specified in DirectorPath when the toggle gets unchecked. Possible values are <nothing>, START, CONTINUE, CONTINUE REVERSE, PAUSE or RESET.
  • string KeyChecked
    • Gets/sets the key action of the container specified in ContainerPath when the toggle button gets checked. Possible values are <nothing>, ACTIVE, INACTIVE, COMBINE WITH BG ON, COMBINE WITH BG OFF.
  • string KeyUnchecked
    • Gets/sets the key action of the container specified in ContainerPath when the toggle button gets un checked. Possible values are <nothing>, ACTIVE, INACTIVE, COMBINE WITH BG ON, COMBINE WITH BG OFF.
Double / Double Slider
  • double Value [Get, Set]
    • Gets/sets the parameter's double value.
  • double MinValue [Get, Set]
    • Gets/sets the parameter's minimum double value. Input value needs to be lower than the current MaxValue.
  • double MaxValue [Get, Set]
    • Gets/sets the parameter's maximum double value. Input value needs to be higher than the current MinValue.
Dropdown / Radio
    • Gets/sets the selected entry on the dropdown.
    • Gets/sets the selected index of the dropdown.
  • int Count [Get]
    • Gets the number of entries on the dropdown.
  • int IndexOf (string option)
    • Looks for an entry equal to option. Returns its index if found, -1 otherwise.
  • void Insert (int index, string option)
    • Inserts an entry with value option at index position. index needs to be between 0 and Count.
  • void Add (string option)
    • Adds an entry with value option atthe end of the entry list.
  • void Remove (string option)
    • Looks for an entry equal to option. Removes it if found.
  • void RemoveAt (int index)
    • Removes the entry at position indexindex needs to be between 0 and Count.
  • void SetItems (string[] entries)
    • Sets the dropdown's entry list to the input entries.
  • string Get (int index)
    • Returns the entry located at index position. index needs to be between 0 and Count.
  • string parameter[ int index ]
    • Array accessor for entries. Returns the entry located at index position.
  • void Clear ( )
    • Removes all entries from the dropdown.
Int / Int Slider
  • int Value [Get, Set]
    • Gets/sets the parameter's int value.
  • int MinValue [Get, Set]
    • Gets/sets the parameter's minimum int value. Input value needs to be lower than the current MaxValue.
  • int MaxValue [Get, Set]
    • Gets/sets the parameter's maximum int value. Input value needs to be higher than the current MinValue.
MultiText / Text
    • Gets/sets the parameter's text value.
Triplet
    • Gets/sets the parameter's X double value.
    • Gets/sets the parameter's Y double value.
  • double Z [Get, Set]
    • Gets/sets the parameter's Z double value.
  • bool XEnabled [Get, Set]
    • Gets/sets the enabled status of the X value.
  • bool YEnabled [Get, Set]
    • Gets/sets the enabled status of the Y value.
  • bool Z Enabled [Get, Set]
    • Gets/sets the enabled status of the Z value.
  • bool AllowProportional [Get, Set]
    • Gets/sets whether the user can toggle the proportional lock.
  • bool IsProportional [Get, Set]
    • Gets/sets the state of the proportional lock.
Table
Properties
  • string Value [Get]
    • Gets an string containing the table content in a XML format (much like ControlList).
  • int MinimumRows [Get, Set]
    • Gets/sets the parameter's minimum number of rows. Input value needs to be lower than the current MaximumRows.
  • int MaximumRows [Get, Set]
    • Gets/sets the parameter's maximum number of rows. Input value needs to be higher than the current MinimumRows.
  • int MinimumColumns [Get, Set]
    • Gets/sets the parameter's minimum number of columns. Input value needs to be lower than the current MaximumColumns.
  • int MaximumColumns [Get, Set]
    • Gets/sets the parameter's maximum number of columns. Input value needs to be higher than the current MinimumColumns.
  • int RowCount [Get]
    • Gets the current number of rows on the table.
  • int ColumnCount [Get]
    • Gets the current number of columns on the table.
  • int SelectedRow [Get]
    • Gets the currently selected row. In case of multi-selection it returns the first selected row. If no row is selected, -1 is returned.
  • int SelectedIndex [Get]
    • An alias for SelectedRow
Methods
Cell Handling
  • BaseCell Accessor [int row, int column ] [Get]
    • Gets the cell located at row-indexed row and column-indexed column.
