Set a Delay
Set a delay (ms) before a tracking parameter is sent to the Rig.
Insert a delay, in frames, for tracking delay adjustment.
graphics/setup_delay_add.png
Insert this value in the first box. If you keep the second box empty, the value is set for all axis. If you choose an axis in the second box, the value is set for this axis only. Press the button after inserting.
