Viz Arc User Guide
Version 1.9 | Published October 31, 2023 ©
Files and Folders
Files and folders that are used or modified by Viz Arc are listed below.
Related files and folders can be found under C:\ProgramData\vizrt\VizArc.
config: Contains config.json file with all default and custom Viz Arc configuration.
keybinds: Contains keybinds.json file used to determine system keyboard shortcuts.
Logs: Contains a text log file containing every log name, date, log level and message since the first launch of the application.
profiles: Contains profiles.json file where configured profiles and corresponding Channels and Engines are stored.
projects: Contains a sub-folder and .json file for each saved Viz Arc project. You can change project folders in the Settings > Application Settings panel.
Resources: Contains useful resources (for example, plug-ins for external devices, Unreal plug-ins and Viz archives).
temp: Contains temporary files that are automatically created and deleted in case of a software crash.