  • BaseCell GetCell (int row, int column)
  • void SetCellValue (int row, int col, dynamic value)
    • Sets the cell’s value (located at [row, column]) to value. [dynamic] value can either be a string or have a type that is compatible with the target cell.
  • stringGetCellValue (int row, int col)
    • Gets the cell’s (located at [row, column]) string value representation.
  • void ClearColumnValues (int columnIndex)
    • Resets all the cell’s values in columnIndex column.
  • void ClearRowValues (int rowIndex)
    • Resets all the cell’s values in rowIndex row.
  • void ClearAllValues ( )
    • Resets all the cell’s values.
  • void Clear ( )
    • Removes all the content (all columns and rows are deleted).
Columns Handling
Inserting a column from code requires the user to specify the type of column that needs to be created, the valid column types are:
  • bool: Column with BoolCell
  • string: Column with StringCell
  • int: Column with IntCell
  • ivec2: Column with IntDupletCell
  • ivec3: Column with IntTripletCell
  • double: Column with DoubleCell
  • dvec2: Column with DoubleDupletCell
  • dvec3: Column with DoubleTripletCell
  • asset: Column with AssetCell
All column interactions take into consideration the maximum and minimum number of columns of the table
  • void AddColumn (string columnType)
  • void AddColumn (string columnType, string name)
    • Adds a column of type columnType named name if specified, otherwise the default is used.
  • void AddMultipleColumn (int count, string columnType)
    • Adds count columns of columnType type.
  • void InsertColumn (int index, string columnType)
  • void InsertColumn (int index, string columnType, string name)
    • Inserts a column at index index of columnType type named name if specified, otherwise the default is used.
  • vodi InsertMultipleColumn (int index, string columnType, int count)
    • Inserts count columns at index index of columnType type.
  • void RemoveColumnAt (int index)
    • Removes column at index index.
  • void MoveColumn (int targetIndex, int newPosition)
    • Moves column from targetIndex position to newPosition.
  • void ClearColumns ( )
    • Removes all columns.
  • void SetColumnWidth (int index, double width)
    • Sets the column width in pixels of column with index index.
Rows Handling
All row interactions take into consideration the maximum and minimum number of rows of the table
  • void SetNumberRows (int count)
    • Adds/removes rows until the table’s RowCount is equal to count.
  • void AddRow ( )
    • Adds a Row to the table.
  • void AddMultipleRow (int count)
    • Adds count rows to the table.
  • void InsertRow (int index)
    • Inserts a row at index position to the table.
  • void InsertMultipleRow (int index, int count)
    • Inserts count rows at index position to the table.
  • void RemoveRowAt (int index)
    • Removes row at index position.
  • void MoveRow (int targetIndex, int newPosition)
    • Moves row from targetIndex position to newPosition.
  • void ClearRows ( )
    • Removes all rows.
Table Parameter Example
// Open the cvs file with the starters, parse the content and add all riders to the RaceTable (TableParameter)
function LoadRaceTable()
// Setup columns from UI, Comment if already done manually
//RaceTable.Clear()
//RaceTable.AddColumn( "string", "Horse")
//RaceTable.AddColumn( "string", "Trainer")
//RaceTable.AddColumn( "string", "Jockey")
//RaceTable.AddColumn( "string", "Owner")
//RaceTable.AddColumn( "string", "Colors")
//RaceTable.AddColumn( "string", "Horse CN")
// Clear rows
RaceTable.ClearRows()
var i = 0
var FileContent = arc.ReadTextFile("D:/Horses/Starter.csv")
var EntryArr = FileContent.split("\n")
for(i = 1; i < EntryArr.length; i++)
// Split the rider content
var splitContent = EntryArr[i].split(",")
// CVS file has great amount of data but we only want to display certain stuff
  RaceTable.AddRow()
RaceTable.GetCell(i-1 , 0).Value = splitContent [19]
RaceTable.GetCell(i-1 , 1).Value = splitContent [22]
RaceTable.GetCell(i-1 , 2).Value = splitContent [25]
RaceTable.GetCell(i-1 , 3).Value = splitContent [27]
RaceTable.GetCell(i-1 , 4).Value = splitContent [34]
RaceTable.GetCell(i-1 , 5).Value = splitContent [20]
Video
Set the video and PTZ source.
  • void SetVideoSource (string name)
    • Sets the name of the preview source window.
  • void SetNDIPTZVideoControl (string ptzControl)
    • Sets the name of the NDI PTZ control overlay source.
